PostCircuitBitFlipChecksOptionsModel
pydantic model PostCircuitBitFlipChecksOptionsModel
GitHub
Bases: BaseModel
Options to apply post-circuit bit-flip checks to the results of noise learning circuits.
enable
field
Type: bool
Default value: False
Whether to apply post-circuit bit-flip checks.
If False, all the other fields will be ignored.
strategy
field
Type: Literal['node', 'edge']
Default value: 'node'
The strategy used to decide if a shot should be kept or discarded.
The available strategies are:
  • 'node': Discard every shot where one or more bits failed to flip. Keep every other shot.
  • 'edge': Discard every shot where there exists a pair of neighbouring qubits for which both of the bits failed to flip. Keep every other shot.
x_pulse_type
field
Type: Literal['xslow', 'rx']
Default value: 'xslow'
The type of the X-pulse used for the post-circuit bit-flip checks.
Was this page helpful?
