Implicit solvent calculations using Qiskit Serverless
Usage estimate: 2 minutes on a Heron r2 processor (NOTE: This is an estimate only. Your runtime may vary.)
Learning outcomes
  • How to configure and run a remote workflow using Qiskit Serverless
  • How to compute implicit solvent effects using a quantum computer
Background
Implicit solvent calculations are frequently used in computational biophysics. These models describe how a solute compound interacts with a solvent, without modeling the solvent system directly. Instead, an approximation is made wherein the solute system model is wrapped in a mathematical representation of a dielectric medium characterized empirically. This dielectric approximation then interacts with the solute, which is itself modeled directly. The dielectric medium influences characteristics of the solute system, such as its ground state energy, by interacting with its electron field. This is important to biophysical models used, say, in drug discovery, because compounds behave differently in various dielectric environments. Modeling a compound in the air (in vacuo) will describe different behavior than modeling it in water. Since pharmaceutical compounds must enter into the human body, which itself is composed mostly of water, it is helpful to model a compound in a solution like water instead of in vacuo. With implicit solvent models, we can achieve this behavior cheaply, although the end result will generally be more approximate than the counterpart: more computationally costly explicit solvent models that create direct representations of both solute and solvent molecules.
In this tutorial, we demonstrate how a quantum algorithm, Sample-based Quantum Diagonalization (SQD), can be worked into a relatively computationally cheap implicit solvent model. In the example, we describe how methylamine behaves when it dissolves in water. We compare the quantum algorithm to a classical state-of-the-art comparison method called CASCI and demonstrate close agreement between these computations. We showcase a quantum-centric supercomputing architecture in miniature, offloading the computationally expensive classical post-processing of the quantum sampling portion of the routine into a cloud-based environment within Qiskit Serverless. The code also demonstrates parallelization across the remotely available CPU cores to improve computation time.
Understanding how solvents affect molecular properties is relevant to sustainability research, including carbon capture, electrocatalysis, and battery electrolyte design. The methylamine-in-water example introduces a workflow for combining quantum electronic-structure calculations with an implicit solvent model, providing a starting point for exploring molecular behavior in these broader applications.
Qiskit Serverless is a framework for running distributed quantum and classical workloads without managing infrastructure. There is no server provisioning (no spinning up EC2s, clusters, Docker containers), no orchestration tools (Kubernetes, Docker Swarm) and no monitoring/maintenance. Each Serverless job runs in a clean container, executes your code, and then shuts down. There is no memory between jobs. You simply write your code then submit your job. Within a Serverless job, a program can seamlessly access IBM Quantum® backends and classically post-process results therein. With Qiskit Serverless, users can access always-on remote CPU cores and memory, which provides for the distribution of certain classical workloads across remote resources. Users also gain some advantage in parallel processing of programs while avoiding common headaches from device shutdown mid-execution. For more information on Qiskit Serverless, see its documentation, as well as additional material on GitHub.
This tutorial shows a relevant application of the following:
  • Sample-based quantum diagonalization
  • Client-server computational models for quantum computing
This tutorial is inspired by and based upon research conducted at Cleveland Clinic, as described in Kaliakin, Danil, et al. "Implicit solvent sample-based quantum diagonalization." The Journal of Physical Chemistry B 129.23 (2025): 5788-5796, exposing the full workflow for implicit solvent calculations and extending it with iterative solvent self-consistency ("The Heartwood Algorithm", M. Motta, T. Pellegrini, 2025), geometry optimization, and automatic qubit layout selection. Please refer to the SQD IEF-PCM quantum function template, jointly developed by Cleveland Clinic and IBM® based on Cleveland Clinic research, for a streamlined, black-box interface for running implicit solvent calculations.
Requirements
  • Qiskit SDK v2.0 or later with visualization support
  • IBM Functions Catalog pip install qiskit_ibm_catalog
  • Qiskit IBM Serverless pip install qiskit_serverless
  • Qiskit addon: Sample-based quantum diagonalization (SQD) v0.12.0 pip install qiskit_addon_sqd
  • PySCF pip install pyscf
  • FFSIM pip install ffsim
  • Matplotlib pip install matplotlib
  • Geometric pip install geometric
Setup
# Establish Quantum Resource connection
backend = service.least_busy()
print(f"Using backend {backend.name}")
# Establish Classical HPC Resource connection
from qiskit_ibm_catalog import QiskitFunction, QiskitServerless
client = QiskitServerless()
Create a directory exactly next to the main notebook program called source_files. You will put Python files into this directory that you intend to share with the remote compute environment. You must create two files:
  • source_files\diagonalization_engine.py
  • source_files\classical_simulation.py
Click to expand the text for each script below, then copy and paste the content into a local file with these path names.
