XSlowGate
class XSlowGate(label='xslow', xslow_gate_name='xslow')
GitHub
Bases: Gate
The x-slow gate.
Parameters
  • name – The name of the gate.
  • num_qubits – The number of qubits the gate acts on.
  • params – A list of parameters.
  • label (str) – An optional label for the gate.
  • xslow_gate_name (str)
Attributes
base_class
Get the base class of this instruction. This is guaranteed to be in the inheritance tree of self.
The “base class” of an instruction is the lowest class in its inheritance tree that the object should be considered entirely compatible with for _all_ circuit applications. This typically means that the subclass is defined purely to offer some sort of programmer convenience over the base class, and the base class is the “true” class for a behavioral perspective. In particular, you should not override base_class if you are defining a custom version of an instruction that will be implemented differently by hardware, such as an alternative measurement strategy, or a version of a parametrized gate with a particular set of parameters for the purposes of distinguishing it in a Target from the full parametrized gate.
This is often exactly equivalent to type(obj), except in the case of singleton instances of standard-library instructions. These singleton instances are special subclasses of their base class, and this property will return that base. For example:
>>> isinstance(XGate(), XGate)
True
>>> type(XGate()) is XGate
False
>>> XGate().base_class is XGate
True
In general, you should not rely on the precise class of an instruction; within a given circuit, it is expected that Instruction.name should be a more suitable discriminator in most situations.
decompositions
Get the decompositions of the instruction from the SessionEquivalenceLibrary.
definition
Return definition in terms of other basic gates.
label
Return instruction label
mutable
Is this instance is a mutable unique instance or not.
If this attribute is False the gate instance is a shared singleton and is not mutable.
name
Return the name.
num_clbits
Return the number of clbits.
num_qubits
Return the number of qubits.
params
The parameters of this Instruction. Ideally these will be gate angles.
Methods
add_decomposition
add_decomposition(decomposition)
Add a decomposition of the instruction to the SessionEquivalenceLibrary.
broadcast_arguments
broadcast_arguments(qargs, cargs)
Validation and handling of the arguments and its relationship.
For example, cx([q[0],q[1]], q[2]) means cx(q[0], q[2]); cx(q[1], q[2]). This method yields the arguments in the right grouping. In the given example:
in: [[q[0],q[1]], q[2]],[]
outs: [q[0], q[2]], []
      [q[1], q[2]], []
The general broadcasting rules are:
  • If len(qargs) == 1:
    [q[0], q[1]] -> [q[0]],[q[1]]
  • If len(qargs) == 2:
    [[q[0], q[1]], [r[0], r[1]]] -> [q[0], r[0]], [q[1], r[1]]
    [[q[0]], [r[0], r[1]]]       -> [q[0], r[0]], [q[0], r[1]]
    [[q[0], q[1]], [r[0]]]       -> [q[0], r[0]], [q[1], r[0]]
  • If len(qargs) >= 3:
    [q[0], q[1]], [r[0], r[1]],  ...] -> [q[0], r[0], ...], [q[1], r[1], ...]
Parameters
  • qargs (list) – List of quantum bit arguments.
  • cargs (list) – List of classical bit arguments.
Returns
A tuple with single arguments.
Raises
CircuitError – If the input is not valid. For example, the number of arguments does not match the gate expectation.
Return type
Iterable[tuple[list, list]]
control
control(num_ctrl_qubits=1, label=None, ctrl_state=None, annotated=None)
Return the controlled version of itself.
The controlled gate is implemented as ControlledGate when annotated is False, and as AnnotatedOperation when annotated is True.
Deprecated since version 2.3
qiskit.circuit.gate.Gate.control()’s argument annotated is deprecated as of Qiskit 2.3. It will be removed in Qiskit 3.0. The method Gate.control() no longer accepts annotated=None. The new default is annotated=True, which represents the controlled gate as an AnnotatedOperation (unless a dedicated controlled-gate class already exists). You can explicitly set annotated=False to preserve the previous behavior. However, using annotated=True is recommended, as it defers construction of the controlled circuit to transpiler, and furthermore enables additional controlled-gate optimizations (typically leading to higher-quality circuits).
