title: Configure noise management with Sampler
description: How to configure noise management with the IBM Quantum Estimator primitive.
source: https://eu-de.quantum.cloud.ibm.com/docs/en/guides/sampler-noise-management
# Configure noise management with Sampler
### Package versions
The code on this page was developed using the following requirements.
We recommend using these versions or newer.
qiskit-ibm-runtime~=0.47.0
There are several ways to manage noise, typically by using various error mitigation and error suppression techniques to avoid errors before they happen.  These techniques usually cause pre-processing overhead.  Therefore, it is important to achieve a balance between perfecting your results and ensuring that your job completes in a reasonable amount of time.
Sampler supports the following noise management techniques. See [Error mitigation and suppression techniques](/docs/guides/error-mitigation-and-suppression-techniques) for an explanation of each.
- [dynamical decoupling](/docs/api/qiskit-ibm-runtime/options-dynamical-decoupling-options#dynamicaldecouplingoptions)
- [Pauli twirling](/docs/api/qiskit-ibm-runtime/options-twirling-options)
> **Note**
> Not all options work together on all types of circuits. See the [feature compatibility table](/docs/guides/sampler-options#options-compatibility-table) guide for full details.
Example
sampler = Sampler(backend)
    f">>> dynamical decoupling sequence to use: "
    f"{sampler.options.dynamical_decoupling.sequence_type}"
## Next steps
> **Recommendations**
> - Learn more about [error mitigation and error suppression techniques](/docs/guides/error-mitigation-and-suppression-techniques).
> - Explore Sampler [options](/docs/guides/sampler-options).
> - Decide what [execution mode](/docs/guides/execution-modes) to run your job in.