  • #!/usr/bin/env python3
    from json.encoder import JSONEncoder
    from json.decoder import JSONDecoder
    from functools import partial
    import os
    from qiskit_serverless import (
        distribute_task,
        get_arguments,
        get,
        save_result,
        get_runtime_service,
    from qiskit_addon_sqd.fermion import (
        SCIResult,
        diagonalize_fermionic_hamiltonian,
        solve_sci,
    ### Argument retrieval
    args = get_arguments()
    data = args["data"]  # Chemistry Data
    energy_tol = args["energy_tol"]  # SQD option
    occupancies_tol = args["occupancies_tol"]  # SQD option
    max_iterations = args["max_iterations"]  # SQD option
    symmetrize_spin = args["symmetrize_spin"]  # Eigenstate solver option
    carryover_threshold = args["carryover_threshold"]  # Eigenstate solver option
    num_batches = args["num_batches"]  # Eigenstate solver option
    samples_per_batch = args["samples_per_batch"]  # Eigenstate solver option
    max_cycle = args["max_cycle"]  # Eigenstate solver option
    mem = args["mem"]  # Memory per Worker
    # --- fan‑out target: 1 CPU + mem GB RAM per call -------------
    @distribute_task(target={"cpu": 1, "mem": mem * 1024**3})
    def _solve_sci_worker(
        ix, ci_strs, one_body_tensor, two_body_tensor, norb, nelec, spin_sq
        print(f">>>>> WORKER {ix} INITIATED")
        res = solve_sci(
            ci_strs,
            one_body_tensor,
            two_body_tensor,
            norb=norb,
            nelec=nelec,
            spin_sq=spin_sq,
        print(f">>>>> WORKER {ix} COMPLETE")
        return res
    def distribute_solve_sci_batch(
        ci_strings: list[tuple[np.ndarray, np.ndarray]],
        one_body_tensor: np.ndarray,
        two_body_tensor: np.ndarray,
        norb: int,
        nelec: tuple[int, int],
        spin_sq: float | None = None,
        **kwargs,
    ) -> list[SCIResult]:
        """Diagonalize Hamiltonian in subspaces, parallelizing across
            vCPUs in the Serverless environment.
        Args:
            ci_strings: List of pairs (strings_a, strings_b) of arrays of
                spin-alpha CI strings and spin-beta CI strings whose Cartesian
                product gives the basis of the subspace in which to perform a
                diagonalization.
            one_body_tensor: The one-body tensor of the Hamiltonian.
            two_body_tensor: The two-body tensor of the Hamiltonian.
            norb: The number of spatial orbitals.
            nelec: The numbers of alpha and beta electrons.
            spin_sq: Target value for the total spin squared for the ground state.
                If ``None``, no spin will be imposed.
            **kwargs: Keyword arguments to pass to
                `pyscf.fci.selected_ci.kernel_fixed_space`
                (https://pyscf.org/pyscf_api_docs/pyscf.fci.html#pyscf.fci.selected_ci.kernel_fixed_space
        Returns:
            The results of the diagonalizations in the subspaces given by ci_strings.
        inputs = [
            (ix, ci_strs, one_body_tensor, two_body_tensor, norb, nelec, spin_sq)
            for ix, ci_strs in enumerate(ci_strings)
        # fan‑out: spawn one worker per input tuple
        print(">>>>> ENTERING WORKER FAN-OUT")
        refs = [_solve_sci_worker(*input_) for input_ in inputs]
        print(">>>>> WAITING ON WORKERS TO FINISH TASKS")
        # fan‑in: block until every worker finishes
        results = get(refs)
        print(">>>>> DISTRIBUTED JOBS COMPLETED")
        return results
    # A caveat of executing a Python program remotely is
    # that the inputs to the remote program must be passed
    # over an internet network. Similarly, the outputs
    # must be passed back to the local program via the same
    # structure. Python objects are not always able to be
    # passed over a network, and must be encoded in a
    # JSON serializable format.
    i_data = JSONDecoder().decode(data)
    # i_data has all of the information needed from the
    # local program to pick up where the computation left off
    # after its submission to the remote environment.
        job_id,
        hcore,
        eri,
        num_orbitals,
        nuclear_repulsion_energy,
        num_elec_a,
        num_elec_b,
    ] = i_data
    # Re-convert data back into numpy format, after serialization
    hcore = np.array(hcore)
    eri = np.array(eri)
    nuclear_repulsion_energy = np.float64(nuclear_repulsion_energy)
    # Instantiate Runtime Service to retrieve the
    # bitstrings from the QPU job. We provided these
    # credentials upon Serverless setup.
    service = get_runtime_service()
    # retrieving the QPU job data from the Serverless side
    job = service.job(job_id)
    primitive_result = job.result()
    pub_result = primitive_result[0]
    bit_array = pub_result.data.meas  # Getting the bitstrings
    # Pass options to the built-in eigensolver
    sci_solver = partial(
        distribute_solve_sci_batch, spin_sq=0.0, max_cycle=max_cycle
    # List to capture intermediate results
    result_history = []
    def callback(results: list[SCIResult]):
        result_history.append(results)
        iteration = len(result_history)
        print(f">>>>> SQD ITERATION {iteration}")
        for i, result in enumerate(results):
            print(f">>>>> SUBSAMPLE {i}")
            print(f">>>>> \tENERGY: {result.energy + nuclear_repulsion_energy}")
                f">>>>> \tSUBSPACE DIMENSION: {np.prod(result.sci_state.amplitudes.shape)}"
    result = diagonalize_fermionic_hamiltonian(
        hcore,
        eri,
        bit_array,
        samples_per_batch=samples_per_batch,
        norb=num_orbitals,
        nelec=(num_elec_a, num_elec_b),
        num_batches=num_batches,
        energy_tol=energy_tol,
        occupancies_tol=occupancies_tol,
        max_iterations=max_iterations,
        sci_solver=sci_solver,
        symmetrize_spin=symmetrize_spin,
        carryover_threshold=carryover_threshold,
        callback=callback,
        seed=12345,
    print(">>>>> EXACT DIAGONALIZATION COMPLETE. CLEANING UP, SERIALIZING DATA.")
