AddPostCircuitBitFlipChecks
class AddPostCircuitBitFlipChecks(*args, **kwargs)
Bases: TransformationPass
Add bit-flip checks at the end of the circuit on active qubits terminated by a measurement.
A post-circuit bit-flip check consists of a narrowband X-pulse located after a terminal measurement that flips the state of the qubit from the measured state . The state is then measured, and if the QPU failed to flip the qubit on a given shot, that sample may be considered unreliable and discarded. Postselecting only samples that pass all checks can improve the fidelity of distributions sampled from the QPU.
The added measurements write to new classical registers that are copies of the DAG’s registers, with modified names (by default, appending "_ps" to the register name).
These passes are only supported on Heron QPUs where fractional gates are supported.
Initialize the pass.
Parameters
- x_pulse_type – The type of X-pulse to apply for the post-check measurements. Either
"xslow"or"rx". - post_check_suffix – A fixed suffix to append to the names of the classical registers when copying them.
- ignore_creg_suffixes – A list of suffixes for classical registers that should be ignored (not copied). By default, registers ending with “_pre” are ignored to avoid adding post-check to pre-check registers.
Attributes
is_analysis_pass
is_transformation_pass
Methods
execute
execute(passmanager_ir, state, callback=None)
Parameters
- passmanager_ir (DAGCircuit) – Qiskit IR to optimize.
- state (DAGCircuit) – State associated with workflow execution by the pass manager itself.
- callback (Callable[[Task, DAGCircuit, PropertySet, float, int], None] | None) – A callback function which is called per execution of optimization task.
Returns
Return type
name
run
run(dag)
Parameters
dag (DAGCircuit) – the dag on which the pass is run.
Raises
NotImplementedError – when this is left unimplemented for a pass.
update_status
update_status(state, run_state)
Update workflow status.
Parameters
- state (PassManagerState) – Pass manager state to update.
- run_state (RunState) – Completion status of current task.
Returns
Updated pass manager state.
Return type
