title: Probabilistic error cancellation with shaded lightcones
description: Use probabilistic error cancellation (PEC) with shaded lightcones to cut PEC sampling overhead and mitigate errors in expectation value estimation on hardware
source: https://eu-de.quantum.cloud.ibm.com/docs/en/tutorials/pec-with-shaded-lightcones
# Probabilistic error cancellation with shaded lightcones
*Usage estimate: 10 minutes on a Heron processor (NOTE: This is an estimate only. Your runtime might vary.)*
## Learning outcomes
- What probabilistic error cancellation (PEC) is, and why its sampling overhead $\gamma^2$ grows exponentially with the total noise acting on the circuit
- How shaded lightcones (SLC) bound each noise term's contribution to the target observable, so that you can spend the mitigation budget where it matters — and how, beyond the zero-bias overhead reduction already provided by a purely geometric lightcone, the shading lets you trade a bounded residual bias for even lower sampling overhead
- How to learn layer noise with `NoiseLearnerV3` and inject anti-noise through `samplomatic` and the `Executor` primitive
- How to combine PEC and PEC+SLC with TREX and postselection to estimate an expectation value on hardware
## Prerequisites
- The [Qiskit patterns](/docs/guides/intro-to-patterns) workflow
- Using the [Estimator](/docs/guides/get-started-with-estimator) primitive to calculate expectation values of an observable
- Error mitigation techniques such as Pauli twirling and TREX, covered in [Combine error mitigation options with the Estimator primitive](/docs/tutorials/combine-error-mitigation-techniques)
## Background
This tutorial demonstrates how to mitigate errors by using the shaded lightcone (SLC) addon. This addon is an evolution of the [probabilistic error cancellation (PEC) technique](/docs/guides/error-mitigation-and-suppression-techniques#probabilistic-error-cancellation-pec), wherein a user learns the noise of unique layers in a circuit and then cancels out the noise by applying single-qubit gates and post-processing techniques. Compared to other methods, PEC offers more robust bounds on the bias of the mitigated result, but tends to suffer from a higher overhead in terms of QPU time. During PEC, to compensate for attenuation of the expectation value by noise, the average result is rescaled by a factor of $\gamma = \exp(\sum_{l,\sigma} 2\lambda_{l,\sigma})$, where $\lambda_{l,\sigma}$ is the learned noise rate of error Pauli $\sigma$ at layer $l$ in the circuit. This rescaling increases the variance by a factor of $\gamma^2$, and thus also multiplies the number of circuit executions needed on the QPU by $\gamma^2$, which we call the sampling cost or sampling overhead. Because $\gamma$ grows exponentially, PEC is often limited to shallow or few-qubit circuits. Learn more about PEC in [Probabilistic error cancellation with sparse Pauli-Lindblad models on noisy quantum processors](https://arxiv.org/abs/2201.09866).
If we can identify errors that do not need to be mitigated, we can decrease this sampling cost exponentially. A first step in this direction is implementing locally-aware error mitigation, which uses a quickly computable conventional "lightcone" to reduce the PEC overhead by bounding an observable's sensitivity to errors throughout the circuit, extending the feasibility of PEC to larger scales for some problems. Errors outside of this lightcone cannot affect the measured outcome and can therefore be excluded from the error cancellation procedure. This exclusion decreases the sampling overhead, in some cases substantially, without introducing additional bias. In particular, for measuring a local observable $O$ of a fixed-depth circuit, the required sampling overhead eventually plateaus when scaling the number of qubits in the circuit (see Fig. 2b in [Locality and error mitigation of quantum circuits](https://arxiv.org/abs/2303.06496)).
Shaded lightcones (SLC) go further, using classical simulations to more tightly bound the sensitivity to errors throughout the circuit. This trades some QPU time for CPU time and reduces the sampling overhead needed to renormalize the bias. Instead of a hard cutoff, each potential error in the circuit is assigned a graded "shade" that upper-bounds the susceptibility of the observable's expectation value to that error. (For the backward-propagated bounds introduced below, this susceptibility also depends on the circuit's initial state — the all-zero state in typical workflows, and in this tutorial.) This refined characterization allows for more efficient, targeted applications of PEC with reduced variance, while giving the user the ability to controllably tune the bias in the observable estimation. See [Lightcone shading for classically accelerated quantum error mitigation](https://arxiv.org/abs/2409.04401) for more details.
Our workflow for the SLC addon leverages the [`samplomatic`](https://qiskit.github.io/samplomatic/guides/index.html) library together with the `QuantumProgram` and `Executor` classes added to Qiskit Runtime in `qiskit-ibm-runtime` v0.47.0, allowing users to have more modular control of execution settings for error suppression and mitigation while retaining ease of use. Read more in the [directed execution model](/docs/guides/directed-execution-model) guide.
### SLC error-mitigation workflow at a glance
For modeling the QPU's noise, we use a sparse Pauli-Lindblad noise model with one- and two-qubit Pauli error rates, locally generated on each qubit and edge of the device. With this choice, the SLC error-mitigation workflow presented in this tutorial is as follows:
a. CPU — Bound per-error impact of one- and two-qubit Pauli errors
1. Forward propagation (bound effect on observable). Propagate each error to the end of the circuit and compute its commutator with the observable.
   - Truncate operator terms during evolution to keep computation tractable.
   - Further tighten these bounds by a loose back-propagation of the observable based on quantum speed limits.
2. Backward propagation (bound effect on initial state). Propagate each error to the start of the circuit and compute its commutator with the initial state.
b. QPU — Learn noise rates. Use `NoiseLearnerV3` to estimate rates of the Pauli-Lindblad noise model.
c. CPU — Prioritize mitigation
1. Update merged bounds with learned noise rates. Combine forward and backward bounds that were previously computed and update them with learned noise rates.
