Solve the market split problem with the ParityQC Parity Twine Optimizer
Usage estimate: 10 seconds on a Nighthawk r2 processor. (NOTE: This is an estimate only. Your runtime may vary.)
Learning outcomes
  • Obtain and format the market split problem from the QOBLIB - Quantum Optimization Benchmarking Library.
  • Set up and use the Parity Twine Optimizer to solve a market split instance.
  • Learn how to choose options for the Parity Twine Optimizer and what results are output.
Background
This tutorial demonstrates how to solve the market split problem using the ParityQC Parity Twine Optimizer.
The problem instance is obtained from the QOBLIB - Quantum Optimization Benchmarking Library.
Market split problem
The market split problem is a real-world, NP-hard resource allocation problem and has become a benchmark for quantum optimization algorithms. It represents a high-stakes logistical challenge: how to partition a complex landscape of customers and products into manageable, equalized territories.
The goal is to divide nn markets into two balanced sales regions such that each region receives exactly half the total demand for mm products. The solution is the specific configuration that achieves the most even distribution of product demand possible, allowing a company to implement a logistics and staffing strategy where both regions are balanced, minimizing the risks such as localized product shortages or warehouse overflows.
As the number of markets and products increases, the number of possible permutations grows exponentially, making it challenging to find the best split using traditional exhaustive searches.
Mathematical formulation
Let AA be an m×nm \times n matrix representing the demand of products across markets, where AijA_{ij} is the demand for product ii in market jj.
A binary assignment vector, x=[x1,x2,…,xn]T∈{0,1}nx = [x_1, x_2, \dots, x_n]^T \in \{0, 1\}^n, is defined where:
  • xj=1x_j = 1 assigns market jj to Region A.
  • xj=0x_j = 0 assigns market jj to Region B.
Let d=[d1,d2,…,dm]Td = [d_1, d_2, \dots, d_m]^T be the total demand vector for each product, calculated as d=A⋅1d = A \cdot \mathbf{1}. The target sales volume per region for product ii is exactly di2\frac{d_i}{2}.
The optimization or feasibility constraint requires that the total sales allocated to Region A perfectly matches half the total demand for every product:
Ax=12A1=b.A x = \frac{1}{2} A \mathbf{1} = b.
In practice, because exact division is rarely possible, the problem is formulated to minimize the squared constraint violation (the cost function):
min⁡x∥Ax−b∥2=∑i=1m(∑j=1nAijxj−b)2.\min_{x} \left\Vert{} A x - b \right\Vert{}^2 = \sum_{i=1}^{m} \left( \sum_{j=1}^{n} A_{ij} x_j - b\right)^2.
Expanding this gives a form that is equivalent to a quadratic unconstrained binary optimization (QUBO) problem.
Upon solving, the solution vector xx dictates to which region the market is assigned. This is the configuration that achieves the most balanced distribution of product demand possible.
Requirements
Before starting this tutorial, ensure the following are installed:
  • Quantum Functions Catalog IBM Client (pip install qiskit-ibm-catalog)
  • Qiskit addon Optimization Mapper (pip install qiskit_addon_opt_mapper)
  • NumPy (pip install numpy)
You also need permission to access the ParityQC Twine Optimizer function. To request access, complete this form.
Setup
(This code assumes you've already saved your account to your local environment.)
First, import all required packages for this tutorial.
import tempfile
from collections.abc import Callable
from pathlib import Path
import requests
Load the Parity Twine Optimizer from the quantum functions catalog:
catalog = FunctionsCatalog(channel="ibm_quantum_platform")
function = catalog.load("parityqc/parity-twine-optimizer")
Step 1: Define the problem as an objective function
Obtain a market split problem instance from the QOBLIB - Quantum Optimization Benchmarking Library as follows.
The load_market_split_problem function retrieves a given problem from QOBLIB and converts it into a QUBO problem.
def load_market_split_problem(instance_name: str) -> OptimizationProblem:
    """Load and formulate a market split optimization problem from an QOBLIB instance.
    The QOBLIB library can be found here:
    https://github.com/ZIB-AOPT/QOBLIB.
    Args:
        instance_name: Name of the market split instance to load as specified by the .dat file
            in the QOBLIB repo.
    Returns:
        The output OptimizationProblem containing the loaded market split problem.
    problem_matrix, problem_vector = fetch_and_parse(
        instance_name, "01-marketsplit", parse_marketsplit_dat
    # Create optimization problem
    optimization_problem = OptimizationProblem(instance_name)
    optimization_problem.binary_var_list(problem_matrix.shape[1])
    for idx, rhs in enumerate(problem_vector):
        optimization_problem.linear_constraint(
            problem_matrix[idx, :], sense="==", rhs=rhs
    return OptimizationProblemToQubo(penalty=1).convert(optimization_problem)
The load_market_split_problem function requires the following parser functions to retrieve and process the market split problem data from QOBLIB.
def fetch_and_parse(instance_name: str, problem: str, parse_func: Callable):
    """Generic function to fetch and parse data from QOBLIB repository.
    Args:
        instance_name: Name of the instance to fetch.
        problem: Category of the problem (e.g., '01-marketsplit', '07-independentset').
        parse_func: Function used to parse the downloaded file
            (e.g., parse_marketsplit_dat, parse_gph_file).