    # Numpy arrays are not JSON serializable.
    # Convert them to List objects before using the JSONEncoder
    o_data = JSONEncoder().encode(
            result.energy + nuclear_repulsion_energy,
            result.energy,
            result.rdm1.tolist(),
            result.rdm2.tolist(),
            [x.tolist() for x in result.orbital_occupancies],
                result.sci_state.nelec,
                result.sci_state.norb,
                [x.tolist() for x in result.sci_state.orbital_occupancies()],
                [x.tolist() for x in result.sci_state.rdm()],
    # JSON-safe package
    save_result({"outputs": o_data})  # single JSON blob returned to client
    from qiskit_serverless import get_arguments, save_result
    import pyscf
    from pyscf import gto, scf
    from pyscf.solvent import pcm
    from pyscf.mcscf import avas
    import psutil
    mem_info = (
        psutil.virtual_memory()
    )  # Get information about virtual memory (RAM)
    total_ram_gb = mem_info.total / (1024**3)  # Convert bytes to GB
    print(f">>>>> SERVERLESS TOTAL RAM: {total_ram_gb:.2f} GB")
    [mol_geo, eps, ao_labels] = i_data
    print(">>>>> DEFINING MOLECULE")
    mol = gto.M()
    mol.atom = mol_geo
    mol.basis = "cc-pVDZ"
    mol.unit = "Ang"
    mol.charge = 0
    mol.spin = 0
    mol.verbose = 0
    print(">>>>> BUILDING MOLECULE")
    mol.build()
    print(">>>>> DEFINING PCM")
    cm = pcm.PCM(mol)
    cm.eps = eps  # for water
    cm.method = "IEF-PCM"
    print(">>>>> BUILDING RESTRICTED HARTREE FOCK")
    mf = scf.RHF(mol).PCM(cm)  # This is the Final SCF object
    mf.kernel(verbose=0)
    print(">>>>> RUNNING AVAS")
    avas_ = avas.AVAS(mf, ao_labels, with_iao=True, canonicalize=True, verbose=0)
    avas_.kernel()
    norb, ne_act, mo_avas = avas_.ncas, avas_.nelecas, avas_.mo_coeff
    print(">>>>> STARTING CASCI")
    mc_pcm = pyscf.mcscf.CASCI(mf, norb, ne_act).PCM(
        cm
    )  # Make sure to decorate the CASCI object with PCM
    mc_pcm.mo_coeff = mo_avas
    # mc_pcm.max_memory = 140000
    (CASCI_E, _, _, _, _) = mc_pcm.kernel(verbose=0)
    print(f">>>>> CASCI_E: {CASCI_E}")
    o_data = JSONEncoder().encode([float(CASCI_E)])
    # JSON-safe package
Note
For more information, please see the SQD IEF-PCM quantum function template guide (jointly developed by Cleveland Clinic and IBM) referenced above. See also the qiskit_addon_sqd library.
We need to share the program intended to run in the cloud environment, and re-upload it any time we change its source code:
client.upload(
    QiskitFunction(
        title="diagonalization_engine",
        entrypoint="diagonalization_engine.py",  # lives in ./source_files
        working_dir="source_files",
client.upload(
    QiskitFunction(
        title="classical_simulation",
        entrypoint="classical_simulation.py",  # lives in ./source_files
Small-scale simulator example
This tutorial does not make use of a small-scale simulator because the intent is to demonstrate a scalable quantum application that extends beyond the regime of simulator exploration. Instead, we show later on how this method can be implemented using a classical state-of-the-art comparison method called CASCI.
Large-scale hardware example
# This is a useful helper function that displays
# remote job execution details to the user's local machine
def feedback_serverless(serverless_job):
    import time
    # Wait for the job to execute
    print(f">>>>> Serverless status: {serverless_job.job_id}")
    timer = 0
    while timer < 10000:
        if (
            serverless_job.status() == "QUEUED"
            or serverless_job.status() == "INITIALIZING"
            or serverless_job.status() == "RUNNING"
            print(f">>>>> [{timer}s] Serverless job {serverless_job.job_id}: \
                {serverless_job.status()}")
            time.sleep(10)
            timer += 10
        elif serverless_job.status() == "ERROR":
                f">>>>> Serverless job {serverless_job.job_id}: {serverless_job.status()}"
            print(">>>>> Logs:")
            print(serverless_job.logs())
            break
        elif serverless_job.status() == "DONE":
            break
            break
    return
1.1: Initialize molecule object using known a priori\textit{a priori} molecular geometry
# Reference guide for building molecule structures:
# https://pyscf.org/user/gto.html
# Video tutorial on building molecular objects in PySCF:
# https://www.youtube.com/watch?v=cNC2cY9E9j0
molecule_name = "Methylamine"
methylamine_geo = """
    N   -0.7154    0.0000    0.0000;
    C    0.7154    0.0000    0.0000;
    H    1.1069    0.0916    1.0174;
    H    1.0996    0.8349   -0.5930;
    H    1.0996   -0.9274   -0.4345;
    H   -1.0625    0.8564    0.4294;
    H   -1.0625   -0.7661    0.5753;
# Imports
import pyscf
from pyscf import gto  # Deals with molecular initialization
from pyscf import scf  # Solvation methods
# Explicitly defining the Methylamine molecule
mol = gto.M()
mol.atom = methylamine_geo
mol.unit = "Ang"
mol.charge = 0
mol.spin = 0
mol.verbose = 0
mol.build()
1.2: Define solvation effects using the Polarizable Continuum Model (PCM)
# You can explore other solvents (such as methanol) by
# retrieving other dielectric parameters from:
# https://gaussian.com/scrf/
eps_water = 78.3553  # If solvating in a different medium,
# set this constant appropriately using a known value
cm = pcm.PCM(mol)
cm.eps = eps_water  # PySCF defaults to water solvation,
# but here we show this solvation parameter explicitly
cm.method = (
    "IEF-PCM"  # Alternative solvation models include C-PCM, SS(V)PE, COSMO
# Create a "Restricted Hartree-Fock" object for the solute,
# then wrap the SCF object with a Polarizable Continuum Model
mf_pcm0 = scf.RHF(mol).PCM(
    cm
)  # Restricted Hartree-Fock misses instantaneous correlations,
# post-HF methods like CCSD, CI, MP2 might be worth exploring
1.3: Geometry optimization using TRIC
# Geometry optimization with geomeTRIC
from pyscf.geomopt.geometric_solver import (
    optimize,
)  # GeomeTRIC under the hood, for geometry optimization
mol_opt = optimize(
    mf_pcm0, tol_grad=3e-4, verbose=0
)  # Use geomeTRIC/TRIC under the hood
1.4: Prepare continuum model and mean field object with relevant variables
# Re-define PCM
cm = pcm.PCM(mol_opt)
cm.eps = eps_water  # for water
# Re-build Restricted Hartree Fock object
mf_opt = scf.RHF(mol_opt).PCM(cm)
mf_opt.kernel(verbose=0)
# Run AVAS
ao_labels = ["C 2s", "C 2p", "N 2s", "N 2p", "H 1s"]
avas_ = avas.AVAS(
    mf_opt, ao_labels, with_iao=True, canonicalize=True, verbose=0
avas_.kernel()
num_elec_a = (ne_act + mol_opt.spin) // 2
num_elec_b = (ne_act - mol_opt.spin) // 2
For more information on the helper functions demonstrated here, see the Sample-based quantum diagonalization of a chemistry Hamiltonian tutorial.