2. Rank noise components to mitigate by using the computed bounds and learned rates. Prioritize each possible noise error based on its estimated impact on bias and the associated expense to correct.
d. QPU — Insert anti-noise and run. Execute the circuit of interest with anti-noise (inverse noise) specified by using `Box` annotations.
e. CPU — Estimate observable. Compute the expectation value, applying measurement-based post-selection to reduce non-Markovian noise impact.
### Noise learning overview
Noise learning is a common step in several error-mitigation methods, carried out by the [noise learner](/docs/guides/noise-learning); it also appears in the [probabilistic error amplification tutorial](/docs/tutorials/probabilistic-error-amplification). In `NoiseLearnerV3`, you can specifically identify the to-be-learned noise layers as [`CircuitInstruction`](/docs/api/qiskit/qiskit.circuit.CircuitInstruction) objects, so that you can compute the desired SLC noise bounds for each layer in the manner described above. The learned Pauli-Lindblad model provides coefficients to be used in the PEC+SLC prioritization. The way in which the gates are collected into layers can be determined by using the `generate_boxing_pass_manager` and `find_unique_box_instructions` convenience functions, and then fed into the SLC utility function `generate_noise_model_paulis`, as described in Step 2 below.
| **Part 1**        | **Part 2**        | **Part 3**        |
| Pauli-twirl two-qubit gate layers        | Repeat identity pairs of layers and learn noise        | Derive a fidelity (error for each noise channel)        |
| ![Pauli twirling](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/paulitwirl.avif) | ![Learn layer](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/learnlayer.avif) | ![Curve fit](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/curvefit.avif) |
### Post-processing overview
After executing on quantum hardware by using the `samplomatic` and `Executor` framework, we convert our bitstring measurements into the desired observable value. In this tutorial, we demonstrate the workflow on a mirrored Ising circuit (constructed in Step 1 below), for which the ideal expectation value of the measured observable is 1 because the second half of the circuit undoes the first. When computing the observable value with the `executor_expectation_values` function, we apply a few post-processing techniques that reduce noise impact. These include removing shots affected by non-Markovian noise, readout-error mitigation, and accounting for details of our PEC implementation. Details are discussed in Step 4 below.
## Requirements
- Qiskit SDK v2.2 or later, with [visualization](/docs/api/qiskit/visualization) support
- Qiskit Runtime v0.47 or later (`pip install qiskit-ibm-runtime`)
- Shaded lightcones Qiskit addon v0.1 or later (`pip install qiskit-addon-slc`)
- Qiskit addon utils v0.3 or later (`pip install qiskit-addon-utils`)
- Samplomatic v0.13 or later (`pip install samplomatic`)
## Setup
First, import the packages and functions needed to run this notebook.
from multiprocessing import set_start_method
# Setting this value prevents itertools.starmap deadlock on UNIX systems
set_start_method("spawn")
# Needed to prevent PySCF from parallelizing internally (SLC only)
%set_env OMP_NUM_THREADS=1
env: OMP_NUM_THREADS=1
from qiskit.transpiler import generate_preset_pass_manager, PassManager
    QiskitRuntimeService,
    QuantumProgram,
    Executor,
    NoiseLearnerV3,
import samplomatic
from qiskit_addon_utils.exp_vals.measurement_bases import (
    get_measurement_bases,
from qiskit_addon_utils.exp_vals.expectation_values import (
    executor_expectation_values,
from qiskit_addon_utils.noise_management import (
    gamma_from_noisy_boxes,
    trex_factors,
from qiskit_addon_utils.noise_management.post_selection import PostSelector
from qiskit_addon_utils.noise_management.post_selection.transpiler.passes import (
    AddPostSelectionMeasures,
    AddSpectatorMeasures,
from qiskit_addon_slc.bounds import (
    compute_backward_bounds,
    compute_forward_bounds,
    compute_local_scales,
    merge_bounds,
    tighten_with_speed_limit,
from qiskit_addon_slc.utils import (
    generate_noise_model_paulis,
    map_modifier_ref_to_ref,
from qiskit_addon_slc.visualization import draw_shaded_lightcone
Like other learning-based error mitigation methods, PEC with shaded lightcones mitigates the *physical* noise of a specific quantum processor, so it depends on hardware services with no meaningful analog on an ideal simulator:
- `NoiseLearnerV3` experimentally characterizes the sparse Pauli-Lindblad noise channel on each unique two-qubit layer. On a noiseless simulator there is no noise to cancel.
- The `Executor` primitive samples the twirled, anti-noise-injected circuits generated by `samplomatic` on a backend.
The shaded-lightcone bound computation is classical, but it is only meaningful relative to the learned hardware noise rates, which set the mitigation budget and sampling overhead. For these reasons we skip the small-scale simulator example and demonstrate the full PEC+SLC workflow directly on hardware, with each step of the Qiskit pattern broken out below.
We run the complete PEC+SLC workflow on a 20-qubit mirrored Ising circuit executed on IBM Quantum® hardware, following the four steps of a Qiskit pattern.
### Step 1: Map the problem
Our demonstration is set up as follows:
1. We choose to perform time evolution under a 1D Ising chain Hamiltonian. The 1D Ising chain gives a nicely dense circuit structure, which is convenient for showcasing PEC implementations.
2. We choose to measure the observable $\langle X_6 Z_{13}\rangle$, which contains one $X$ and one $Z$ component. This is convenient for highlighting how the SLC bounds treat different types of errors differently.
3. We want the ideal expectation value of this observable to be exactly 1, so that the quality of the mitigated estimates is easy to judge. Mirroring the circuit gets us most of the way there: for every gate in the second half of the circuit there is an inverse gate in the first half, so that the ideal circuit acts as the identity.
