AddPreCircuitBitFlipChecks
class AddPreCircuitBitFlipChecks(*args, **kwargs)
Bases: TransformationPass
Add bit-flip checks at the beginning of the circuit on active qubits terminated by a measurement.
A pre-circuit bit-flip check consists of a narrowband X-pulse that rotates the qubit from followed by a normal X-pulse that rotates the qubit back to the ground state and a measurement. If the QPU fails to flip the qubit from on a given shot, that sample may be considered unreliable and discarded. Postselecting only samples that pass all checks can improve the fidelity of distributions sampled from the QPU.
The added measurements write to new classical registers that are copies of the DAG’s registers, with modified names (by default, appending "_pre" to the register name).
These passes are only supported on Heron QPUs where fractional gates are supported.
Initialize the pass.
Parameters
- x_pulse_type – The type of X-pulse to apply for the pre-check measurements. Either
"xslow"or"rx". - pre_check_suffix – A fixed suffix to append to the names of the classical registers when copying them.
- ignore_creg_suffixes – A list of suffixes for classical registers that should be ignored (not copied). By default, registers ending with “_ps” are ignored to avoid adding pre-check to post-check registers.
- ignore_creg_names – A list of exact classical register names that should be ignored (not copied). By default, registers named “spec” are ignored to avoid adding pre-check to spectator registers.
Attributes
is_analysis_pass
is_transformation_pass
Methods
execute
execute(passmanager_ir, state, callback=None)
Parameters
- passmanager_ir (DAGCircuit) – Qiskit IR to optimize.
- state (DAGCircuit) – State associated with workflow execution by the pass manager itself.
- callback (Callable[[Task, DAGCircuit, PropertySet, float, int], None] | None) – A callback function which is called per execution of optimization task.
Returns
Return type
name
run
run(dag)
Parameters
dag (DAGCircuit) – the dag on which the pass is run.
Raises
NotImplementedError – when this is left unimplemented for a pass.
update_status
update_status(state, run_state)
Update workflow status.
Parameters
- state (PassManagerState) – Pass manager state to update.
- run_state (RunState) – Completion status of current task.
Returns
Updated pass manager state.
Return type