# Standard SQD helper functions (From SQD Tutorial)
from typing import Sequence
import rustworkx
from qiskit.providers import BackendV2
from qiskit import QuantumCircuit, QuantumRegister
from rustworkx import NoEdgeBetweenNodes, PyGraph
IBM_TWO_Q_GATES = {"cx", "ecr", "cz"}
def create_linear_chains(num_orbitals: int) -> PyGraph:
    """In zig-zag layout, there are two linear chains (with connecting
    qubits between the chains). This function creates those two linear
    chains: a rustworkx PyGraph with two disconnected linear chains.
    Each chain contains `num_orbitals` number of nodes, that is, in the
    final graph there are `2 * num_orbitals` number of nodes.
    Args:
        num_orbitals (int): Number orbitals or nodes in each linear chain.
            They are also known as alpha-alpha interaction qubits.
    Returns:
        A rustworkx.PyGraph with two disconnected linear chains each with
        `num_orbitals` number of nodes.
    G = rustworkx.PyGraph()
    for n in range(num_orbitals):
        G.add_node(n)
    for n in range(num_orbitals - 1):
        G.add_edge(n, n + 1, None)
    for n in range(num_orbitals, 2 * num_orbitals):
        G.add_node(n)
    for n in range(num_orbitals, 2 * num_orbitals - 1):
    return G
def create_lucj_zigzag_layout(
    num_orbitals: int, backend_coupling_graph: PyGraph
) -> tuple[PyGraph, int]:
    """This function creates the complete zigzag graph that 'can be mapped'
    to an IBM QPU with heavy-hex connectivity (the zigzag must be an
    isomorphic sub-graph to the QPU/backend coupling graph for it to be
    mapped). The zigzag pattern includes both linear chains (alpha-alpha
    interactions) and connecting qubits between the linear chains
    (alpha-beta interactions).
    Args:
        num_orbitals (int): Number of orbitals, that is, number of nodes in
            each alpha-alpha linear chain.
        backend_coupling_graph (PyGraph): The coupling graph of the backend
            on which the LUCJ ansatz will be mapped and run. This function takes
            the coupling graph as a undirected `rustworkx.PyGraph` where there
            is only one 'undirected' edge between two nodes, that is, qubits.
            Usually, the coupling graph of an IBM backend is directed (for
            example, Eagle devices such as ibm_brisbane) or may have two edges
            between two nodes (for example, Heron `ibm_torino`). A user
            needs to make such graphs undirected or remove duplicate edges
            (or do both) to make them compatible with this function.
    Returns:
        G_new (PyGraph): The graph with IBM backend compliant zigzag pattern.
        num_alpha_beta_qubits (int): Number of connecting qubits between the
            linear chains in the zigzag pattern. While we want as many
            connecting (alpha-beta) qubits between the linear (alpha-alpha)
            chains, we cannot accommodate all due to qubit and connectivity
            constraints of backends. This is the maximum number of connecting
            qubits the zigzag pattern can have while being backend compliant
            (that is, isomorphic to backend coupling graph).
    isomorphic = False
    G = create_linear_chains(num_orbitals=num_orbitals)
    num_iters = num_orbitals
    while not isomorphic:
        G_new = G.copy()
        num_alpha_beta_qubits = 0
        for n in range(num_iters):
            if n % 4 == 0:
                new_node = 2 * num_orbitals + num_alpha_beta_qubits
                G_new.add_node(new_node)
                G_new.add_edge(n, new_node, None)
                G_new.add_edge(new_node, n + num_orbitals, None)
                num_alpha_beta_qubits = num_alpha_beta_qubits + 1
        isomorphic = rustworkx.is_subgraph_isomorphic(
            backend_coupling_graph, G_new
        num_iters -= 1
    return G_new, num_alpha_beta_qubits
def lightweight_layout_error_scoring(
    backend: BackendV2,
    virtual_edges: Sequence[Sequence[int]],
    physical_layouts: Sequence[int],
    two_q_gate_name: str,
) -> list[list[list[int], float]]:
    """Lightweight and heuristic function to score isomorphic layouts. There
    can be many zigzag patterns, each with different set of physical qubits,
    that can be mapped to a backend. Some of them might include fewer noise
    qubits and couplings than others. This function computes a simple error
    score for each such layout. It sums up 2Q gate error for all couplings
    in the zigzag pattern (layout) and measurement of errors of physical
    qubits in the layout to compute the error score.