4. Finally, obtaining the ideal expectation value of 1 requires the circuit to start — and therefore, thanks to the mirroring, ideally also end — in a +1 eigenstate of the observable. Because the observable contains a non-$Z$ component, and the `Executor` primitive accounts for the desired measurement basis at the end of the circuit, we prepend the corresponding basis-preparation gates at the start of the mirror circuit with a `prepare_basis` function. We use the `get_measurement_bases` function to identify which gates are needed and where to place them, while keeping track of qubit-index subtleties arising from `box` annotation conventions, as discussed in the section on preparing canonical basis measurements.
# Width of the Ising chain (a free parameter of this demonstration)
num_qubits = 20
# The observable to measure: one X component (on qubit 6) and one Z component
# (on qubit 13), as motivated in "Step 1: Map the problem" above
target_obs_sparse = [("XZ", [6, 13], 1.0)]
    target_obs_sparse, num_qubits=num_qubits
# Determine the measurement basis each qubit requires for this observable.
# The reverser is used during post-processing in Step 4.
bases_virt, reverser_virt = get_measurement_bases(observable)
# Free parameters of the demonstration circuit: the number of Trotter steps
# sets the circuit depth, and rx_angle is the transverse-field rotation angle
# applied in each step (pi/4 makes the dynamics non-Clifford)
num_trotter_steps = 10
rx_angle = np.pi / 4
def construct_ising_circuit(
    num_qubits: int,
    num_trotter_steps: int,
    rx_angle: float,
) -> QuantumCircuit:
    for _ in range(num_trotter_steps):
        for first_qubit in (1, 2):
                # equivalent to Rzz(-pi/2):
                circuit.sdg([idx - 1, idx])
                circuit.cz(idx - 1, idx)
    return circuit
def prepare_basis(
    circuit: QuantumCircuit, basis: list[int]
    # basis is a list of integer values from 0 to 3. These map to the basis measurement as:
    # 0 = I; 1 = Z; 2 = X; 3 = Y
    assert len(basis) == circuit.num_qubits
    out_circ = circuit.copy_empty_like()
    for qb, bas in enumerate(basis):
        if bas == 2:
            out_circ.h(qb)
        elif bas == 3:
            out_circ.rx(-np.pi / 2, qb)
    out_circ.barrier()
    out_circ.compose(circuit, inplace=True)
    return out_circ
def mirror_circuit(circuit: QuantumCircuit) -> QuantumCircuit:
    mirror_circ = circuit.copy_empty_like()
    mirror_circ.compose(circuit.inverse(), inplace=True)
    mirror_circ.barrier()
    mirror_circ.compose(circuit, inplace=True)
    mirror_circ.measure_active()
    return mirror_circ
# Instantiate the mirrored circuit and prepend the basis-preparation gates
circuit = construct_ising_circuit(num_qubits, num_trotter_steps, rx_angle)
mirrored_circuit = mirror_circuit(circuit)
mirrored_circuit = prepare_basis(mirrored_circuit, bases_virt[0])
mirrored_circuit.draw(
    "mpl", fold=-1, scale=0.3, idle_wires=False, measure_arrows=False
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/extracted-outputs/0dab284e-dbed-4d2f-92aa-c6c9c0e909a6-0.avif)
### Step 2: Optimize
We optimize details associated with the circuit to be run, the observable to be measured, and the noise-learning parameters. As a starting point, we select the least-busy Heron processor and instantiate it with fractional gates turned on. These fractional gates allow for greater sensitivity in some of our post-selection filtering.
# Initialize IBM Quantum Compute Service using your saved credentials
# Select the least busy Heron device. This tutorial targets Heron processors:
# the usage estimate and the non-Markovian-noise post-selection discussed in
# Step 4 are specific to this processor family.
backend = service.least_busy(
    operational=True,
    simulator=False,
    filters=lambda b: b.processor_type["family"] == "Heron",
# Re-fetch with fractional gates enabled (least_busy does not forward this)
# Fractional gates are enabled so the non-Clifford Rx rotations are supported natively.
backend = service.backend(backend.name, use_fractional_gates=True)
print(f"Selected backend: {backend.name}")
Selected backend: ibm_kingston
First, we will transpile our circuit to ISA instructions, [as required for execution on our QPUs](/docs/guides/transpile#instruction-set-architecture). The choice of physical qubits to run on has a large impact on the quality of the results, because coherence times and gate fidelities vary across a device and drift over time. For a careful experiment, it can pay off to hand-select a chain of qubits informed by quick benchmarking experiments (see, for example, the [Real-time benchmarking for qubit selection](/docs/tutorials/real-time-benchmarking-for-qubit-selection) tutorial). For the purposes of this tutorial, we rely on the Qiskit transpiler to select a layout based on the backend's coupling map and its most recent calibration data.
isa_pm = generate_preset_pass_manager(backend=backend, optimization_level=1)
isa_circuit = isa_pm.run(mirrored_circuit)
# The chain of physical qubits selected by the transpiler
layout = isa_circuit.layout.final_index_layout()
print(f"Selected layout: {layout}")
isa_observable = observable.apply_layout(
    layout, num_qubits=isa_circuit.num_qubits
Selected layout: [71, 58, 51, 50, 49, 48, 47, 46, 45, 44, 43, 42, 41, 36, 21, 22, 23, 16, 3, 2]
wire_order = layout + [
    q for q in range(isa_circuit.num_qubits) if q not in layout
isa_circuit.draw(
    "mpl",
    fold=-1,
    scale=0.3,
    idle_wires=False,
    wire_order=wire_order,
    measure_arrows=False,
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/extracted-outputs/87f19e08-0cae-4959-9215-354ab099ab02-0.avif)
### Box the circuit
For ease of implementation, we utilize the `generate_boxing_pass_manager` transpilation pass, which places the circuit instructions into annotated boxes. These boxes clearly indicate where, in the case of PEC, anti-noise should be injected into the circuit. For details on settings, refer to the [Samplomatic documentation](https://qiskit.github.io/samplomatic/).
