Classical feedforward and control flow
    qiskit[all]~=2.3.0
    qiskit-ibm-runtime~=0.43.1
Dynamic circuits now available on all backends
The new version of dynamic circuits is now available to all users on all backends. You can now run dynamic circuits at utility scale. See the announcement for more details.
Dynamic circuits are powerful tools with which you can measure qubits in the middle of a quantum circuit execution and then perform classical logic operations within the circuit, based on the outcome of those mid-circuit measurements. This process is also known as classical feedforward. While these are early days of understanding how best to take advantage of dynamic circuits, the quantum research community has already identified a number of use cases, such as the following:
These improvements brought by dynamic circuits, however, come with trade-offs. Mid-circuit measurements and classical operations typically have longer execution time than two-qubit gates, and this increase in time might negate the benefits of reduced circuit depth. Therefore, reducing the length of mid-circuit measurement is a focus area of improvement as IBM Quantum® releases the new version of dynamic circuits.
The OpenQASM 3 specification defines a number of control-flow structures, but Qiskit Runtime currently only supports the conditional if statement. In Qiskit SDK, this corresponds to the if_test method on QuantumCircuit. This method returns a context manager and is typically used in a with statement. This guide describes how to use this conditional statement.
Note
The code examples in this guide use the standard measure instruction for mid-circuit measurements. However, it is recommended that you use the MidCircuitMeasure instruction instead, if the backend supports it. See the Mid-circuit measurements documentation for details.
if statement
The if statement is used to conditionally perform operations based on the value of a classical bit or register.
In the example below, we apply a Hadamard gate to a qubit and measure it. If the result is 1, then we apply an X gate on the qubit, which has the effect of flipping it back to the 0 state. We then measure the qubit again. The resulting measurement outcome should be 0 with 100% probability.
qubits = QuantumRegister(1)
clbits = ClassicalRegister(1)
(q0,) = qubits
(c0,) = clbits
circuit.h(q0)
# Use MidCircuitMeasure() if it's supported by the backend.
# circuit.append(MidCircuitMeasure(), [q0], [c0])
circuit.measure(q0, c0)
    circuit.x(q0)
circuit.draw("mpl")
The with statement can be given an assignment target which is itself a context manager that can be stored and subsequently used to create an else block, which is executed whenever the contents of the if block are not executed.
In the example below, we initialize registers with two qubits and two classical bits. We apply a Hadamard gate to the first qubit and measure it. If the result is 1, then we apply a Hadamard gate on the second qubit; otherwise, we apply an X gate on the second qubit. Finally, we measure the second qubit as well.
qubits = QuantumRegister(2)
clbits = ClassicalRegister(2)
(q0, q1) = qubits
(c0, c1) = clbits
circuit.h(q0)
    circuit.h(q1)
with else_:
    circuit.x(q1)
circuit.measure(q1, c1)
circuit.draw("mpl")
In addition to conditioning on a single classical bit, it's also possible to condition on the value of a classical register composed of multiple bits.
In the example below, we apply Hadamard gates to two qubits and measure them. If the result is 01, that is, the first qubit is 1 and the second qubit is 0, then we apply an X gate to a third qubit. Finally, we measure the third qubit. Note that for clarity, we chose to specify the state of the third classical bit, which is 0, in the if condition. In the circuit drawing, the condition is indicated by the circles on the classical bits being conditioned on. A solid circle indicates conditioning on 1, while an outlined circle indicates conditioning on 0.
qubits = QuantumRegister(3)
clbits = ClassicalRegister(3)
(q0, q1, q2) = qubits
(c0, c1, c2) = clbits
circuit.h([q0, q1])
    circuit.x(q2)
circuit.measure(q2, c2)
circuit.draw("mpl")
Classical expressions
The Qiskit classical expression module qiskit.circuit.classical contains an exploratory representation of runtime operations on classical values during circuit execution. Due to hardware limitations, only QuantumCircuit.if_test() conditions are currently supported.
The following example shows that you can use the calculation of the parity to create an n-qubit GHZ state using dynamic circuits. First, generate n/2n/2 Bell pairs on adjacent qubits. Then, glue these pairs together using a layer of CNOT gates in between pairs. You then measure the target qubit of all prior CNOT gates and reset each measured qubit to the state 0\vert 0 \rangle. You apply XX to every unmeasured site for which the parity of all preceding bits is odd. Finally, CNOT gates are applied to the measured qubits to re-establish the entanglement lost in the measurement.
