title: Warm-start QAOA with the Optimization Mapper Qiskit addon
description: Improve QAOA convergence on max-cut problems by initializing with the solution of a continuous relaxation, using the qiskit-addon-opt-mapper package.
source: https://eu-de.quantum.cloud.ibm.com/docs/en/tutorials/warm-start-qaoa
# Warm-start QAOA with the Optimization Mapper Qiskit addon
*Usage estimate: 9 minutes on a Heron r3 (NOTE: This is an estimate only. Your runtime may vary.)*
## Learning outcomes
- How to map a max-cut problem to a quantum Quadratic Unconstrained Binary Optimization (QUBO) formulation using `qiskit-addon-opt-mapper`
- How to implement and run standard QAOA on a simulator
- How to apply WS-QAOA by computing the quadratic program (QP) relaxation and building the warm-start circuit
- How to compare energy convergence and solution quality between standard QAOA and WS-QAOA
## Prerequisites
- [QAOA tutorial](/docs/tutorials/quantum-approximate-optimization-algorithm)
- [Advanced QAOA tutorial](/docs/tutorials/advanced-techniques-for-qaoa)
## Background
The Quantum Approximate Optimization Algorithm (QAOA) is a hybrid quantum-classical algorithm designed to solve combinatorial optimization problems such as max-cut and general QUBO formulations. For a foundational introduction to QAOA in Qiskit, see the [QAOA tutorial](/docs/tutorials/quantum-approximate-optimization-algorithm); for more advanced circuit-building techniques, see the [advanced QAOA tutorial](/docs/tutorials/advanced-techniques-for-qaoa).
In standard QAOA:
- The initial state is the uniform superposition $|+\rangle^{\otimes n}$.
- Variational parameters are randomly initialized.
- A classical optimizer searches for parameters that minimize the cost function.
However, for practical problem sizes and noisy quantum hardware, random initialization can lead to slow convergence, poor local minima, and increased optimization cost.
**Warm-start QAOA** (WS-QAOA) improves this by incorporating classical optimization insights directly into the quantum circuit. This tutorial follows the methods introduced by Egger, Mareček, and Woerner in [*Warm-starting quantum optimization*](https://arxiv.org/abs/2009.10095). The key idea is to:
1. **Solve a continuous relaxation** of the original binary problem (a quadratic program over $[0,1]^n$ instead of $\{0,1\}^n$).
2. **Encode the relaxed solution** $c^*_i \in [0,1]$ into a custom initial state by using $Y$-rotation angles $\theta_i = 2\arcsin(\sqrt{c^*_i})$, so that qubit $i$ starts in a state whose probability of measuring $|1\rangle$ is $c^*_i$.
3. **Replace the standard $X$-mixer** with a custom mixer whose ground state is the warm-start initial state, ensuring the algorithm starts near the classical solution and can explore the neighborhood.
A regularization parameter $\varepsilon \in [0, 0.5]$ clips $c^*_i$ away from 0 and 1 to avoid reachability issues; qubits initialized in $|0\rangle$ or $|1\rangle$ cannot be moved by the cost Hamiltonian. At $\varepsilon = 0.5$, WS-QAOA reduces exactly to standard QAOA.
Problem modeling uses the [`qiskit-addon-opt-mapper`](https://qiskit.github.io/qiskit-addon-opt-mapper/) package, whose [`Maxcut`](https://qiskit.github.io/qiskit-addon-opt-mapper/stubs/qiskit_addon_opt_mapper.applications.Maxcut.html) application class builds the QUBO directly from a graph, and whose converters and translators map the resulting problem to quantum Hamiltonians.
## Requirements
- Qiskit Runtime v0.43 or later (`pip install qiskit-ibm-runtime`)
- Optimization Mapper Qiskit addon (`pip install qiskit-addon-opt-mapper`)
- SciPy (`pip install scipy`)
- NetworkX (`pip install networkx`)
## Setup
Import all required libraries and define helper functions used throughout this tutorial.
import networkx as nx
from qiskit.circuit.library import qaoa_ansatz
from qiskit.quantum_info import Statevector
from qiskit.primitives import StatevectorEstimator, StatevectorSampler
    QiskitRuntimeService,
    Session,
    EstimatorOptions,
    EstimatorV2 as Estimator,
    SamplerV2 as Sampler,
from qiskit_addon_opt_mapper.translators import to_ising
# Small-scale simulator example
We use a small **max-cut** problem on a weighted graph as our running example. Max-cut asks: given a graph $G=(V,E)$ with edge weights $w_{ij}$, find a partition of the vertices into two sets $S$ and $\bar{S}$ that maximizes the total weight of edges crossing the cut.
As a QUBO minimization problem, max-cut can be written as:
$\min_{x \in \{0,1\}^n} -\sum_{(i,j) \in E} w_{ij}(x_i + x_j - 2x_i x_j)$
We work with a four-node graph for tractability on a simulator.
We define the max-cut problem using the `Maxcut` application class from `qiskit-addon-opt-mapper`, which builds the QUBO formulation directly from a graph. We then convert it to a QUBO and translate it to an Ising Hamiltonian (`SparsePauliOp`) suitable for QAOA. We also solve the continuous relaxation of the QUBO — replacing the binary constraint $x_i \in \{0,1\}$ with $x_i \in [0,1]$ — to obtain the warm-start initial point $c^*$.