Note that the SLC workflow requires the use of `inject_noise_strategy="individual_modification"` later in the process because this allows us to uniquely identify the `InjectNoise` annotations of the `BoxOp` instructions in the circuit. (Boxes without an `InjectNoise` annotation cannot be identified in this way.)
> **Caution**
> The SLC bound computations currently assume that the `InjectNoise` annotations are placed with `site="after"` (see [qiskit-addon-slc#33](https://github.com/Qiskit/qiskit-addon-slc/issues/33)). Because the default value of this setting changed in recent versions of `samplomatic` (see [samplomatic#372](https://github.com/Qiskit/samplomatic/pull/372)), we set `inject_noise_site="after"` explicitly below.
The `find_unique_box_instructions` function iterates through the provided boxed circuit and identifies those that have unique two-qubit (2Q) layers or measurements, for the purpose of noise learning and noise injection.
# Box circuit with Twirl and InjectNoise annotations
boxes_pm = generate_boxing_pass_manager(
    twirling_strategy="active",
    inject_noise_site="after",
    inject_noise_targets="gates",
    measure_annotations="all",
boxed_circuit = boxes_pm.run(isa_circuit)
# Find the unique instructions (layers) from boxed circuit
unique_2q_instructions = find_unique_box_instructions(
    boxed_circuit, normalize_annotations=None, undress_boxes=True
boxed_circuit.draw(
    "mpl",
    fold=-1,
    scale=0.3,
    idle_wires=False,
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/extracted-outputs/d662b076-005e-46c7-826d-4c29a4937404-0.avif)
### Prepare canonical bases measurements
Note that we must take special care to keep track of qubit ordering. Below, we introduce the notion of `canonical_qubits` as a means to appropriately update the qubit ordering when providing it to Executor, as a result of how qubit order is captured when boxing circuits and finding unique instructions. See the [Qubit ordering convention](https://qiskit.github.io/samplomatic/guides/samplex_io.html#qubit-ordering-convention) documentation for details.
# Determine the canonical qubits order
meas_box = boxed_circuit.data[-1]
canonical_qubits = [
    idx
    for idx, qubit in enumerate(boxed_circuit.qubits)
    if qubit in meas_box.qubits
# map canonical qubit to physical (isa) qubit
c_2_p = {c: p for c, p in enumerate(canonical_qubits)}
# map physical (isa) qubit to virtual qubit (index in original circuit)
p_2_v = {p: v for v, p in enumerate(layout)}
# compute map between virtual and canonical qubit indices.
c_2_v = {c: p_2_v[p] for c, p in c_2_p.items()}
assert len(c_2_v) == num_qubits
bases_canon = [
    np.array([base_i[c_2_v[c]] for c in range(num_qubits)], dtype=np.uint8)
    for base_i in bases_virt
### Workflow for lightcone shading, noise learning, and anti-noise injection
> **Note**
> In this tutorial, we run the SLC bound computations before the noise learning completes, so the to-be-mitigated circuit is run as close in time as possible to the learned noise model. In principle this workflow can be parallelized further: a noise-learning job can run while, in parallel, the noise bounds are estimated. For an arbitrary quantum circuit the noise-bound computation can scale with a weakly exponential dependence, so parallelizing the bound computation (for example, across many CPU cores) yields tighter bounds for a given compute-time budget, and the QPU executions and bound computations can themselves be parallelized for the most efficient workflow.
#### Predict to-be-learned noise-model Paulis
Before running any noise learning on hardware, we first enumerate which Pauli error terms our noise model will contain. Recall that we model the noise of each unique layer as a sparse Pauli-Lindblad model with one error rate for each weight-one Pauli ($X$, $Y$, or $Z$) on each active qubit, and one for each weight-two Pauli on each connected pair of active qubits. The `generate_noise_model_paulis` function goes through each unique boxed layer of the provided circuit and generates exactly this list of Pauli terms, taking the circuit's qubit connectivity into account.
In other words, this step predicts the *structure* of the noise model that `NoiseLearnerV3` will later fill in with learned rates. Knowing this structure ahead of time is what allows us to compute a forward and a backward bound for every potential error before the noise learning has even run.
noise_model_paulis = generate_noise_model_paulis(
    unique_2q_instructions, backend.coupling_map, boxed_circuit
noise_model_rates = {ref: None for ref in noise_model_paulis}
##### a. Compute forward bounds
The `compute_forward_bounds` function evaluates the commutation relations between the gates in each layer and the above-generated Pauli terms in terms of how forward-propagation errors affect the desired observable $A$. For gates that commute with the Pauli terms, nothing is done. For Clifford gates, they are pushed toward the beginning of the circuit. For non-Clifford gates, we approximate their influence on the target observables to later be prioritized for noise cancellation (after all bounds have been merged). This bound is achieved by first applying the L2 norm (namely, the square root of the sum of squares of the relevant Pauli-term coefficients). When there are too many qubit terms involved, we revert to a looser bound that uses the triangle inequality.
#### Set the bound-computation parameters
The following settings control the classical bound computations:
- `slc_atol`: the absolute tolerance of the computations. Operator terms with coefficients below this threshold are treated as negligible and discarded.
- `slc_eigval_max_qubits`: the maximum number of qubits for which the tighter, eigenvalue-based (L2-norm) bound is evaluated. Operators supported on more qubits than this fall back to the looser triangle-inequality bound described above.
- `slc_evolution_max_terms`: the maximum number of Pauli terms retained while propagating operators through the circuit. Truncating the smallest terms keeps the computation tractable at the cost of slightly looser bounds.
- `slc_num_processes`: the number of CPU processes across which the bound computation is parallelized.
