title: Circuit cutting for depth reduction
description: Build a Qiskit pattern for cutting gates in a quantum circuit to reduce circuit depth.
source: https://eu-de.quantum.cloud.ibm.com/docs/en/tutorials/depth-reduction-with-circuit-cutting
# Circuit cutting for depth reduction
*Usage estimate: Eight minutes on an Eagle processor (NOTE: This is an estimate only. Your runtime might vary.)*
## Background
This tutorial demonstrates how to build a `Qiskit pattern` for cutting gates in a quantum circuit to reduce circuit depth. For more in-depth discussion on circuit cutting, visit the [circuit cutting Qiskit addon docs](https://qiskit.github.io/qiskit-addon-cutting/).
## Requirements
- Circuit cutting Qiskit addon v0.9.0 or later (`pip install qiskit-addon-cutting`)
## Setup
from qiskit.circuit.library import EfficientSU2
from qiskit.quantum_info import PauliList, Statevector, SparsePauliOp
    cut_gates,
    generate_cutting_experiments,
We will implement our Qiskit pattern using the four steps outlined in the [docs](/docs/guides/intro-to-patterns). In this case, we will simulate expectation values on a circuit of a certain depth by cutting gates resulting in swap gates and executing subexperiments on shallower circuits. Gate cutting is relevant for Steps 2 (optimize circuit for quantum execution by decomposing distant gates) and 4 (post-processing to reconstruct expectation values on original circuit).
In the first step, we'll generate a circuit from the Qiskit circuit library and define some observables.
- Input: Classical parameters to define a circuit
- Output: Abstract circuit and observables
circuit = EfficientSU2(num_qubits=4, entanglement="circular").decompose()
circuit.assign_parameters([0.4] * len(circuit.parameters), inplace=True)
observables = PauliList(["ZZII", "IZZI", "IIZZ", "XIXI", "ZIZZ", "IXIX"])
circuit.draw("mpl", scale=0.8, style="iqp")
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/depth-reduction-with-circuit-cutting/extracted-outputs/54ed0f13-0.avif)
- Input: Abstract circuit and observables
- Output: Target circuit and observables produced by cutting distant gates to reduce transpiled circuit depth
We choose an initial layout that requires two swaps to execute the gates between qubits 3 and 0 and another two swaps to return the qubits to their initial positions. We choose `optimization_level=3`, which is the highest level of optimization available with a preset pass manager.
backend = service.least_busy(
    operational=True, min_num_qubits=circuit.num_qubits, simulator=False
    optimization_level=3, initial_layout=[0, 1, 2, 3], backend=backend
transpiled_qc = pm.run(circuit)
![Coupling map showing the qubits that will need to be swapped](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/depth-reduction-with-circuit-cutting/swaps.avif)
print(f"Transpiled circuit depth: {transpiled_qc.depth()}")
transpiled_qc.draw("mpl", scale=0.4, idle_wires=False, style="iqp", fold=-1)
Transpiled circuit depth: 103
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/depth-reduction-with-circuit-cutting/extracted-outputs/4fe4af43-1.avif)
*Find and cut the distant gates:* We will replace the distant gates (gates connecting non-local qubits, 0 and 3) with `TwoQubitQPDGate` objects by specifying their indices. `cut_gates` will replace the gates in the specified indices with `TwoQubitQPDGate` objects and also return a list of `QPDBasis` instances -- one for each gate decomposition. The `QPDBasis` object contains information about how to decompose the cut gates into single-qubit operations.
# Find the indices of the distant gates
cut_indices = [
    i
    for i, instruction in enumerate(circuit.data)
    if {circuit.find_bit(q)[0] for q in instruction.qubits} == {0, 3}
# Decompose distant CNOTs into TwoQubitQPDGate instances
qpd_circuit, bases = cut_gates(circuit, cut_indices)
qpd_circuit.draw("mpl", scale=0.8)
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/depth-reduction-with-circuit-cutting/extracted-outputs/23e3d25e-0.avif)
*Generate the subexperiments to run on the backend*: `generate_cutting_experiments` accepts a circuit containing `TwoQubitQPDGate` instances and observables as a `PauliList`.
To simulate the expectation value of the full-sized circuit, many subexperiments are generated from the decomposed gates' joint quasiprobability distribution and then executed on one or more backends. The number of samples taken from the distribution is controlled by `num_samples`, and one combined coefficient is given for each unique sample. For more information on how the coefficients are calculated, refer to the [explanatory material](https://qiskit.github.io/qiskit-addon-cutting/explanation/index.html).
# Generate the subexperiments and sampling coefficients
    circuits=qpd_circuit, observables=observables, num_samples=np.inf
*For comparison, we see that the QPD subexperiments will be shallower after cutting distant gates*: Here is an example of an arbitrarily chosen subexperiment generated from the QPD circuit. Its depth has been reduced by more than half. Many of these probabilistic subexperiments must be generated and evaluated in order to reconstruct an expectation value of the deeper circuit.
# Transpile the decomposed circuit to the same layout
transpiled_qpd_circuit = pm.run(subexperiments[100])
print(f"Original circuit depth after transpile: {transpiled_qc.depth()}")
    f"QPD subexperiment depth after transpile: {transpiled_qpd_circuit.depth()}"
transpiled_qpd_circuit.draw(
    "mpl", scale=0.6, style="iqp", idle_wires=False, fold=-1
Original circuit depth after transpile: 103
QPD subexperiment depth after transpile: 46
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/depth-reduction-with-circuit-cutting/extracted-outputs/70e2f1b6-1.avif)
*On the other hand, cutting results in the need of extra sampling*. Here we cut three CNOT gates, resulting in a sampling overhead of $9^3$. For more on the sampling overhead incurred by circuit cutting, refer to the [Circuit Knitting Toolbox documentation](https://qiskit-extensions.github.io/circuit-knitting-toolbox/circuit_cutting/explanation/index.html).
print(f"Sampling overhead: {np.prod([basis.overhead for basis in bases])}")
Sampling overhead: 729.0
Execute the target circuits ("subexperiments") with the Sampler primitive.
- Input: Target circuits
- Output: Quasi-probability distributions
# Transpile the subexperiments to the backend's instruction set architecture (ISA)
isa_subexperiments = pm.run(subexperiments)
# Set up the IBM Quantum Sampler primitive.  For a fake backend, this will use a local simulator.
sampler = SamplerV2(backend)
# Submit the subexperiments
job = sampler.run(isa_subexperiments)
# Retrieve the results
results = job.result()
print(job.job_id())
czypg1r6rr3g008mgp6g
Use the subexperiment results, subobservables, and sampling coefficients to reconstruct the expectation value of the original circuit.
Input: Quasi-probability distributions
Output: Reconstructed expectation values
reconstructed_expvals = reconstruct_expectation_values(
    results,
    coefficients,
    observables,
# Reconstruct final expectation value
final_expval = np.dot(reconstructed_expvals, [1] * len(observables))
print("Final reconstructed expectation value")
print(final_expval)
1.0751342773437473
ideal_expvals = [
    Statevector(circuit).expectation_value(SparsePauliOp(observable))
    for observable in observables
print("Ideal expectation value")
print(np.dot(ideal_expvals, [1] * len(observables)).real)
1.2283177520039992
## Tutorial survey
[Link to survey](https://your.feedback.ibm.com/jfe/form/SV_2ftYFf9t72yFNIO)
