AddSpectatorPostCircuitBitFlipChecks
class AddSpectatorPostCircuitBitFlipChecks(*args, **kwargs)
Bases: TransformationPass
Add bit-flip checks at the end of the circuit on qubits adjacent to active qubits.
Each spectator qubit receives a post-circuit bit-flip check: a measurement, then a narrowband X-pulse that flips the qubit’s state (), then a second measurement. If the QPU fails to flip the qubit between the two measurements on a given shot, that sample may be considered unreliable and discarded. Postselecting only samples that pass all checks can improve the fidelity of distributions sampled from the QPU. Optionally via include_unmeasured, active qubits that are not terminated by a measurement are also treated as spectators.
Two classical registers are added, each with one bit per spectator qubit: spectator_creg_name (default "spec") holds the first measurement and spectator_creg_name + post_check_suffix (default "spec_ps") holds the second, and a shot is kept when the two disagree.
These passes are only supported on Heron QPUs where fractional gates are supported.
Initialize the pass.
Parameters
- coupling_map – A coupling map or a list of tuples indicating pairs of neighboring qubits.
- x_pulse_type – The type of X-pulse to apply between the two spectator measurements. Either
"xslow"or"rx". - include_unmeasured – Whether qubits that are active but not terminated should also be treated as spectators. If
True, the parity check is added to each of them as well. - spectator_creg_name – The name of the classical register holding the first spectator measurement. The post-check register is named
spectator_creg_name + post_check_suffix. - ignore_creg_suffixes – A list of suffixes for classical registers that should be ignored when determining active/terminated qubits. By default, registers ending with
"_pre"are ignored so that pre-check measurements aren’t treated as regular terminations. - post_check_suffix – The suffix appended to
spectator_creg_nameto form the post-check register name, and used to identify the data-qubit post-check barriers that the spectator parity check is integrated into. Defaults to"_ps".
Attributes
is_analysis_pass
is_transformation_pass
Methods
execute
execute(passmanager_ir, state, callback=None)
Parameters
- passmanager_ir (DAGCircuit) – Qiskit IR to optimize.
- state (DAGCircuit) – State associated with workflow execution by the pass manager itself.
- callback (Callable[[Task, DAGCircuit, PropertySet, float, int], None] | None) – A callback function which is called per execution of optimization task.
Returns
Return type
name
run
run(dag)
Parameters
dag (DAGCircuit) – the dag on which the pass is run.
Raises
NotImplementedError – when this is left unimplemented for a pass.
update_status
update_status(state, run_state)
Update workflow status.
Parameters
- state (PassManagerState) – Pass manager state to update.
- run_state (RunState) – Completion status of current task.
Returns
Updated pass manager state.
Return type