- `slc_timeout`: the time budget (in seconds) for the bound computation. Any layers not reached within this budget are assigned the trivial bound of 2.
> **Note**
> In this tutorial, the timeout is reached *by design*: we keep `slc_timeout` deliberately small so that the notebook runs quickly, and to demonstrate that reaching the timeout is safe. The computed shades are upper bounds at every stage, so hitting the timeout only makes the bounds looser (trivial) for the layers that were not reached; it never underestimates the effect of an error. This appears in the visualizations below as the leftmost layers being filled entirely with the trivial bound. Increasing the timeout (or the number of processes) tightens the bounds and further reduces the sampling overhead.
slc_atol = 1e-8
slc_eigval_max_qubits = 18
slc_evolution_max_terms = 1000
slc_num_processes = 8
slc_timeout = 60
forward_bounds = compute_forward_bounds(
    boxed_circuit,
    noise_model_paulis,
    isa_observable,
    evolution_max_terms=slc_evolution_max_terms,
    eigval_max_qubits=slc_eigval_max_qubits,
    atol=slc_atol,
    num_processes=slc_num_processes,
    timeout=slc_timeout,
Bounds computation timed out.
#### Visualize the SLC for manual inspection
You can interpret the behavior of the shaded bounds by examining how the measurements and Pauli terms interact with the local errors. These patterns are characteristic of this kicked Ising Hamiltonian time-evolution problem and also appear in the paper [Lightcone Shading for Classically Accelerated Quantum Error Mitigation](https://arxiv.org/abs/2409.04401), with several telltale features:
- We can clearly distinguish the two cones arising from the two non-identity Paulis in the observable.
- We can see that the X measurement on qubit 6 commutes with the X error in the rightmost layer.
- We can see that the Z Pauli on qubit 13 commutes with the Z error in the rightmost layer.
- When we reach the timeout specified above, the remaining layers to the left are filled entirely with trivial bounds of two.
for p in "XYZ":
    display(
        draw_shaded_lightcone(
            boxed_circuit,
            forward_bounds,
            noise_model_paulis,
            pauli_filter=p,
            scale=0.15,
            fold=-1,
            idle_wires=False,
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/extracted-outputs/285edaef-8e79-41eb-a563-4675ea75d5b1-0.avif)
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/extracted-outputs/285edaef-8e79-41eb-a563-4675ea75d5b1-1.avif)
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/extracted-outputs/285edaef-8e79-41eb-a563-4675ea75d5b1-2.avif)
#### b. Tighten forward bounds with quantum speed limits
We next tighten the bounds by using the `tighten_with_speed_limit` function. The geometric spread of the observable's lightcone is already fully accounted for in the forward bounds computed above. What this function adds is a self-consistency pass that leverages the limited speed at which information can flow through the circuit — the lightcone grows by at most one qubit per layer of two-qubit gates — to tighten the previously computed bounds with respect to each other. The information flows in both directions:
1. From the commutator bounds to the bounds on the backpropagated observable: if the observable commutes with a $Z$ error on a qubit, then it cannot have much $X$ or $Y$ component there.
2. From the bounds on the backpropagated observable to the commutator bounds: if the observable has little $X$ and $Y$ component on a qubit, then it must almost commute with $Z$ there.
forward_bounds_tighter = tighten_with_speed_limit(
    forward_bounds, boxed_circuit, noise_model_paulis, isa_observable
In principle, this tightening provides a smoother transition between the computed bounds and the trivial bounds assigned to the layers beyond the timeout. In this example the effect is barely visible, because the lightcones have already spread to the edges of the circuit by the time the timeout is reached.
for p in "XYZ":
    display(
            boxed_circuit,
            forward_bounds_tighter,
            noise_model_paulis,
            pauli_filter=p,
            scale=0.15,
            fold=-1,
            idle_wires=False,
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/extracted-outputs/6ba4b397-e903-4b85-9482-31a96c689dc0-0.avif)
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/extracted-outputs/6ba4b397-e903-4b85-9482-31a96c689dc0-1.avif)
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/extracted-outputs/6ba4b397-e903-4b85-9482-31a96c689dc0-2.avif)
#### c. Compute backward bounds
This part of noise prediction evaluates how an error at a particular layer can affect the input state $\rho$. The `compute_backward_bounds` function first inverts the circuit and removes measurement gates, and then proceeds with a similar analysis as was done for the forward-bound computations.
backward_bounds = compute_backward_bounds(
    boxed_circuit,
    noise_model_paulis,
From computing backward bounds, we can see how the initial state structure governs the early behavior of error propagation:
- We can clearly see how the Z errors initially commute with the |0⟩ initial state.
- Only on qubit 6, where we initialize the +1 eigenstate of the X basis, does a Z error fail to commute, while an X error does commute.
for p in "XYZ":
    display(
            boxed_circuit,
            backward_bounds,
            noise_model_paulis,
            pauli_filter=p,
            scale=0.15,
            fold=-1,
            idle_wires=False,
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/extracted-outputs/40d0eba9-5e0b-4b1d-8fb2-c239e262062f-0.avif)
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/extracted-outputs/40d0eba9-5e0b-4b1d-8fb2-c239e262062f-1.avif)
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/extracted-outputs/40d0eba9-5e0b-4b1d-8fb2-c239e262062f-2.avif)
#### Preview merged bounds without learned noise rates
The `merged_bounds` function determines the point in the circuit where switching from backward bounds to forward bounds minimizes the total estimated bias on the desired observable. This bias is computed as the sum of the backward-bound contributions for all noise locations before that point, plus the forward-bound contributions for all noise locations after it. Currently, this is done uniformly for all qubits.