# Define a 4-node weighted graph for the max-cut problem
n_nodes = 4
edges = [(0, 1, 1.0), (0, 2, 1.0), (1, 2, 1.0), (1, 3, 1.0), (2, 3, 1.0)]
G = nx.Graph()
G.add_nodes_from(range(n_nodes))
G.add_weighted_edges_from(edges)
pos = nx.spring_layout(G, seed=42)
edge_labels = {(u, v): d["weight"] for u, v, d in G.edges(data=True)}
fig, ax = plt.subplots(figsize=(4, 3))
nx.draw(G, pos, with_labels=True, node_color="lightblue", ax=ax)
nx.draw_networkx_edge_labels(G, pos, edge_labels=edge_labels, ax=ax)
ax.set_title("Max-Cut graph")
plt.tight_layout()
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/warm-start-qaoa/extracted-outputs/step1-graph-code-0.avif)
The graph has five edges. The optimal max-cut partitions the nodes into $S = \{0, 3\}$ and $\bar{S} = \{1, 2\}$ (or its complement), severing four of the five edges for a cut value of 4.
# Build the max-cut problem directly from the NetworkX graph using the
# Maxcut application class. Internally it constructs the QUBO
#   minimize  -sum_{(i,j) in E} w_ij * (x_i + x_j - 2*x_i*x_j)
# (each edge contributes -w to the linear terms and +2w to the quadratic
# term), so we get the same OptimizationProblem without the boilerplate.
maxcut = Maxcut(G)
prob = maxcut.to_optimization_problem()
print(prob.prettyprint())
Problem name: Max-cut
Maximize
  -2*x_0*x_1 - 2*x_0*x_2 - 2*x_1*x_2 - 2*x_1*x_3 - 2*x_2*x_3 + 2*x_0 + 3*x_1
  + 3*x_2 + 2*x_3
Subject to
  No constraints
  Binary variables (4)
    x_0 x_1 x_2 x_3
The `Maxcut` class wraps the QUBO construction so we don't have to expand the max-cut objective by hand. The printed objective shows each variable's linear coefficient (how much it individually contributes to the cut) and each cross-term's quadratic coefficient (the penalty for putting two adjacent nodes on the same side). The underlying `OptimizationProblem` returned by `to_optimization_problem()` supports binary, integer, continuous, and spin variables, and is the same object expected by the converters and translators used in the next step.
# Convert the OptimizationProblem to a QUBO, then translate to an Ising Hamiltonian
# The substitution x_i = (1 - z_i)/2  maps binary variables to spin operators,
# yielding a Hamiltonian H_C = sum_i h_i Z_i + sum_{i<j} J_ij Z_i Z_j + constant.
# QAOA minimizes <H_C> to find the ground state, which encodes the optimal cut.
converter = OptimizationProblemToQubo()
qubo = converter.convert(prob)
cost_operator, offset = to_ising(qubo)
n_qubits = cost_operator.num_qubits
print(f"Cost Hamiltonian H_C ({n_qubits} qubits):")
print(cost_operator)
print(f"\nOffset (constant shift): {offset}")
print("  QUBO value = Ising energy + offset")
Cost Hamiltonian H_C (4 qubits):
SparsePauliOp(['IIZZ', 'IZIZ', 'IZZI', 'ZIZI', 'ZZII'],
              coeffs=[0.5+0.j, 0.5+0.j, 0.5+0.j, 0.5+0.j, 0.5+0.j])
Offset (constant shift): -2.5
The `to_ising` translator returns a `SparsePauliOp` representing $H_C$ and a scalar `offset` such that $\text{QUBO value} = \langle H_C \rangle + \text{offset}$. For this max-cut problem with all unit weights, $h_i = 0$ for all qubits (the graph is symmetric in linear terms after the $x_i \to z_i$ substitution), and each edge contributes a $Z_i Z_j$ coupling of strength $+0.5$. The minimum eigenvalue of $H_C$ corresponds to the maximum cut.
# Solve the continuous (QP) relaxation to obtain the warm-start point c*
# The QP relaxation replaces the binary constraint x_i in {0,1} with x_i in [0,1]
# and minimizes the same quadratic objective. Its solution c*_i gives the
# probability that variable i should be 1 according to the classical relaxation.
# The max-cut QUBO has a non-convex quadratic matrix (negative eigenvalues),
# so the relaxed problem has multiple local minima. A naive single start from
# [0.5,...,0.5] converges to the symmetric saddle point c* = [0.5,...,0.5],
# which carries no useful structural information about the problem.
# Multi-start optimization is used to reliably find the global minimum.
Q = qubo.objective.quadratic.to_array(symmetric=True)
mu = qubo.objective.linear.to_array()
def qp_objective(x_cont):
    """Continuous relaxation of the QUBO objective."""
    return x_cont @ Q @ x_cont + mu @ x_cont + qubo.objective.constant
bounds = [(0.0, 1.0)] * n_qubits
rng = np.random.default_rng(42)
best_val = np.inf
c_star = None
for _ in range(200):
    x0 = rng.uniform(0.0, 1.0, n_qubits)
    result = minimize(qp_objective, x0, method="L-BFGS-B", bounds=bounds)
    if result.fun < best_val:
        best_val = result.fun
        c_star = result.x
print(f"QP relaxation solution c* = {np.round(c_star, 4)}")
print(f"QP objective value        = {best_val:.4f}")
QP relaxation solution c* = [1. 0. 0. 1.]
QP objective value        = -4.0000
The multi-start solver finds $c^* = [1, 0, 0, 1]$ (or its complement $[0, 1, 1, 0]$), which is the actual optimal binary solution. For this problem the QP relaxation is tight, the continuous minimum coincides with the integer optimum, meaning the relaxation immediately identifies the best cut. After regularization with $\varepsilon = 0.25$ in Step 2, this solution will be encoded into the warm-start initial state.
We build two QAOA circuits and prepare the warm-start angles from the QP solution.