In the parity calculation, the first element of the constructed expression involves lifting the Python object mr[0] to a Value node (lift is used to turn arbitrary objects into classical expressions). This is not necessary for mr[1] and the possible following classical register, as they are inputs to expr.bit_xor, and any necessary lifting is done automatically in these cases. Such expressions can be built up in loops and other constructs.
num_qubits = 8
meas_qubits = list(range(2, num_qubits, 2))  # qubits to measure and reset
qc = QuantumCircuit(qr, mr)
# Create local Bell pairs
qc.reset(qr)
qc.h(qr[::2])
    qc.cx(qr[ctrl], qr[ctrl + 1])
# Glue neighboring pairs
    qc.measure(qr[q], mr[k])
    qc.reset(qr[q])
for tgt in range(num_qubits):
    if tgt in meas_qubits:  # skip measured qubits
        continue
    if not left_bits:  # skip if list empty
        continue
    # build XOR-parity expression
    parity = expr.lift(
        mr[left_bits[0]]
    )  # lift the first bit to Value so it will be treated like a boolean.
    for k in left_bits[1:]:
        parity = expr.bit_xor(
            mr[k], parity
        )  # calculate parity with all other bits
    with qc.if_test(parity):  # Add X if parity is 1
        qc.x(qr[tgt])
# Re-entangle measured qubits
qc.draw(output="mpl", style="iqp", idle_wires=False, fold=-1)
Find backends that support dynamic circuits
To find all backends that your account can access and support dynamic circuits, run code like the following. This example assumes that you have saved your login credentials. You could also explicitly specify credentials when initializing your Qiskit Runtime service account. This would let you view backends available on a specific instance or plan type, for example.
Notes
  • The backends that are available to the account depend on the instance specified in the credentials.
  • The new version of dynamic circuits is now available to all users on all backends. See the announcement for more details.
dc_backends = service.backends(dynamic_circuits=True)
print(dc_backends)
[<IBMBackend('ibm_fez')>, <IBMBackend('ibm_pittsburgh')>, <IBMBackend('ibm_boston')>, <IBMBackend('ibm_miami')>, <IBMBackend('ibm_marrakesh')>, <IBMBackend('ibm_torino')>, <IBMBackend('ibm_kingston')>]
Qiskit Runtime limitations
Be aware of the following constraints when running dynamic circuits in Qiskit Runtime.
  • Due to the limited physical memory on control electronics, there is also a limit on the number of if statements and size of their operands. This limit is a function of the number of broadcasts and the number of broadcasted bits in a job (not a circuit).
    When processing an if condition, measurement data needs to be transferred to the control logic to make that evaluation. A broadcast is a transfer of unique classical data, and broadcasted bits is the number of classical bits being transferred. Consider the following:
    c0 = ClassicalRegister(3)
    c1 = ClassicalRegister(5)
    with circuit.if_test((c0, 1)) ...
    with circuit.if_test((c0, 3)) ...
    with circuit.if_test((c1[2], 1)) ...
    In the previous code example, the first two if_test objects on c0 are considered one broadcast because the content of c0 did not change, and thus does not need to be re-broadcasted. The if_test on c1 is a second broadcast. The first one broadcasts all three bits in c0 and the second broadcasts just one bit, making a total of four broadcasted bits.
    Currently, if you broadcast 60 bits each time, then the job can have approximately 300 broadcasts. If you broadcast just one bit each time, however, then the job can have 2400 broadcasts.
  • The operand used in an if_test statement must be 32 or fewer bits. Thus, if you are comparing an entire ClassicalRegister, the size of that ClassicalRegister must be 32 or fewer bits. If you are comparing just a single bit from a ClassicalRegister, however, that ClassicalRegister can be of any size (since the operand is only one bit).
    For example, the "Not valid" code block does not work because cr is more than 32 bits. You can, however, use a classical register wider than 32 bits if you are testing only one bit, as shown in the "Valid" code block.
       cr = ClassicalRegister(50)
       qr = QuantumRegister(50)
       circuit = QuantumCircuit(qr, cr)
       circ.measure(qr, cr)
       with circ.if_test((cr, 15)):
  • Nested conditionals are not allowed. For example, the following code block will not work because it has an if_test inside another if_test:
       c1 = ClassicalRegister(1, "c1")
       c2 = ClassicalRegister(2, "c2")
       with circ.if_test((c1, 1)):
        with circ.if_test(c2, 1)):
  • Having reset or measurements inside conditionals is not supported.
  • Arithmetic operations are not supported.
  • See the OpenQASM 3 feature table to determine which OpenQASM 3 features are supported on Qiskit and Qiskit Runtime.
  • When OpenQASM 3 (instead of QuantumCircuit) is used as the input format to pass circuits to Qiskit Runtime primitives, only instructions that can be loaded into Qiskit are supported. Classical operations, for example, are not supported because they cannot be loaded into Qiskit. See Import an OpenQASM 3 program into Qiskit for more information.
  • The for, while, and switch instructions are not supported.
Use dynamic circuits with Estimator
Since Estimator does not support dynamic circuits, you can use Sampler and build your own measurement circuits instead. Alternatively, you can use the Executor primitive, which supports dynamic circuits.
To replicate Estimator's behavior, follow this process:
  1. Group the terms of all observables into a partition. This can be done by using the PauliList API, for example.
    Note
    You can use the BitArray primitive attribute to compute the expectation values of the provided observables.
  2. Execute one basis change circuit per partition (whichever basis change needs to be done for each partition). See the Measurement bases addon utility measurement_bases module for more information. For more information, see the documentation for the Qiskit addon utilities package.
  3. Add back together the results for each partition.
Next steps
Recommendations
Was this page helpful?