> **Important note**
> The optimal point at which to switch from backward to forward bounds depends on the learned noise rates. At this stage we have not yet learned any rates: `noise_model_rates` was initialized to `None` for every layer, which `merge_bounds` treats as uniform noise rates. The merged bounds shown here are therefore only a preview; we recompute them with the actual learned rates in Step 3.
merged_bounds = merge_bounds(
    boxed_circuit,
    backward_bounds,
    noise_model_rates,
Missing noise rates. Partitioning backward/forward commutator bounds by assuming uniform error rates.
Optimal spacetime partitioning not implemented!Just partitioning list of noisy boxes.
After merging the backward and tightened forward bounds, the behavior of the combined SLCs becomes clear:
- The function above tells us that a partition is chosen at which the switch from backward to tightened forward bounds takes place.
- We can see below that the SLCs now contain partial backward and partial tightened forward bounds.
for p in "XYZ":
    display(
            boxed_circuit,
            merged_bounds,
            noise_model_paulis,
            pauli_filter=p,
            scale=0.15,
            fold=-1,
            idle_wires=False,
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/extracted-outputs/eb2948bc-fa27-4108-b03c-0291d3b2f7c8-0.avif)
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/extracted-outputs/eb2948bc-fa27-4108-b03c-0291d3b2f7c8-1.avif)
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/extracted-outputs/eb2948bc-fa27-4108-b03c-0291d3b2f7c8-2.avif)
### Step 3: Execute
In this section we begin the part of the workflow that uses a real quantum device. For this learning-based error mitigation method, there are two steps:
1. Learn the noise by using `NoiseLearnerV3`.
2. Execute an error-mitigation circuit with the `samplomatic` and `Executor` framework.
With the bounded errors from our quantum circuit, we learn the associated noise rates to prioritize our error budget, determine the sampling overhead, and execute on a QPU.
### a. Learn the noise rates
The noise learner characterizes the noise processes affecting the gates in one or more circuits of interest, based on the sparse [Pauli-Lindblad noise model](https://arxiv.org/abs/2201.09866). The `run()` method launches a noise-learning job for the provided unique two-qubit layers, using the options specified in the noise-learner configuration. These options control the Pauli-twirling strategy, the number of randomizations and shots, the learning depths, and post-selection.
We also choose the learning depths deliberately. A practical finding for learning-based mitigation with `samplomatic` is that it is highly beneficial for the deepest learning depth to match the depth of the circuit you want to mitigate. Because NLv3 `layer_pair_depths` are measured in layer *pairs* (a layer plus its inverse), we set the deepest value to half the circuit's two-qubit-layer depth.
post_selection_enabled = True
# Match the deepest noise-learning depth to the depth of the circuit being
# mitigated. NLv3 ``layer_pair_depths`` are measured in layer pairs (a layer
# plus its inverse), so the deepest value is half the circuit's two-qubit-layer
# depth. Learning to this depth markedly improves the quality of the mitigation.
# We measure the two-qubit-layer depth on the pre-boxed ISA circuit: after
# boxing, every two-qubit gate is hidden inside a full-width ``BoxOp``, so a
# ``num_qubits == 2`` filter on ``boxed_circuit`` matches nothing (and
# ``QuantumCircuit.depth`` does not recurse into boxes).
depth_2q = isa_circuit.depth(lambda instr: instr.operation.num_qubits == 2)
max_layer_pair_depth = depth_2q // 2  # dividing by 2 since we want pairs
# Use a fixed schedule of learning depths, but drop any that exceed the circuit's
# depth and always cap the deepest value at ``max_layer_pair_depth`` so we never
# learn deeper than the circuit being mitigated.
candidate_depths = [1, 2, 4, 8, 12, 16, 24, 32, 40, 48]
layer_pair_depths = sorted(
    {d for d in candidate_depths if d < max_layer_pair_depth}
    | {max_layer_pair_depth}
noise_learner_options = {
    "num_randomizations": 64,
    "layer_pair_depths": layer_pair_depths,
    "post_selection": {
        "enable": post_selection_enabled,
        "strategy": "edge",
        "x_pulse_type": "rx",
    "environment": {"job_tags": ["TUT_SLC"]},
noise_learner = NoiseLearnerV3(backend, noise_learner_options)
noise_learner_job = noise_learner.run(unique_2q_instructions)
noise_learner_result = noise_learner_job.result()
if post_selection_enabled:
        "Minimum fraction of shots kept for noise learning experiments: ",
        end="",
        f"{min([min(d.values()) for d in [nlr.metadata['post_selection']['fraction_kept'] for nlr in noise_learner_result[:2]]]):.2f}"
Minimum fraction of shots kept for noise learning experiments: 0.71
# Get a dict mapping each InjectNoise.ref to its learned PauliLindbladMap
refs_2_plm = noise_learner_result.to_dict(
    unique_2q_instructions, require_refs=False
### b.i. Update merged bounds with actual learned noise rates
Now that the specific noise model has been learned, we can apply the learned noise rates to the predicted noise bounds and obtain a final determination of which bounds have the most impact on minimizing the bias.
    boxed_circuit,
    backward_bounds,
    refs_2_plm,
#### b.ii. Compute the `local_scales` for the hardware execution
`compute_local_scales` looks at each possible noise error in the circuit and estimates how much that error could bias the final measurement, as well as how expensive it would be to correct it. It then ranks the errors by how worthwhile they are to mitigate and selects the subset that reduces bias as much as possible, while staying within the allowed sampling-cost budget (or achieving a desired accuracy). The result is a set of scaling factors indicating which errors will be actively mitigated and which will be left unmitigated (`local_scales`), along with the predicted total sampling cost overhead (`sampling_costs`) and remaining bias (`residual_bias_bound`).