**Standard QAOA** uses the uniform superposition $|+\rangle^{\otimes n}$ as the initial state and the standard $X$-mixer $H_M = -\sum_i X_i$, implemented as $\prod_i R_X(-2\beta)$ per layer.
**Warm-start QAOA (WS-QAOA)** from [\[1\]](#Reference1) makes two structural changes per qubit $i$:
- **Initial state:** $R_Y(\theta_i)|0\rangle$ with $\theta_i = 2\arcsin(\sqrt{c^*_i})$, so the probability of measuring $|1\rangle$ equals $c^*_i$.
- **Custom mixer:** $R_Y(\theta_i)\, R_Z(-2\beta)\, R_Y(-\theta_i)$, which has $R_Y(\theta_i)|0\rangle$ as its ground state. This means WS-QAOA starts in the ground state of its own mixer, the same property that standard QAOA satisfies with $|+\rangle$ and the $X$-mixer.
Note on layers: At `p=1`(a single QAOA layer), standard QAOA is analytically limited to \~49% of the optimal energy on graphs containing triangles (this graph has the triangle 0-1-2). The warm start bypasses this limitation by encoding prior knowledge of the solution directly into the initial state.
# Number of QAOA layers (each layer = one cost unitary + one mixer unitary)
p = 1
# Regularization: clip c* to [epsilon, 1-epsilon] so no qubit is initialized
# in |0> or |1>, which would freeze it under the cost Hamiltonian.
epsilon = 0.25
c_clipped = np.clip(c_star, epsilon, 1 - epsilon)
thetas = 2 * np.arcsin(np.sqrt(c_clipped))
print(f"Continuous relaxation c*  = {np.round(c_star, 4)}")
print(f"After regularization      = {np.round(c_clipped, 4)}")
print(f"Warm-start angles theta   = {np.round(thetas, 4)} radians")
print()
print("Angle interpretation:")
print("  theta = 0      <->  c* = 0   (qubit points toward |0>)")
    "  theta = pi/2   <->  c* = 0.5 (qubit in equal superposition, like |+>)"
print("  theta = pi     <->  c* = 1   (qubit points toward |1>)")
Continuous relaxation c*  = [1. 0. 0. 1.]
After regularization      = [0.75 0.25 0.25 0.75]
Warm-start angles theta   = [2.0944 1.0472 1.0472 2.0944] radians
After clipping, $c^* = 1$ becomes $1 - \varepsilon = 0.75$ and $c^* = 0$ becomes $\varepsilon = 0.25$. The resulting angles $\theta \approx [2.09, 1.05, 1.05, 2.09]$ radians rotate qubits 0 and 3 strongly toward $|1\rangle$ and qubits 1 and 2 toward $|0\rangle$, directly encoding the structure of the optimal cut into the initial quantum state.
def apply_cost_unitary(qc, cost_op, gamma):
    """Apply exp(-i * gamma * H_C) to the circuit.
    Each Pauli term in H_C contributes a rotation gate:
      - Single-Z term h_i * Z_i  ->  RZ(2 * gamma * h_i) on qubit i
      - Two-Z term J_ij * Z_i Z_j  ->  CNOT, RZ(2 * gamma * J_ij), CNOT
    for pauli_term, coeff in zip(cost_op.paulis, cost_op.coeffs):
        indices = [
            j for j, q in enumerate(pauli_term.to_label()[::-1]) if q == "Z"
        if len(indices) == 1:
            qc.rz(2 * gamma * coeff.real, indices[0])
        elif len(indices) == 2:
            qc.cx(indices[0], indices[1])
            qc.rz(2 * gamma * coeff.real, indices[1])
def build_ws_qaoa(cost_op, n_layers, n_qubits, thetas):
    """WS-QAOA: warm-start initial state + custom per-qubit mixer.
    Per Egger et al. (2021) Eq. (1)-(2):
      Initial state per qubit i:  R_Y(theta_i) |0>
      Mixer gate per qubit i:     R_Y(theta_i) R_Z(-2*beta) R_Y(-theta_i)
    gammas = ParameterVector("γ", n_layers)
    betas = ParameterVector("β", n_layers)
    qc = QuantumCircuit(n_qubits)
    for i, theta in enumerate(thetas):
        qc.ry(theta, i)  # warm-start initial state
    for k in range(n_layers):
        apply_cost_unitary(qc, cost_op, gammas[k])
            qc.ry(theta, i)
            qc.rz(-2 * betas[k], i)
            qc.ry(-theta, i)
    return qc, gammas, betas
# Standard QAOA via the Qiskit built-in helper:
# qaoa_ansatz prepares |+>^n, then alternates exp(-i*gamma*H_C) with the
# default X-mixer for `reps` layers. The returned circuit exposes the
# variational parameters via std_qc.parameters.
std_qc = qaoa_ansatz(cost_operator, reps=p)
# WS-QAOA: keep the custom builder. The per-qubit mixer
# R_Y(theta_i) R_Z(-2*beta) R_Y(-theta_i) is implemented as an explicit gate
# sequence rather than as a SparsePauliOp, so we construct the circuit
# directly to stay close to the Egger et al. (2021) formulation.
ws_qc, ws_gammas, ws_betas = build_ws_qaoa(cost_operator, p, n_qubits, thetas)
For the standard ansatz we delegate to [`qaoa_ansatz`](/docs/api/qiskit/qiskit.circuit.library.qaoa_ansatz), which constructs $|+\rangle^{\otimes n}$, applies the cost unitary, and applies the default $X$-mixer for each of `reps` layers. For WS-QAOA we keep the explicit `build_ws_qaoa` helper because the per-qubit mixer $R_Y(\theta)\,R_Z(-2\beta)\,R_Y(-\theta)$ is expressed as a gate sequence rather than as a sum of Paulis. The `apply_cost_unitary` helper reads directly from the `SparsePauliOp` Hamiltonian, so it handles any QUBO problem without manual circuit construction.