    Note:
        This lightweight scoring can be refined using concepts such as
        mapomatic.
    Args:
        backend (BackendV2): A backend.
        virtual_edges (Sequence[Sequence[int]]): Edges in the device-
            compliant zigzag pattern where nodes are numbered from 0 to (2 *
            num_orbitals + num_alpha_beta_qubits).
        physical_layouts (Sequence[int]): All physical layouts of the zigzag
            pattern that are isomorphic to each other and to the larger backend
            coupling map.
        two_q_gate_name (str): The name of the two-qubit gate of the
            backend. The name is used for fetching two-qubit gate error from
            backend properties.
    Returns:
        scores (list): A list of lists where each sublist contains two
            items. First item is the layout, and second item is a float
            representing error score of the layout. The layouts in the `scores`
            are sorted in the ascending order of error score.
    props = backend.properties()
    scores = []
    for layout in physical_layouts:
        total_2q_error = 0
        for edge in virtual_edges:
            physical_edge = (layout[edge[0]], layout[edge[1]])
            try:
                ge = props.gate_error(two_q_gate_name, physical_edge)
            except Exception:
                ge = props.gate_error(two_q_gate_name, physical_edge[::-1])
            total_2q_error += ge
        total_measurement_error = 0
        for qubit in layout:
            meas_error = props.readout_error(qubit)
            total_measurement_error += meas_error
        scores.append([layout, total_2q_error + total_measurement_error])
    return sorted(scores, key=lambda x: x[1])
def _make_backend_cmap_pygraph(backend: BackendV2) -> PyGraph:
    graph = backend.coupling_map.graph
    if not graph.is_symmetric():
        graph.make_symmetric()
    backend_coupling_graph = graph.to_undirected()
    edge_list = backend_coupling_graph.edge_list()
    removed_edge = []
    for edge in edge_list:
        if set(edge) in removed_edge:
            continue
        try:
            backend_coupling_graph.remove_edge(edge[0], edge[1])
            removed_edge.append(set(edge))
        except NoEdgeBetweenNodes:
            pass
    return backend_coupling_graph
def get_zigzag_physical_layout(
    num_orbitals: int, backend: BackendV2, score_layouts: bool = True
) -> tuple[list[int], int]:
    """The main function that generates the zigzag pattern
        with physical qubits that can be used as an `intial_layout` in a
        preset passmanager/transpiler.
    Args:
        num_orbitals (int): Number of orbitals.
        score_layouts (bool): Optional. If `True`, it uses the
            `lightweight_layout_error_scoring` function to score the
            isomorphic layouts and returns the layout with
            fewer erroneous qubits.
            If `False`, returns the first isomorphic subgraph.
    Returns:
        A tuple of device compliant layout (list[int]) with zigzag pattern
        and an int representing number of alpha-beta-interactions.
    backend_coupling_graph = _make_backend_cmap_pygraph(backend=backend)
    G, num_alpha_beta_qubits = create_lucj_zigzag_layout(
        num_orbitals=num_orbitals,
        backend_coupling_graph=backend_coupling_graph,
    isomorphic_mappings = rustworkx.vf2_mapping(
        backend_coupling_graph, G, subgraph=True
    isomorphic_mappings = list(isomorphic_mappings)
    edges = list(G.edge_list())
    layouts = []
    for mapping in isomorphic_mappings:
        initial_layout = [None] * (2 * num_orbitals + num_alpha_beta_qubits)
        for key, value in mapping.items():
            initial_layout[value] = key
        layouts.append(initial_layout)
    two_q_gate_name = IBM_TWO_Q_GATES.intersection(
        backend.configuration().basis_gates
    ).pop()
    if score_layouts:
        scores = lightweight_layout_error_scoring(
            backend=backend,
            virtual_edges=edges,
            physical_layouts=layouts,
            two_q_gate_name=two_q_gate_name,
        return scores[0][0][:-num_alpha_beta_qubits], num_alpha_beta_qubits
    return layouts[0][:-num_alpha_beta_qubits], num_alpha_beta_qubits
import ffsim
# Initial LUCJ ansatz layout
initial_layout, _ = get_zigzag_physical_layout(norb, backend=backend)
# Initialize a pass manager
    optimization_level=3, backend=backend, initial_layout=initial_layout
pass_manager.pre_init = ffsim.qiskit.PRE_INIT
Steps 3 & 4: Execute using Qiskit and post-process using Qiskit Serverless
Here, we combine Step 3 (Execute) and Step 4 (Post-process) because the application context of the implicit solvent model requires an iterative feedback loop that executes several cycles of execution and post-processing to improve the end computation.
