AddSpectatorPreCircuitBitFlipChecks
class AddSpectatorPreCircuitBitFlipChecks(*args, **kwargs)
Bases: TransformationPass
Add bit-flip checks at the beginning of the circuit on qubits adjacent to active qubits.
Each spectator qubit receives a pre-circuit bit-flip check: A narrowband X-pulse that flips the qubit’s state (), then a regular X-pulse followed by a measurement. If the QPU fails to flip the qubit from , that sample may be considered unreliable and discarded. Postselecting only samples that pass all checks can improve the fidelity of distributions sampled from the QPU. Optionally via include_unmeasured, active qubits that are not terminated by a measurement are also treated as spectators.
The added measurements write to a new classical register with one bit per spectator qubit, named spectator_creg_name (default "spec_pre").
These passes are only supported on Heron QPUs where fractional gates are supported.
Initialize the pass.
Parameters
- coupling_map – A coupling map or a list of tuples indicating pairs of neighboring qubits.
- x_pulse_type – The type of X-pulse to apply for the pre-check measurements. Either
"xslow"or"rx". - include_unmeasured – Whether the qubits that are active but are not terminated by a measurement should also be treated as spectators. If
True, a terminal measurement is added on each of them. - spectator_creg_name – The name of the classical register added for the measurements on the spectator qubits.
- ignore_spectator_creg_names – List of classical register names to ignore when determining active qubits. Qubits that only have measurements to these registers are not considered active, preventing cascading spectator selection. Defaults to
["spec"](the default name used byAddSpectatorPostCircuitBitFlipChecks). - ignore_creg_suffixes – A list of suffixes for classical registers that should be ignored when determining terminated qubits. Qubits with measurements into registers with these suffixes are not considered terminated, allowing pre-check measurements to be added. By default, registers ending with “_ps” are ignored to allow pre-check after post-check.
- pre_check_suffix – The suffix used by AddPreCircuitBitFlipChecks for pre-check registers. This is used to identify which qubits have pre-check measurements and which barrier to extend. Defaults to “_pre”.
Attributes
is_analysis_pass
is_transformation_pass
Methods
execute
execute(passmanager_ir, state, callback=None)
Parameters
- passmanager_ir (DAGCircuit) – Qiskit IR to optimize.
- state (DAGCircuit) – State associated with workflow execution by the pass manager itself.
- callback (Callable[[Task, DAGCircuit, PropertySet, float, int], None] | None) – A callback function which is called per execution of optimization task.
Returns
Return type
name
run
run(dag)
Parameters
dag (DAGCircuit) – the dag on which the pass is run.
Raises
NotImplementedError – when this is left unimplemented for a pass.
update_status
update_status(state, run_state)
Update workflow status.
Parameters
- state (PassManagerState) – Pass manager state to update.
- run_state (RunState) – Completion status of current task.
Returns
Updated pass manager state.
Return type
