Tools index
Build addons-powered workflows faster by using this collection of functions for creating Hamiltonians, generating Trotter time-evolution circuits, and applying the latest error mitigation capabilities.
Browse documentation
Mitigate Estimator expectation values with an AI model, with no additional QPU time.
Construct high-fidelity circuits with reduced depth using approximate quantum compilation with tensor networks.
Work with bosonic systems using data structures for bosonic operators and circuits, as well as frameworks for boson-to-qubit encodings and circuit synthesis through the Qiskit transpiler integration.
Solve constrained binary optimization problems on IBM Quantum hardware by using the iterative warm-starting QAOA with XY-mixers.
Simulate the time evolution of quantum many-body models and estimate time traces of expectation values, with automated error suppression.
Work with fermionic systems using data structures for fermionic operators and circuits, as well as frameworks for fermion-to-qubit encodings and circuit synthesis through the Qiskit transpiler integration.
Simulate fermionic quantum circuits which conserve particle number and the z component of spin.
A set of tools for enabling the solution to general large-scale Hamiltonian subspace eigenproblems.
Solve for the ground state and ground state energy of chemical systems with Qunova Computing's HI-VQE Quantum Function.
Run workloads on IBM quantum hardware using Qiskit primitives and execution modes.
Efficiently solve optimization problems with Kipu Quantum's Iskay Quantum Optimizer.
Deploy your own quantum-classical workflows to IBM Quantum Functions and run them on managed classical compute.
Mitigate measurement errors by processing in a reduced subspace defined by noisy bitstrings.
Build custom error mitigation pipelines with techniques such as Probabilistic Error Cancellation (PEC), Zero-Noise Extrapolation (ZNE), Twirled Readout Error eXtinction (TREX), and Probabilistic Error Amplification (PEA) directly with Samplomatic.
Reduce the Trotter error of Hamiltonian dynamics through a weighted combination of several circuit executions.
Build randomization-based quantum noise characterization experiments and model-fitting analysis pipelines
Reduce circuit depth in expectation value estimations by backpropagating observables through the circuit.
Model optimization problems and map them into representations that can be understood by a quantum computer.
Start solving utility-scale optimization problems with the Fire Opal Optimization Solver by Q-CTRL.
Apply low-overhead dynamical decoupling to improve circuit performance on IBM quantum hardware.
Solve optimization problems on quantum computers using Parity Twine, which minimizes gate counts and circuit depths.
A framework to approximate operator evolution, which can be used to simulate expectation values and implement error mitigation techniques, such as propagated noise absorption (PNA) and shaded lightcones.
Boost the fidelity of sampled distributions using hardware-efficient Pauli checks based on spacetime codes.
Apply automated error suppression using Fire Opal Performance Management by Q-CTRL.
Technique for mitigating errors in observable expectation values by 'absorbing' the inverses of learned noise channels into an observable using Pauli propagation.
Produce unbiased expectation values with lower variance and resource overhead for circuits with fractional or parameterized gates and high-weight observables.
Build, optimize, and execute quantum programs using the open-source software for working with quantum circuits and running them on quantum hardware.
Use quantum computation for multi-physics PDEs, preparing simulation workflows for quantum hardware while keeping full control over quantum and physical modeling parameters.
Solve financial optimization problems, seeking optimal portfolio strategies over time while minimizing risk and maximizing returns.
Extract quantum-transformed features for classical machine learning pipelines using digitized counterdiabatic evolution of a spin-glass Hamiltonian.
Estimate the spectrum of quantum Hamiltonians by processing noisy samples and diagonalizing in a reduced subspace.
Support customized sampling randomizations for the directed execution model, using annotated circuit boxes to capture design intents such as twirling and noise injection on the client side.
SBD (Selected Basis Diagonalization) is a high-performance library for quantum chemistry calculations.
Read the documentation
Reduce probabilistic error cancellation (PEC) sampling overhead by removing noise model terms that have low impact on the observable estimation.
Improve the accuracy and computational efficiency of classical machine learning classification workflows by using quantum optimization executed on IBM hardware.
An HPC-ready implementation of the SQD addon, written in modern C++17 standards and designed to enable HPC workflows and applications.
Solve large combinatorial optimization problems formulated as QUBOs by combining quantum random access optimization with sample-based quantum diagonalization and classical postprocessing.
Reduce measurement overhead and variance for workloads with low-weight observables and loop-free circuits, outperforming standard error mitigation baselines such as ZNE and PEC.