The ability to control the desired remaining bias is a critical feature of the SLC implementation of PEC. Whereas in the [original implementation](https://arxiv.org/abs/2201.09866), the sampling overhead always targeted zero bias, we can tune the required sampling overhead with a trade-off in the expected remaining bias. This helps let the user stay within a fixed sampling budget, which can be particularly useful when initially prototyping a workflow.
id_map = map_modifier_ref_to_ref(boxed_circuit)
summed_rates = 0.0
for box_id, noise_id in id_map.items():
    learned_plm = refs_2_plm[noise_id]
    summed_rates += np.sum(learned_plm.rates)
    # print(f"{box_id}:\tgamma = {np.exp(2 * summed_rates):1.6e}\tsampling cost = {np.exp(4 * summed_rates):1.6e}")
total_gamma = np.exp(2 * summed_rates)
    f"Full PEC gamma={total_gamma}, sampling cost (gamma^2) = {total_gamma**2}"
Full PEC gamma=12.750876317157042, sampling cost (gamma^2) = 162.58484685543633
biases = []
costs = []
for bias in [0.0] + np.arange(0.001, 0.102, 0.01).tolist():
    _, cost_, bias_ = compute_local_scales(
        boxed_circuit,
        merged_bounds,
        refs_2_plm,
        sampling_cost_budget=np.inf,
        bias_tolerance=bias,
    biases.append(bias_)
    costs.append(cost_)
#### Trade off sampling overhead against residual bias
xticks = np.arange(0, 11)
fig, ax = plt.subplots()
ax.scatter(
    [0], [total_gamma**2], marker="D", c="tab:orange", label="full PEC"
ax.plot(
    100 * np.array(biases),
    np.array(costs),
    "o-",
    c="tab:blue",
    label="PEC+SLC",
ax.set_yscale("log")
ax.set_xticks(xticks, [f"{x:.1f}" for x in xticks])
ax.set_xlabel("Remaining bias [%]")
ax.set_ylabel(r"Sampling overhead, $\gamma^2$")
ax.grid()
ax.legend()
fig.suptitle("PEC sampling overhead reduction due to SLC")
Text(0.5, 0.98, 'PEC sampling overhead reduction due to SLC')
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/extracted-outputs/slc-ovplot-0-4000-8000-000000000066-1.avif)
chosen_bias_thres = 0.1
local_scales, sampling_cost, residual_bias_bound = compute_local_scales(
    boxed_circuit,
    merged_bounds,
    refs_2_plm,
    bias_tolerance=chosen_bias_thres,
    f"PEC+SLC sampling cost (gamma^2) = {sampling_cost} "
    f"w/ remaining bias = {100 * residual_bias_bound:.1f}%"
PEC+SLC sampling cost (gamma^2) = 48.13646509622307 w/ remaining bias = 10.0%
### c. Execute the circuit of interest with antinoise
#### c.i. Prepare template circuit by using `samplex`
The `samplex` is an output of the `build` method of Samplomatic, which encodes all the information that is required to generate randomized parameters for `template_circuit`. These are then used to set up the `QuantumProgram` objects, which are in turn run on a QPU with the `Executor` primitive. Each `QuantumProgram` can contain several items, which you can think of as a pair of `template` and `samplex`.
See the [Hello samplomatic](https://github.com/qiskit-community/qdc-challenges-2025/blob/main/day3_tutorials/Track_A/hello_samplomatic/Samplomatic%20-%20Hello%20World.ipynb) tutorial for details.
# Build template circuit and samplex for later use with the "Executor"
template_circuit, samplex = samplomatic.build(boxed_circuit)
# Set up postselection if it's been enabled
    # Set up post selection PM (to add PS instructions)
    post_selection_pm = PassManager(
            AddSpectatorMeasures(backend.coupling_map),
            AddPostSelectionMeasures(x_pulse_type="rx"),
    final_template_circuit = post_selection_pm.run(template_circuit)
    final_template_circuit = template_circuit
#### c.ii. Set up the `QuantumProgram`
num_randomizations = 4096
shots_per_randomization = 64
chunk_size = 256
# Set up QuantumProgram
program = QuantumProgram(shots=shots_per_randomization, noise_maps=refs_2_plm)
# no EM
# Collect up a dict of the other arguments that need to be bound to samplex_inputs
samplex_inputs = {
    f"noise_scales.{ref}": float(0) for ref in local_scales.keys()
samplex_inputs |= {"basis_changes": {"basis0": bases_canon[0]}}
# Convert samplex_inputs into a dict to pass to QuantumProgram
samplex_arguments = (
    samplex.inputs().bind(**samplex_inputs).make_broadcastable()
program.append_samplex_item(
    circuit=final_template_circuit,
    samplex=samplex,
    samplex_arguments=samplex_arguments,
    shape=(num_randomizations,),
    chunk_size=chunk_size,
# plain PEC
# Collect a dict of the other arguments that need to be bound to samplex_inputs
samplex_inputs = {
    f"noise_scales.{ref}": float(-1) for ref in local_scales.keys()
    samplex=samplex,
# PEC+SLC
samplex_inputs = {
samplex_inputs |= {"local_scales": local_scales}
    samplex=samplex,
#### c.iii. Execute program with the `Executor` primitive
executor = Executor(backend)
job_exec = executor.run(program)
results_exec = job_exec.result()
### Step 4: Post-process
As we calculate the final expectation value of interest by using `executor_expectation_values`, we implement a few post-processing techniques to help ensure we obtain the highest-quality results possible. First, we apply our [twirled readout error extinction (TREX)](/docs/guides/error-mitigation-and-suppression-techniques#twirled-readout-error-extinction-trex), which accounts for any errors occurring during the readout process. Then, we fix errors due to non-Markovian noise on our Heron backends by using a post-selection method. This method measures active and spectator qubits, then applies a slow rotation to each qubit, and then measures again. In instances where the two measurements do not confirm a flipped qubit as expected, these shots are discarded by applying a `mask` from the `PostSelector`. Within the mask computation, a specific strategy can be set to filter based on single-qubit nodes or neighboring spectator edges, which can influence both the number of shots filtered out and the quality of the results.