3.1 Compute the restricted Hartree-Fock energy
# Run the kernel to get the RHF energy
hf_e = float(mf_opt.kernel())
print(f"Restricted Hartree-Fock Energy: {hf_e}")
3.2: Establish classical reference energy with CASCI
# Setup a Serverless Client
worker = client.load("classical_simulation")
data_e = JSONEncoder().encode([mol_opt.tostring(), eps_water, ao_labels])
serverless_job = worker.run(data=data_e)
# Optionally, check the Serverless status feedback
# Don't sit here and stare at the feedback unless debugging.
# You can go develop something else while the Serverless job runs.
_ = feedback_serverless(serverless_job)
# If you make a mistake and need to cancel something
# for job in client.jobs():
#     job.cancel()
CASCI_E = JSONDecoder().decode(serverless_job.result()["outputs"])[0]
# We have approximated the red, classical baseline from
# Figure 1 for Methanol (North-West panel)
print(f"CASCI/IEF-PCM(cc-pVDZ): E={CASCI_E}")
Configure application parameters
# Systematically vary these parameters to improve hardware results
# Set to "True" to run on real hardware
use_hardware = True
# Error suppression/mitigation options
# >> Configure within Sampler primitive
# Transpiler Options
optimization_level = 3
# Heartwood algorithm options
n_iter = 15  # How many update loops to run
resample = 1  # (resample=1 -> resample the QPU after every
# update loop; resample=n_iter -> sample QPU only once)
shots = 10000
# SQD options
energy_tol = 1e-4
occupancies_tol = 1e-3
max_iterations = 12
# Eigenstate solver options
num_batches = 5
samples_per_batch = 300
symmetrize_spin = True
carryover_threshold = 1e-5
max_cycle = 200
# Classical post-processing options
local = (
    False  # Remote, Serverless (False) versus Local Post-Processing (True)
mem = 16  # Memory allocated to each diagonalization worker (Gb)
# Heartwood algorithm subroutines
import pyscf
from pyscf import ao2mo, cc
from functools import reduce
import ffsim
import time
    SCIResult,
    solve_sci_batch,
def update_rdm(casci_object, dmas):
    Inputs:
      mc   -> CASCI object
      dmas -> Spin-summed 1-particle reduced density matrix
    This function returns the CASCI/SQD one-body density matrix in
    the full basis of atomic orbitals, written as the sum (last line)
    of two terms:
       - a contribution from the core orbitals,
        np.dot(mocore, mocore.conj().T) * 2, (core = inactive and doubly-occupied)
       - a contribution from the active-space orbitals and electrons (dmas)
        rotated from the active-space to the AO basis (the reduce operation)
    Outputs:
      rho_approximation: The CASCI/SQD one-body density matrix
      in the full basis of atomic orbitals
    mo_coeff = casci_object.mo_coeff
    ncore = casci_object.ncore
    ncas = casci_object.ncas
    mocore = mo_coeff[:, :ncore]
    mocas = mo_coeff[:, ncore : ncore + ncas]
    dm1 = np.dot(mocore, mocore.conj().T) * 2
    rho_approximation = dm1 + reduce(np.dot, (mocas, dmas, mocas.conj().T))
    return rho_approximation
def run_active_space_calculation(
    h1e_cas, h2e_cas, norb, ne_act, orbs, fermilevel, ecore
    # ----- perform an HF and a CCSD calculation in the active space
    from pyscf import tools
    from datetime import datetime
    now = datetime.now().strftime("%H:%M:%S")
    print(">>>>> ACTIVE SPACE CALCULATIONS ")
    tools.fcidump.from_integrals(
        f"as_fcidump_{now}.txt",
        h1e_cas,
        h2e_cas,
        norb,
        ne_act,
        ms=0,
        nuc=ecore,
    )  # Forcefully represents the active space in the correct structure
    mf_as = tools.fcidump.to_scf(f"as_fcidump_{now}.txt")
    os.remove(f"as_fcidump_{now}.txt")
    mf_as.kernel()
    print(">>>>> RUNNING CCSD")
    mf_cc = cc.CCSD(mf_as)
    mf_cc.kernel()
    orbts = mf_as.mo_coeff
    t1, t2 = mf_cc.t1, mf_cc.t2
    print(">>>>> UPDATED t1, t2 PARAMETERS")
    # ----- update the HF orbitals
    active = list(
        range(fermilevel - ne_act // 2, fermilevel - ne_act // 2 + norb)
    orbs[:, active] = np.dot(orbs[:, active], orbts)
    return orbs, t1, t2
def get_lucj(norb, num_elec_a, num_elec_b, t1, t2, n_reps=1):
    print(">>>>> CONSTRUCTING LUCJ CIRCUIT")
    alpha_alpha_indices = [(p, p + 1) for p in range(norb - 1)]
    alpha_beta_indices = [(p, p) for p in range(0, norb, 4)]
    ucj_op = ffsim.UCJOpSpinBalanced.from_t_amplitudes(
        t1=t1,  # <---- Update t1 each loop
        t2=t2,  # <---- Update t2 each loop
        n_reps=n_reps,
        interaction_pairs=(alpha_alpha_indices, alpha_beta_indices),
    nelec = (num_elec_a, num_elec_b)
    # create an empty quantum circuit
    qubits = QuantumRegister(2 * norb, name="q")
    circuit = QuantumCircuit(qubits)
    # prepare Hartree-Fock state as the reference state
    # and append it to the quantum circuit
    circuit.append(ffsim.qiskit.PrepareHartreeFockJW(norb, nelec), qubits)
    # apply the UCJ operator to the reference state
    circuit.append(ffsim.qiskit.UCJOpSpinBalancedJW(ucj_op), qubits)
    circuit.measure_all()
    return circuit
# Classical diagonalization engine sent to HPC
def classically_diagonalize(
    bit_array=None,  # Bit string array (only needed if locally processing data)
    nuclear_repulsion_energy=None,  # Electronic energy from the core orbitals
    hcore=None,  # 1-electron hamiltonian integrals
    eri=None,  # 2-electron hamiltonian integrals
    num_orbitals=None,  # Number of spatial orbitals
    nelec=None,  # Number of electrons
    num_elec_a=None,  # Alpha orbitals
    num_elec_b=None,  # Beta orbitals
    job_id=None,  # QPU bitstring Job ID
    client=None,  # Diagonalization engine worker
    energy_tol=1e-4,  # SQD option
    occupancies_tol=1e-3,  # SQD option
    max_iterations=12,  # SQD option
    num_batches=8,  # Eigenstate solver option
    samples_per_batch=300,  # Eigenstate solver option
    symmetrize_spin=False,  # Eigenstate solver option
    carryover_threshold=1e-5,  # Eigenstate solver option
    max_cycle=200,  # Eigenstate solver option
    local=True,  # Remote vs Local Diagonalization
    mem=16.0,  # Memory per Serverless Worker (Gb)
    print(">>>>> STARTING DIAGONALIZATION ENGINE ")