Parameters
  • num_ctrl_qubits (int) – Number of controls to add. Defauls to 1.
  • label (str | None) – Optional gate label. Defaults to None. Ignored if the controlled gate is implemented as an annotated operation.
  • ctrl_state (int |str | None) – The control state of the gate, specified either as an integer or a bitstring (e.g. "110"). If None, defaults to the all-ones state 2**num_ctrl_qubits - 1.
  • annotated (bool | None) – Indicates whether the controlled gate should be implemented as a controlled gate or as an annotated operation. If None, treated as False.
Returns
A controlled version of this gate.
Raises
QiskitError – invalid ctrl_state.
copy
copy(name=None)
Copy of the instruction.
Parameters
name (str) – name to be given to the copied circuit, if None then the name stays the same.
Returns
a copy of the current instruction, with the name updated if it was provided
Return type
qiskit.circuit.Instruction
inverse
inverse(annotated=False)
Invert this instruction.
If annotated is False, the inverse instruction is implemented as a fresh instruction with the recursively inverted definition.
If annotated is True, the inverse instruction is implemented as AnnotatedOperation, and corresponds to the given instruction annotated with the “inverse modifier”.
Special instructions inheriting from Instruction can implement their own inverse (e.g. T and Tdg, Barrier, etc.) In particular, they can choose how to handle the argument annotated which may include ignoring it and always returning a concrete gate class if the inverse is defined as a standard gate.
Parameters
annotated (bool) – if set to True the output inverse gate will be returned as AnnotatedOperation.
Returns
The inverse operation.
Raises
CircuitError – if the instruction is not composite and an inverse has not been implemented for it.
is_parameterized
is_parameterized()
Return whether the Instruction contains compile-time parameters.
power
power(exponent, annotated=False)
Raise this gate to the power of exponent.
Implemented either as a unitary gate (ref. UnitaryGate) or as an annotated operation (ref. AnnotatedOperation). In the case of several standard gates, such as RXGate, when the power of a gate can be expressed in terms of another standard gate that is returned directly.
Parameters
  • exponent (float) – the power to raise the gate to
  • annotated (bool) – indicates whether the power gate can be implemented as an annotated operation. In the case of several standard gates, such as RXGate, this argument is ignored when the power of a gate can be expressed in terms of another standard gate.
Returns
An operation implementing gate^exponent
Raises
CircuitError – If gate is not unitary
repeat
repeat(n)
Creates an instruction with self repeated :math`n` times.
Parameters
n (int) – Number of times to repeat the instruction
Returns
Containing the definition.
Return type
Raises
CircuitError – If n < 1.
reverse_ops
reverse_ops()
For a composite instruction, reverse the order of sub-instructions.
This is done by recursively reversing all sub-instructions. It does not invert any gate.
Returns
a new instruction with
sub-instructions reversed.
Return type
soft_compare
soft_compare(other)
Soft comparison between gates. Their names, number of qubits, and classical bit numbers must match. The number of parameters must match. Each parameter is compared. If one is a ParameterExpression then it is not taken into account.
Parameters
other (instruction) – other instruction.
Returns
are self and other equal up to parameter expressions.
Return type
bool
to_matrix
to_matrix()
Return a Numpy.array for the gate unitary matrix.
Returns
if the Gate subclass has a matrix definition.
Return type
np.ndarray
Raises
CircuitError – If a Gate subclass does not implement this method an exception will be raised when this base class method is called.
to_mutable
to_mutable()
Return a mutable copy of this gate.
This method will return a new mutable copy of this gate instance. If a singleton instance is being used this will be a new unique instance that can be mutated. If the instance is already mutable it will be a deepcopy of that instance.
validate_parameter
validate_parameter(parameter)
Gate parameters should be int, float, or ParameterExpression
Was this page helpful?