measurement_noise_map = noise_learner_result[2].to_pauli_lindblad_map()
trex_scale_factors = trex_factors(measurement_noise_map, reverser_virt)
post_selection_strategy = "node"
def post_process_conv(datum, steps=16, gamma=None, ps=False, trex=False):
    meas = datum["meas"]
    flips = datum["measurement_flips.meas"]
    signs = datum.get("pauli_signs", None)
    meas_basis_axis = None
    avg_axis = 0
    mask = None
    if ps and post_selection_enabled:
        # Post-select the results
        post_selector = PostSelector.from_circuit(
            circuit=final_template_circuit, coupling_map=backend.coupling_map
        # Compute the ps mask for filtering results
        mask = post_selector.compute_mask(
            datum, strategy=post_selection_strategy
        # Compute fraction of shots kept from post selection
        total_num_shots = num_randomizations * shots_per_randomization
        ps_ratio = np.sum(mask) * 100 / total_num_shots / len(bases_canon)
            f"With {post_selection_strategy}-based post selection ({ps_ratio:.1f}% of shots kept):"
    results = []
    for i in range(steps, num_randomizations + 1, steps):
        # Compute mitigated expvals w/out post-selection
        res = executor_expectation_values(
            meas[:i],
            reverser_virt,
            meas_basis_axis,
            avg_axis=avg_axis,
            measurement_flips=flips[:i],
            pauli_signs=signs[:i] if signs is not None else None,
            postselect_mask=mask[:i] if mask is not None else None,
            rescale_factors=trex_scale_factors if trex else None,
            gamma_factor=gamma,
        results.append(res[0])
    return results
gamma_pec = gamma_from_noisy_boxes(refs_2_plm, id_map)
gamma_slc = gamma_from_noisy_boxes(refs_2_plm, id_map, local_scales)
steps = 16
results = {}
for label, result_idx, gamma, use_ps, use_trex in [
    ("PEC", 1, gamma_pec, True, True),
    ("PEC+SLC", 2, gamma_slc, True, True),
    ("Unmitigated", 0, None, False, False),
    res = post_process_conv(
        results_exec[result_idx],
        steps=steps,
        gamma=gamma,
        ps=use_ps,
        trex=use_trex,
    results[label] = res
With node-based post selection (24.1% of shots kept):
With node-based post selection (24.2% of shots kept):
From examination of the experimental results, we can directly compare the behavior of the different approaches: PEC, PEC combined with SLC, and the unmitigated baseline. Some specific details to highlight:
- The unmitigated result sits far outside the 10% bias band (near 0.35) and is unaffected by the number of randomizations.
- On this device, full PEC carries a sampling overhead of $\gamma^2 \approx 1.6\times10^2$. After large early swings, the plain-PEC estimate recovers the signal and settles around 1.1, slightly overshooting the exact value. Note that the 10% bias band applies only to the PEC+SLC estimator: plain PEC is in principle unbiased, so this residual deviation is not covered by a bias guarantee but instead reflects statistical fluctuations and imperfections in the learned noise model, which is reasonable at this problem size.
- SLC reduces the overhead a further \~3.4-fold (to $\gamma^2 \approx 48$, for a residual-bias bound of about 10%). PEC+SLC also fluctuates strongly at few randomizations, initially even reaching into the unphysical region, but its estimate converges steadily onto the exact value, settling near 1.0 well inside the band. It matches or exceeds the accuracy of plain PEC at roughly a third of the sampling cost, demonstrating the benefit of lightcone shading.
- The error bars of both mitigated estimates contract as randomizations accumulate; at a fixed number of randomizations, the PEC+SLC estimator has the smaller statistical variance, consistent with its smaller $\gamma^2$.
Note that the learned noise rates (and therefore the overheads and mitigated estimates) depend on the backend and its calibration at the time of execution, so rerunning this notebook can produce quantitatively different values.
fig, ax = plt.subplots(1, 1, figsize=(12, 6))
ax.axhline(1.0, color="black", label="Exact")
ax.fill_between(
    [-50, 4100], -10, 0, color="grey", alpha=0.25, label="Unphysical"
ax.fill_between([-50, 4100], 1, 10, color="grey", alpha=0.25)
ax.fill_between(
    [-50, 4100], 0.9, 1.1, color="red", alpha=0.25, label="10% bias"
for label, res in results.items():
    ax.errorbar(
        list(range(steps, num_randomizations + 1, steps)),
        [r[0] for r in res],
        yerr=[r[1] for r in res],
        alpha=0.75,
        marker="o",
        linestyle="",
        markerfacecolor="none",
        label=label,
ax.set_ylabel(r"$\langle X_{6}Z_{13}\rangle$")
ax.grid()
ax.legend(ncols=2)
ax.set_ylim([-0.1, 2.0])
ax.set_xlim([-50, 4100])
(-50.0, 4100.0)
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/pec-with-shaded-lightcones/extracted-outputs/8df6612b-d611-4201-b1f4-6d8de4a192ad-1.avif)
## Next steps
> **Recommendations**
> - [Combine error mitigation options with the Estimator primitive](/docs/tutorials/combine-error-mitigation-techniques)
> - [Utility-scale error mitigation with probabilistic error amplification](/docs/tutorials/probabilistic-error-amplification)
> - The [`qiskit-addon-slc`](https://github.com/Qiskit/qiskit-addon-slc) and [`samplomatic`](https://github.com/Qiskit/samplomatic) documentation
> - [Lightcone shading for classically accelerated quantum error mitigation](https://arxiv.org/abs/2409.04401)