    # Pass options to the built-in eigensolver. If you just want to use
    # the defaults, you can omit this step, in which case you would not
    # specify the sci_solver argument in the call to
    # diagonalize_fermionic_hamiltonian below.
    if local:
        result_history = []
            hcore,
            eri,
            bit_array,
            norb=num_orbitals,
            nelec=(nelec // 2, nelec // 2),
            callback=callback,
            seed=12345,
        result = (result.energy, result.rdm1, result.rdm2)
        # Serverless Logic
            f">>>>> SENDING QISKIT RUNTIME JOB {job_id} TO QISKIT SERVERLESS"
        data = [
            job_id,
            hcore.tolist(),
            eri.tolist(),
            int(num_orbitals),
            float(nuclear_repulsion_energy),
            int(num_elec_a),
            int(num_elec_b),
        # Encode the execution dependencies with the JSONEncoder
        data_e = JSONEncoder().encode(data)
        # Send to Serverless
        worker = client.load("diagonalization_engine")
            data=data_e,
            energy_tol=energy_tol,  # SQD option
            occupancies_tol=occupancies_tol,  # SQD option
            max_iterations=max_iterations,  # SQD option
            symmetrize_spin=symmetrize_spin,  # Eigenstate solver option
            carryover_threshold=carryover_threshold,  # Eigenstate solver option
            num_batches=num_batches,  # Eigenstate solver option
            samples_per_batch=samples_per_batch,  # Eigenstate solver option
            max_cycle=max_cycle,  # Eigenstate solver option
            mem=mem,  # Memory per Worker (Gb)
        o_data = JSONDecoder().decode(serverless_job.result()["outputs"])
        result = (o_data[1], np.array(o_data[2]), np.array(o_data[3]))
        print(f">>>>>>>>>> Active Space Energy: {o_data[1]}")
        print(f">>>>>>>>>> rdm1: {o_data[2]}")
        print(f">>>>>>>>>> rdm2: {o_data[3]}")
    return result
# The Heartwood algorithm
from qiskit_addon_sqd.counts import generate_bit_array_uniform
mc = pyscf.mcscf.CASCI(mf_opt, ncas=norb, nelecas=ne_act).PCM(cm)
mc.with_solvent.method = mf_opt.with_solvent.method  #  Here we make sure
# that mc is also using the same solvent method defined earlier (IEF-PCM)
mc.with_solvent.eps = mf_opt.with_solvent.eps  # Set the dielectric parameters
mc.mo_coeff = mo_avas.copy()  # Update the molecular orbitals to include
# those computed in the presence of the solvent
h1e_cas, ecore = (
    mc.get_h1eff()
)  # <-- h1eff is the 1-electron hamiltonian integrals. h1e_cas is
# a common alias. ecore is the electronic energy from the core orbitals.
h2e_cas = ao2mo.restore(
    1, mc.get_h2eff(), norb
)  # <-- get the 2-electron hamiltonian integrals
mc.mo_coeff, t1, t2 = run_active_space_calculation(
    h1e_cas,
    h2e_cas,
    norb,
    ne_act,
    mo_avas.copy(),
    mf_opt.mol.nelectron // 2,
    ecore,
# Sampler primitive options
# Explore error suppression techniques and see if they can improve result quality
sampler.options.environment.job_tags = ["TUT_ISC"]
# sampler.options.twirling.enable_gates = False
# sampler.options.twirling.num_randomizations = 10
# sampler.options.twirling.shots_per_randomization = 1024
# initial approximation for rdm1
with_solvent_e, with_solvent_v = None, None  # Don't touch
data = []
for iiter in range(n_iter):
    print(f">>>>> IMPLICIT SOLVENT ITERATION {iiter+1}/{n_iter}")
    if with_solvent_v is not None:
        # Subsequent update loops enter here
        mc.get_hcore = lambda *args: mc._scf.get_hcore() + with_solvent_v
        # First update loop starts here
        # hcore is the CAS space (classically computed) 1-electron
        # hamiltonian, which we default to at the start of the routine.
        mc.get_hcore = (
        )  # REF: https://pyscf.org/pyscf_api_docs/pyscf.mcscf.html#pyscf.scf.hf.CASBase.get_h1cas
    # Alias mapping
    # hcore : h1e_cas : h1e_eff
    # nuclear_repulsion_energy : ecore
    # eri : h2e_cas : h2e_eff
    h1e_cas, ecore = (
        mc.get_h1eff()
    )  # <-- h1eff is the 1-electron hamiltonian integrals. h1e_cas is a
    # common alias. ecore is the electronic energy from the core orbitals.
        h1e_cas,
        h2e_cas,
        norb,
        ne_act,
        mo_avas.copy(),
        ecore,
    if use_hardware:
        if (
            iiter % resample == 0
        ):  # <-- Toggle how often you refresh your bitstrings here. The
            # developer suggests that you do it every time, but benevolently
            # provides the freedom to disagree with him via the resample
            # control variable.
            # The "Quantum-Centric" part
            print(">>>>> GENERATING BITSTRINGS USING QUANTUM HARDWARE")
            # LUCJ Ansatz construction
            circuit = get_lucj(norb, num_elec_a, num_elec_b, t1, t2, n_reps=1)
            print(f">>>>> TRANSPILING LUCJ TO {backend.name}")
            isa_circuit = pass_manager.run(circuit)
            print(f">>>>> SUBMITTING ISA_CIRCUIT TO {backend.name}")
            job = sampler.run(
                [isa_circuit], shots=shots
            )  # <----- Error Suppression/Mitigation configured performed upstream
            job_id = str(job.job_id())
            timer = 0
            while job.status() != "DONE":
                timer += 10
                    f">>>>> [{timer}s] RUNTIME JOB {job_id}: {job.status()}"
                time.sleep(10)
            print(f">>>>> RETRIEVED {job_id} FROM {backend.name}")
        print(">>>>> GENERATING BITSTRINGS CLASSICALLY")
        rng = np.random.default_rng(24)
        bit_array = generate_bit_array_uniform(
            100_000, 2 * norb, rand_seed=rng
        )  # <-- Sample bitstrings from a uniform distribution. This is
        # useful for debug, but runs out of steam on large systems
        job_id = float(
            "nan"
        )  # <-- we will check that valid job_id's were passed during grading
        local = True
    # The "Classical Post-processing" part
    result = classically_diagonalize(
        bit_array=bit_array,
        nuclear_repulsion_energy=ecore,  # Electronic energy from the core orbitals
        hcore=h1e_cas,  # 1-electron hamiltonian integrals
        eri=h2e_cas,  # 2-electron hamiltonian integrals
        num_orbitals=norb,  # Number of spatial orbitals
        nelec=ne_act,  # Number of electrons
        num_elec_a=ne_act // 2,  # Alpha orbitals
        num_elec_b=ne_act // 2,  # Beta orbitals
        job_id=job_id,  # QPU bitstring Job ID
        client=client,  # Diagonalization engine worker
        local=local,  # Remote vs Local Diagonalization
    # e   : SQD-based estimate of the energy
    # rdm1: Spin-summed 1-particle reduced density matrix
    e, rdm1 = result[0], result[1]
    rho_approximation = update_rdm(
        mc, rdm1
    ).copy()  # <--- Reconstruct the one-body density matrix in the
    # atomic orbital basis to update the external potential due to
    # the solvent
    if with_solvent_e is not None:
        edup = np.einsum(
            "ij,ji->", with_solvent_v, rho_approximation
        )  # <-- edup: Incrementing the energy calculation with
        # subsequent iterations
        e += ecore + with_solvent_e - edup
        # First update loop enters here
        e += (
            ecore  # Pulled from the CAS space object (molecule's core energy)
    # Outputs:
    # with_solvent_e : scalar energy correction due to solvent polarization
    # with_solvent_v : Fock-like matrix to be added to the core Hamiltonian in SCF
    with_solvent_e, with_solvent_v = mc.with_solvent._get_vind(
        rho_approximation
    data.append((iiter, float(e), job_id))
    print(f">>>>> END IITER {iiter}")
    print(f">>>>> TOTAL ENERGY: {e}\n")
from matplotlib.ticker import ScalarFormatter
def plot_data(data, baseline=0, name=None, save=False):
    x_vals, y_vals, job_ids = zip(*data)
    fig, ax = plt.subplots(figsize=(10, 6))
    # Plot line + markers
    ax.plot(
        x_vals,
        y_vals,
        color="navy",
        linewidth=2,
        marker="o",
        markersize=5,
        label="Energy trajectory",
    ax.axhline(
        baseline,
        color="red",
        linestyle="--",
        linewidth=1.5,
        label="Reference energy",
    # Force plain formatting
    ax.yaxis.set_major_formatter(ScalarFormatter(useMathText=True))
    ax.ticklabel_format(style="plain", axis="y")
    # Annotate each point with its exact value
    for x, y, job_id in zip(x_vals, y_vals, job_ids):
        ax.annotate(
            f"{y:.8f}, ID: {job_id}",
            (x, y),
            textcoords="offset points",
            xytext=(0, 8),  # vertical offset
            ha="center",
            fontsize=8,
            rotation=25,
            color="navy",
    # Annotate the Classical Reference line
    for x, y in zip([0.5], [baseline]):
        ax.annotate(
            f"{y:.5f}",
            (x, y),
            ha="center",
            fontsize=8,
            rotation=25,
            color="red",
    # Titles, labels, etc
    ax.set_title(
        f"SQD/IEF-PCM(cc-pVDZ) - {name}\nEnergy Convergence",
        fontsize=14,
        fontweight="bold",
        pad=15,
    ax.set_xlabel("Update Iterations", fontsize=12)
    ax.set_ylabel("Total Energy (Hartrees)", fontsize=12)
    ax.grid(True, linestyle="--", linewidth=0.6, alpha=0.7)
    ax.legend(frameon=True, loc="best")
    plt.tight_layout()
    if save:
        plt.savefig(f"./results/{name}_energy_convergence.png")
    return fig, ax
# Plot your data
fig, ax = plot_data(data, baseline=CASCI_E, name=molecule_name, save=True)
Next steps
Recommendations
If you found this work interesting, you might be interested in the following resources:
Was this page helpful?