print("Standard QAOA circuit (p=1):")
std_qc.draw("mpl", fold=-1)
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/warm-start-qaoa/extracted-outputs/step2-draw-code-1.avif)
print("\nWS-QAOA circuit (p=1):")
ws_qc.draw("mpl", fold=-1)
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/warm-start-qaoa/extracted-outputs/6fad9eda-1.avif)
Both circuits follow the same structure: an initial state preparation layer, then $p$ alternating cost-unitary and mixer-unitary layers. In the WS-QAOA circuit, the opening $R_Y$ gates encode $c^*$, and the mixer replaces each $R_X$ with a conjugated $R_Y$–$R_Z$–$R_Y$ triplet. The circuit depth difference between the two grows linearly with $p$, but remains manageable at low depth.
We use `StatevectorEstimator` for exact, noiseless simulation. The `minimize` function from SciPy with the COBYLA optimizer drives the variational loop, calling the estimator at each iteration to evaluate $\langle H_C \rangle$ for a given parameter set $(\gamma, \beta)$.
The two algorithms use different initial parameters that reflect what each knows before optimization:
- **Standard QAOA:** Random initialization in $[0, \pi]$ — appropriate since no structural information is available.
- **WS-QAOA:** $\gamma = 0$, $\beta = \pi/4$ — at $\gamma=0$ the cost unitary is the identity, so the very first circuit evaluation samples directly from the warm-start initial state. This gives COBYLA a strong starting signal aligned with the classical solution.
estimator = StatevectorEstimator()
def make_cost_fn(circuit, param_order, cost_op, estimator, history):
    """Return a scalar cost function compatible with scipy.optimize.minimize."""
    def cost_fn(params):
        bound = circuit.assign_parameters(dict(zip(param_order, params)))
        job = estimator.run([(bound, cost_op)])
        energy = job.result()[0].data.evs.real
        history.append(energy)
        return energy
    return cost_fn
# Standard QAOA: random initialization
np.random.seed(42)
std_param_order = list(std_qc.parameters)
std_params0 = np.random.uniform(0, np.pi, len(std_param_order))
std_history = []
std_result = minimize(
    make_cost_fn(
        std_qc, std_param_order, cost_operator, estimator, std_history
    std_params0,
    method="COBYLA",
    options={"maxiter": 300, "rhobeg": 0.5},
print(f"Standard QAOA optimal energy : {std_result.fun:.4f}")
print(f"  optimal params: {std_result.x.round(4)}")
print(f"  optimizer calls: {len(std_history)}")
# WS-QAOA: informed initialization
ws_params0 = np.concatenate([np.zeros(p), np.full(p, np.pi / 4)])
ws_history = []
ws_param_order = list(ws_gammas) + list(ws_betas)
ws_result = minimize(
    make_cost_fn(ws_qc, ws_param_order, cost_operator, estimator, ws_history),
    ws_params0,
    method="COBYLA",
print(f"\nWS-QAOA optimal energy       : {ws_result.fun:.4f}")
    f"  optimal params: gamma={ws_result.x[:p].round(4)}, beta={ws_result.x[p:].round(4)}"
print(f"  optimizer calls: {len(ws_history)}")
Standard QAOA optimal energy : -0.5859
  optimal params: [0.6803 2.0533]
  optimizer calls: 47
WS-QAOA optimal energy       : -1.5000
  optimal params: gamma=[-0.0001], beta=[1.5708]
  optimizer calls: 42
WS-QAOA's informed starting point means COBYLA begins with a meaningful energy value near the warm-start solution, while standard QAOA starts from an essentially random point on the energy landscape. This difference in starting quality is the main driver of the convergence gap visible in Step 4.
# Compute the exact optimal energy by brute-force over all 2^n bitstrings
all_energies = [
    Statevector.from_label(format(k, f"0{n_qubits}b"))
    .expectation_value(cost_operator)
    .real
    for k in range(2**n_qubits)
optimal_energy = min(all_energies)
print(f"Exact optimal energy         : {optimal_energy:.4f}")
print(f"Standard QAOA approx. ratio  : {std_result.fun / optimal_energy:.4f}")
print(f"WS-QAOA approx. ratio        : {ws_result.fun / optimal_energy:.4f}")
Exact optimal energy         : -1.5000
Standard QAOA approx. ratio  : 0.3906
WS-QAOA approx. ratio        : 1.0000
The approximation ratio is defined as $\langle H_C \rangle_{\text{QAOA}} / E_{\text{opt}}$. For minimization problems where $E_{\text{opt}} < 0$, a ratio closer to 1 means the algorithm found a lower energy (a better solution). The brute-force search over all $2^n$ basis states is only feasible for small $n$ and serves as a ground-truth reference.
We visualize convergence, sample the optimized circuits for bitstring solutions, decode those bitstrings back to max-cut partitions, and summarize the final results.
fig, ax = plt.subplots(figsize=(7, 4))
ax.plot(std_history, label="Standard QAOA", alpha=0.85)
ax.plot(ws_history, label="WS-QAOA", alpha=0.85)
ax.axhline(
    optimal_energy,
    color="k",
    linestyle="--",
    label=f"Exact optimal ({optimal_energy:.2f})",
ax.set_xlabel("Optimizer call")
ax.set_ylabel(r"$\langle H_C \rangle$")
ax.set_title("Convergence: Standard QAOA vs. WS-QAOA")
ax.legend()
plt.tight_layout()
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/warm-start-qaoa/extracted-outputs/step4-convergence-code-0.avif)
The convergence plot shows the energy $\langle H_C \rangle$ at each COBYLA function evaluation. Standard QAOA at $p=1$ is limited to \~49% of the optimal energy on this graph (the theoretical maximum for $p=1$ QAOA on graphs with triangles), settling around $-0.74$. WS-QAOA, initialized close to the optimal solution, converges quickly to near $-1.50$ (the exact optimum) with far fewer iterations. This demonstrates the key advantage of the warm start: at the same circuit depth, it reaches a significantly better solution.
# Sample the optimized circuits to recover the most probable bitstring solutions
sampler = StatevectorSampler()
shots = 1024
def get_best_bitstring(circuit, param_order, optimal_params, sampler, shots):
    bound = circuit.assign_parameters(dict(zip(param_order, optimal_params)))
    bound.measure_all()
    job = sampler.run([bound], shots=shots)
    counts = job.result()[0].data.meas.get_counts()
    return max(counts, key=counts.get), counts
def evaluate_cut(bitstring, G):
    """Compute the Max-Cut value for a bitstring node assignment."""
    x = [int(b) for b in bitstring]
    cut_val = sum(
        w for u, v, w in G.edges.data("weight", default=1) if x[u] != x[v]
    set0 = [i for i, b in enumerate(bitstring) if b == "0"]
    set1 = [i for i, b in enumerate(bitstring) if b == "1"]
    return cut_val, set0, set1
# Qiskit bitstring ordering: rightmost character = qubit 0
def decode_bitstring(bs):
    return bs[::-1]
std_best, std_counts = get_best_bitstring(
    std_qc, std_param_order, std_result.x, sampler, shots
ws_best, ws_counts = get_best_bitstring(
    ws_qc, ws_param_order, ws_result.x, sampler, shots
std_cut, std_s0, std_s1 = evaluate_cut(decode_bitstring(std_best), G)
ws_cut, ws_s0, ws_s1 = evaluate_cut(decode_bitstring(ws_best), G)
print(f"Standard QAOA most-probable bitstring : {std_best}")
print(f"  Partition: S={std_s0}, S̄={std_s1}  |  cut value = {std_cut}")
print()
print(f"WS-QAOA most-probable bitstring       : {ws_best}")
print(f"  Partition: S={ws_s0}, S̄={ws_s1}  |  cut value = {ws_cut}")
Standard QAOA most-probable bitstring : 0110
  Partition: S=[0, 3], S̄=[1, 2]  |  cut value = 4.0
WS-QAOA most-probable bitstring       : 0110
Bitstrings from `Sampler` are returned with qubit 0 at the rightmost position, so reversing the string maps index $i$ to variable $x_i$. The cut value is the total weight of edges that cross the partition, which is what the max-cut problem aims to maximize. A cut value of 4 uses four of the five available edges, which is the theoretical maximum for this graph.
# Visualize the WS-QAOA solution on the graph
fig, axes = plt.subplots(1, 2, figsize=(8, 3))
for ax, s0, s1, cut, title in [
    (axes[0], std_s0, std_s1, std_cut, f"Standard QAOA (cut = {std_cut})"),
    (axes[1], ws_s0, ws_s1, ws_cut, f"WS-QAOA (cut = {ws_cut})"),
    colors = ["skyblue" if i in s0 else "salmon" for i in G.nodes()]
    nx.draw(G, pos, with_labels=True, node_color=colors, ax=ax)
    ax.set_title(title)
plt.tight_layout()
# Summary
# to_ising offset: QUBO value = Ising energy + offset, so Max-Cut value = -(Ising energy + offset)
optimal_cut = -(optimal_energy + offset)
print("=== Summary ===")
    f"{'Method':<20} {'Ising energy':>14} {'Cut value':>12} {'Approx. ratio':>15}"
print("-" * 65)
    f"{'Standard QAOA':<20} {std_result.fun:>14.4f} {std_cut:>12} {std_result.fun/optimal_energy:>15.4f}"
    f"{'WS-QAOA':<20} {ws_result.fun:>14.4f} {ws_cut:>12} {ws_result.fun/optimal_energy:>15.4f}"
    f"{'Exact optimal':<20} {optimal_energy:>14.4f} {optimal_cut:>12.0f} {'1.0000':>15}"
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/warm-start-qaoa/extracted-outputs/step4-visualize-code-0.avif)
=== Summary ===
Method                 Ising energy    Cut value   Approx. ratio
Standard QAOA               -0.5859          4.0          0.3906
WS-QAOA                     -1.5000          4.0          1.0000
Exact optimal               -1.5000            4          1.0000
The graph visualization colors each node by its partition assignment (blue = $S$, orange = $\bar{S}$). Edges that cross the partition (connecting differently-colored nodes) are the ones counted in the cut.
Both methods find a bitstring with cut value 4, but for very different reasons. It is important to note that the **convergence plot and the sampled bitstring measure two different things**:
- The **convergence plot** tracks the average energy $\langle H_C \rangle$ of the full quantum state, a weighted average over all bitstrings in the superposition. Standard QAOA converges to \~$-0.62$, well above the optimal $-1.50$, meaning its quantum state is spread across many suboptimal bitstrings and only occasionally includes the correct answer.
- The **sampled bitstring** is a single draw from that state. Standard QAOA got lucky here; the optimal partition happened to be the most frequently sampled outcome even from a diffuse state. On harder problems, noisier hardware, or with more candidate solutions competing, this luck runs out.
WS-QAOA, by contrast, converges its average energy all the way to $-1.50$, meaning its quantum state is concentrated on the optimal bitstrings. Nearly every shot returns the correct answer, so the solution is found reliably rather than by chance.
The practical consequence: on this small noiseless simulator the difference may seem minor, but at larger problem sizes or on real hardware, a state with average energy close to optimal is far more robust than one that only occasionally samples the right answer from a diffuse distribution.
# Compare the full probability distribution over cut values for both
# algorithms. The most-probable bitstring above only reveals the mode;
# this histogram exposes how much of the quantum state's probability mass
# lands on the optimal cut versus on suboptimal partitions.
def cut_value_distribution(counts, G, shots):
    dist = {}
    for bs, c in counts.items():
        cut, _, _ = evaluate_cut(decode_bitstring(bs), G)
        dist[cut] = dist.get(cut, 0.0) + c / shots
    return dist
std_cut_dist = cut_value_distribution(std_counts, G, shots)
ws_cut_dist = cut_value_distribution(ws_counts, G, shots)
cut_values = sorted(set(std_cut_dist) | set(ws_cut_dist))
std_probs = [std_cut_dist.get(c, 0.0) for c in cut_values]
ws_probs = [ws_cut_dist.get(c, 0.0) for c in cut_values]
x = np.arange(len(cut_values))
width = 0.4
ax.bar(
    x - width / 2, std_probs, width, label="Standard QAOA", color="steelblue"
ax.bar(x + width / 2, ws_probs, width, label="WS-QAOA", color="salmon")
ax.axvline(
    cut_values.index(optimal_cut),
    color="k",
    linestyle="--",
    alpha=0.4,
    label=f"Optimal cut = {optimal_cut:g}",
ax.set_xticks(x)
ax.set_xticklabels([f"{c:g}" for c in cut_values])
ax.set_xlabel("Cut value")
ax.set_ylabel("Probability")
ax.set_title(f"Probability of measuring each cut value ({shots} shots)")
ax.legend()
plt.tight_layout()
    f"P(cut = {optimal_cut:g}) | Standard QAOA = "
    f"{std_cut_dist.get(optimal_cut, 0):.4f}  "
    f"WS-QAOA = {ws_cut_dist.get(optimal_cut, 0):.4f}"
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/warm-start-qaoa/extracted-outputs/b01696c2-0.avif)
P(cut = 4) | Standard QAOA = 0.4639  WS-QAOA = 1.0000
This histogram quantifies what the convergence plot only suggested. Standard QAOA's probability is spread across multiple suboptimal cut values, so the chance of sampling an optimal cut of four in any single shot is only a fraction of the total mass. WS-QAOA concentrates nearly all of its probability on the optimal cut, so almost every shot returns the right answer. This is the practical signature of a state whose average energy has converged to the ground-state energy versus one that has merely happened to include the ground state in a broad superposition.
# Large Scale Hardware Example
### Steps 1-4 compress into single code block
# Selecting a backend using real hardware
backend = service.least_busy(
Using backend: ibm_boston
# ── Step 1a: Build the 40-node Max-Cut problem ─────────────────────────────
# A 3-regular graph (every node has exactly 3 neighbors) is a standard QAOA
N_LARGE = 40
G_large = nx.random_regular_graph(d=3, n=N_LARGE, seed=0)
edges_large = list(G_large.edges())
print(f"Graph: {N_LARGE} nodes, {len(edges_large)} edges (3-regular)")
# Visualize the graph so it is clear what problem we are solving before any
# quantum work. Nodes in a circular layout; each edge contributes +1 to the
# cut value when its endpoints land in different partitions.
pos_large = nx.circular_layout(G_large)
fig, ax = plt.subplots(figsize=(6, 6))
nx.draw(
    G_large,
    pos_large,
    with_labels=True,
    node_size=400,
    font_size=7,
    ax=ax,
ax.set_title(f"40-node 3-regular Max-Cut graph ({len(edges_large)} edges)")
plt.tight_layout()
# Same Maxcut → OptimizationProblem → QUBO → Ising pipeline as the small example,
# applied to the 40-node graph.
prob_large = Maxcut(G_large).to_optimization_problem()
converter_large = OptimizationProblemToQubo()
qubo_large = converter_large.convert(prob_large)
cost_op_large, offset_large = to_ising(qubo_large)
n_qubits_large = cost_op_large.num_qubits
    f"Cost operator: {n_qubits_large} qubits, {len(cost_op_large)} Pauli terms"
# ── Step 1b: QP relaxation (multi-start L-BFGS-B) ─────────────────────────
# Same multi-start approach as the small example. At 40 qubits the relaxed
# landscape has many more local minima, so 200 random starts are essential
# to find a low-energy warm-start point.
Q_large = qubo_large.objective.quadratic.to_array(symmetric=True)
mu_large = qubo_large.objective.linear.to_array()
def qp_obj_large(x):
    return x @ Q_large @ x + mu_large @ x + qubo_large.objective.constant
bounds_large = [(0.0, 1.0)] * n_qubits_large
rng_qp = np.random.default_rng(42)
best_val_large, c_star_large = np.inf, None
    x0 = rng_qp.uniform(0.0, 1.0, n_qubits_large)
    res = minimize(qp_obj_large, x0, method="L-BFGS-B", bounds=bounds_large)
    if res.fun < best_val_large:
        best_val_large, c_star_large = res.fun, res.x
# Regularize and convert to rotation angles (same formula as small example)
epsilon_large = 0.25
c_clipped_large = np.clip(c_star_large, epsilon_large, 1 - epsilon_large)
thetas_large = 2 * np.arcsin(np.sqrt(c_clipped_large))
    f"c* range: [{c_star_large.min():.3f}, {c_star_large.max():.3f}]  "
    f"theta range: [{thetas_large.min():.3f}, {thetas_large.max():.3f}] rad"
# Plot the distribution of c* values to see how much structure the relaxation
# extracted. Values near 0/1 mean confident assignments; values near 0.5 mean
# the classical solver was uncertain and quantum exploration is most needed there.
fig, ax = plt.subplots(figsize=(6, 3))
ax.hist(c_star_large, bins=20, color="steelblue", edgecolor="white")
ax.axvline(0.5, color="k", linestyle="--", label="Uniform prior (std QAOA)")
ax.set_xlabel(r"$c^*_i$")
ax.set_ylabel("Count")
ax.set_title(r"Distribution of warm-start values $c^*_i$ (40-node graph)")
ax.legend()
plt.tight_layout()
# ── Step 1c: Build WS-QAOA circuit ─────────────────────────────────────────
# Reuse build_ws_qaoa from the small-scale section unchanged; the helper
# scales automatically with n_qubits and the cost operator size.
p_large = 1
ws_qc_large, ws_gammas_large, ws_betas_large = build_ws_qaoa(
    cost_op_large, p_large, n_qubits_large, thetas_large
ws_qc_large.measure_all()
# ── Step 2: Transpile to hardware-native gates ──────────────────────────
# generate_preset_pass_manager compiles the abstract circuit to th
# gate set of the backend and inserts SWAP gates wherever the cost Hamiltonian
# couples qubits that are not directly connected on the processor.
ws_isa_large = pm.run(ws_qc_large)
ecr_count = ws_isa_large.count_ops().get("ecr", 0)
    f"\nTranspiled circuit: 2Q depth={ws_isa_large.depth(lambda x: x.operation.num_qubits == 2)}"
ws_isa_large.draw("mpl", fold=-1)
Graph: 40 nodes, 60 edges (3-regular)
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/warm-start-qaoa/extracted-outputs/a35f3b21-1.avif)
Cost operator: 40 qubits, 60 Pauli terms
c* range: [0.000, 1.000]  theta range: [1.047, 2.094] rad
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/warm-start-qaoa/extracted-outputs/a35f3b21-3.avif)
Transpiled circuit: 2Q depth=86
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/warm-start-qaoa/extracted-outputs/a35f3b21-5.avif)
# ── Classical baseline via simulated annealing ────────────────────
# Run SA before any hardware calls to get a strong classical reference cut
# value. SA is fast (seconds), needs no solver license, and reliably finds
# near-optimal solutions on 40-node graphs. We use sa_cut as the denominator
# for the approximation ratio instead of the looser QP upper bound.
# At each step we flip a random node and accept the move if it improves the
# cut, or with probability exp(delta/T) otherwise. Temperature T decays
# geometrically, allowing uphill moves early on to escape local minima.
def simulated_annealing_maxcut(
    G, seed=0, T0=2.0, T_min=1e-4, alpha=0.995, n_steps=100_000
    rng_sa = np.random.default_rng(seed)
    n = G.number_of_nodes()
    x = rng_sa.integers(0, 2, n)
    best_x = x.copy()
    best_cut = sum(1 for u, v in G.edges() if x[u] != x[v])
    T = T0
    for _ in range(n_steps):
        i = rng_sa.integers(0, n)
        delta = sum((-1 if x[i] != x[nb] else 1) for nb in G.neighbors(i))
        if delta > 0 or rng_sa.random() < np.exp(delta / T):
            x[i] ^= 1
            if cut > best_cut:
                best_cut, best_x = cut, x.copy()
        T = max(T * alpha, T_min)
    return best_x, best_cut
sa_solution, sa_cut = simulated_annealing_maxcut(G_large)
print(f"Simulated annealing cut value: {sa_cut}  (classical reference)")
# ── Step 3: Execution on hardware ───────────────────────────
# A Session reserves the backend so the COBYLA iterations and final sampling
# run back-to-back without re-queuing between jobs — important when the
# optimizer submits many short jobs sequentially. All jobs are tagged with
# "TUT_WSQAOA" for traceability in the IBM Quantum dashboard.
# EstimatorV2 with resilience_level=1 enables twirled readout error extinction
# (TREX), which corrects systematic measurement bit-flip errors without extra
# circuit overhead. 4096 shots per call balances estimation noise vs. job time.
estimator_options = EstimatorOptions()
estimator_options.resilience_level = 1
estimator_options.default_shots = 4096
estimator_options.environment.job_tags = ["TUT_WSQAOA"]
# Align the cost observable with the physical qubit layout chosen by the transpiler
cost_op_isa = cost_op_large.apply_layout(ws_isa_large.layout)
ws_param_order_isa = list(ws_isa_large.parameters)
ws_history_hw = []
    estimator_hw = Estimator(mode=session, options=estimator_options)
    def hw_cost_fn(params):
        bound = ws_isa_large.assign_parameters(
            dict(zip(ws_param_order_isa, params))
        energy = (
            estimator_hw.run([(bound, cost_op_isa)]).result()[0].data.evs.real
        ws_history_hw.append(float(energy))
            f"  iter {len(ws_history_hw):>3d}  <H_C> = {energy:.4f}", end="\r"
        return float(energy)
    # Warm-start initialization: gamma=0 means the cost unitary is the identity on
    # the first call, so COBYLA immediately evaluates the warm-start state itself —
    # a much better starting signal than a random point.
    ws_params0_hw = np.concatenate(
        [np.zeros(p_large), np.full(p_large, np.pi / 4)]
    ws_result_hw = minimize(
        hw_cost_fn,
        ws_params0_hw,
        method="COBYLA",
        options={"maxiter": 150, "rhobeg": 0.3},
        f"\nOptimization complete: energy={ws_result_hw.fun:.4f}, "
        f"iterations={len(ws_history_hw)}"
    # ── Step 3b: Sample the optimized circuit ──────────────────────────────────
    # Use 8192 shots for the final sample to get a reliable mode estimate.
    sampler_hw = Sampler(
        mode=session,
        options={"environment": {"job_tags": ["TUT_WSQAOA"]}},
    ws_bound_hw = ws_isa_large.assign_parameters(
        dict(zip(ws_param_order_isa, ws_result_hw.x))
    counts_hw = (
        sampler_hw.run([ws_bound_hw], shots=8192)
        .result()[0]
best_bs_hw = max(counts_hw, key=counts_hw.get)
best_count = counts_hw[best_bs_hw]
total_shots = sum(counts_hw.values())
# Decode: Qiskit returns bitstrings with qubit 0 at the rightmost position,
# so reversing the string maps character index i to variable x_i.
cut_val_hw, s0_hw, s1_hw = evaluate_cut(best_bs_hw[::-1], G_large)
# Compare against simulated annealing.
# A ratio >= 1.0 means WS-QAOA matched or beat the classical SA solution.
# A ratio close to 1.0 (e.g. > 0.95) shows the quantum result is competitive.
approx_ratio_hw = cut_val_hw / sa_cut
    f"Most-probable bitstring frequency: {best_count}/{total_shots} "
    f"({100*best_count/total_shots:.1f}%)"
    f"WS-QAOA cut: {cut_val_hw}  |  SA cut: {sa_cut}  "
    f"|  Approximation ratio vs SA: {approx_ratio_hw:.4f}"
# Visualize both solutions side-by-side on the graph.
# Blue = partition S, orange = partition S-bar.
# Edges crossing between colors are the ones counted in the cut.
fig, axes = plt.subplots(1, 2, figsize=(14, 6))
for ax, assignment, cut, title in [
        axes[0],
        list(sa_solution),
        sa_cut,
        f"Simulated Annealing (cut={sa_cut})",
        axes[1],
        [int(b) for b in best_bs_hw[::-1]],
        cut_val_hw,
        f"WS-QAOA hardware (cut={cut_val_hw})",
    colors = [
        "skyblue" if assignment[i] == 0 else "salmon" for i in G_large.nodes()
    nx.draw(
        G_large,
        pos_large,
        with_labels=True,
        node_color=colors,
        node_size=400,
        font_size=7,
        ax=ax,
    ax.set_title(title)
plt.suptitle("Max-Cut partitions: SA vs WS-QAOA", fontsize=13)
plt.tight_layout()
# ── Step 4: Convergence plot and summary ──────────────────────────────────
# On real hardware the trace will be noisy (shot noise + gate errors), but the
# overall downward trend confirms that COBYLA is making progress despite noise.
ax.plot(ws_history_hw, color="tab:orange", label="WS-QAOA (hardware)")
ax.axhline(
    ws_result_hw.fun,
    color="tab:orange",
    linestyle=":",
    label=f"Final energy ({ws_result_hw.fun:.3f})",
ax.set_title(f"WS-QAOA convergence on {backend.name} (40 qubits, p=1)")
ax.legend()
plt.tight_layout()
print("\n=== Large Scale Summary ===")
print(f"{'Metric':<38} {'Value':>10}")
print("-" * 50)
print(f"{'Nodes / Edges':<38} {N_LARGE:>5} / {len(edges_large):<4}")
print(f"{'QAOA layers (p)':<38} {p_large:>10}")
print(f"{'Transpiled ECR gate count':<38} {ecr_count:>10}")
print(f"{'Transpiled circuit depth':<38} {ws_isa_large.depth():>10}")
print(f"{'Optimizer iterations':<38} {len(ws_history_hw):>10}")
print(f"{'WS-QAOA energy (hardware)':<38} {ws_result_hw.fun:>10.4f}")
print(f"{'Cut value':<38} {cut_val_hw:>10}")
print(f"{'Simulated annealing cut value':<38} {sa_cut:>10}")
print(f"{'Approximation ratio (vs SA)':<38} {approx_ratio_hw:>10.4f}")
Simulated annealing cut value: 53  (classical reference)
  iter  31  <H_C> = -12.4094
Optimization complete: energy=-13.0256, iterations=31
Most-probable bitstring frequency: 4/8192 (0.0%)
WS-QAOA cut: 53  |  SA cut: 53  |  Approximation ratio vs SA: 1.0000
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/warm-start-qaoa/extracted-outputs/00ae1953-1.avif)
![Output of the previous code cell](https://eu-de.quantum.cloud.ibm.com/docs/images/tutorials/warm-start-qaoa/extracted-outputs/00ae1953-2.avif)
Metric                                      Value
Nodes / Edges                             40 / 60
QAOA layers (p)                                 1
Transpiled ECR gate count                       0
Transpiled circuit depth                      276
Optimizer iterations                           31
WS-QAOA energy (hardware)                -13.0256
Cut value                                      53
Simulated annealing cut value                  53
Approximation ratio (vs SA)                1.0000
## Next steps
> **Recommendations**
> - **Higher QAOA layers**: Increase `p` to see how both algorithms improve with more circuit layers, and whether the WS-QAOA advantage at low depth persists.
> - **Qiskit addon optimization mapper**: Explore the [documentation](https://qiskit.github.io/qiskit-addon-opt-mapper/) and try modeling different combinatorial problems, or using different solvers for the continuous relaxation.
## References
[\[1\]](#Reference1) D. J. Egger, J. Mareček, and S. Woerner, "Warm-starting quantum optimization," *Quantum*, vol. 5, p. 479, 2021. [arXiv:2009.10095](https://arxiv.org/abs/2009.10095)
[\[2\]](#Reference2) E. Farhi, J. Goldstone, and S. Gutmann, "A quantum approximate optimization algorithm," [arXiv:1411.4028](https://arxiv.org/abs/1411.4028), 2014.