    Returns:
        Result of `parse_func` - either (np.ndarray, np.ndarray) for marketsplit
        or nx.Graph for MIS.
    base_url = (
        "https://raw.githubusercontent.com/ZIB-AOPT/QOBLIB/refs/heads/main/"
    url = (
        base_url
        + problem
        + "/instances/"
        + instance_name
        + (".dat" if problem == "01-marketsplit" else ".gph")
    try:
        response.raise_for_status()
            mode="w",
            suffix=".dat" if problem == "01-marketsplit" else ".gph",
            delete=False,
            encoding="utf-8",
        ) as temp_file:
            temp_file.write(response.text)
            temp_file_path = temp_file.name
        try:
            return parse_func(temp_file_path)
        finally:
            Path(temp_file_path).unlink(missing_ok=True)
    except requests.RequestException as e:
        print(f"Error fetching data from repository: {e}")
    except (ValueError, OSError) as e:
        print(f"Error processing data: {e}")
        return None
def parse_marketsplit_dat(filename: str) -> tuple[np.ndarray, np.ndarray]:
    """Parse a market split problem from a .dat file format.
    Args:
        filename: Path to the .dat file.
    Returns:
        Tuple of (A, b) where:
            - A: (m, n) array of coefficients.
            - b: (m,) array of target values.
    Raises:
        ValueError: If file format is invalid or file is empty.
    with Path(filename).open(encoding="utf-8") as f:
        lines = [
            line.strip()
            for line in f
    if not lines:
    try:
    except (ValueError, IndexError) as e:
        raise ValueError(
            "Invalid file format: first line must contain 'm n' integers"
        ) from e
    if len(lines) < m + 1:
        raise ValueError(
            f"File contains {len(lines)} lines but expected {m + 1} lines"
    mat_a = []
    vec_b = []
    for i in range(1, m + 1):
        try:
        except ValueError as e:
            raise ValueError(f"Invalid integer values in line {i + 1}") from e
        if len(values) != n + 1:
            raise ValueError(
                f"Line {i + 1} contains {len(values)} values but expected {n + 1}"
        mat_a.append(values[:-1])  # First n values: product sales per market
        vec_b.append(values[-1])  # Last value: target sales for this product
    return np.array(mat_a), np.array(vec_b)
Once defined, load_marketsplit_problem can be used to load a specific problem instance from the library:
ms_instance = "ms_04_050_001"
ms_problem = load_market_split_problem(ms_instance)
Step 2: Convert to JSON format
In the first step, you obtained the QUBO form of the problem. Now, convert it to JSON format for the optimizer function:
def optimization_problem_to_json(
    problem: OptimizationProblem,
) -> dict[str, float]:
    Converts an unconstrained quadratic OptimizationProblem in terms of binary or spin variables
    to the JSON input format of the Parity Twine Quantum Function.
    Args:
        problem: The optimization problem to convert to JSON.
    Returns:
        The JSON input format of the given problem.
    ising, constant = problem.to_ising()
    output = {"()": float(constant)}
    for op, coefficient in zip(ising.paulis, ising.coeffs, strict=True):
        # Invert the label strings because Qiskit has opposite convention
        qubits = tuple(
            num
            for num, pauli in enumerate(op.to_label()[::-1])
            if pauli == "Z"
        output[str(qubits)] = float(coefficient)
    return output
The QUBO instance of the market split problem is now converted to JSON format as:
json_ms_problem = optimization_problem_to_json(ms_problem)
Step 3: Calculate the function size
Every job runs at one function size: S, M, or L. The size comes from two properties of the model: how many variables it has, and how densely they interact (the fraction of all variable pairs that appear together in a term). If the size is too small, the job is rejected with error 4600. If it is larger than needed, the job runs on a bigger compute profile than the work requires. A job that does not request a size runs at M. See Function sizes in the guide for the criteria of each size.
The following cell defines the size calculator from the guide. It reads the problem and does nothing else: no job is submitted and nothing is reserved.
# Calculate the function size a model needs, before submitting it.
# Call ``calculate_function_size(problem)``: it returns "S", "M" or "L" and submits
# nothing. The size comes from the number of variables and how densely they interact.
import ast
from collections.abc import Iterator
from typing import Any, Literal
from qiskit_addon_opt_mapper.problems import OptimizationProblem
Size = Literal["S", "M", "L"]
VariableType = Literal["spin", "binary"]
_ORDER = {"S": 0, "M": 1, "L": 2}
# Limits are provided by IBM
_SMALL_NUMVARS, _SMALL_DENSITY = 50, 0.1
_MEDIUM_NUMVARS, _MEDIUM_DENSITY = 100, 0.25
def calculate_function_size(
    problem: dict[str, float] | OptimizationProblem, **kwargs: Any
) -> Size:
    """Return the size ("S", "M" or "L") needed to run ``problem``."""
    metrics = _measure(problem, **kwargs)
    if _is_small(metrics):
        return "S"
    if _is_medium(metrics):
        return "M"
    return "L"
def to_optimization_problem(
    problem_type: str = "",
    variable_type: VariableType = "binary",
    """Convert the Parity Twine Optimizer ``problem`` input into an
    ``OptimizationProblem``.
    Args:
        problem: A dictionary {term: coefficient} where each term is a string
            version of a tuple of variable ids, for example
            {"()": 3, "(0,)": 1, "(0, 1)": 2}. An ``OptimizationProblem`` is
            returned unchanged.
        problem_type: The ``problem_type`` passed to the function, for
            example "mis".
        variable_type: Type of all variables, either "spin" or "binary".
    Returns:
        The parsed problem, as a minimization without constraints.
    if isinstance(problem, OptimizationProblem):
        return problem
    if variable_type not in ("spin", "binary"):
        raise ValueError(
            f"Invalid variable type {variable_type!r}, expected 'spin' or 'binary'."
    constant: float = 0
    linear_terms: dict[str, float] = {}
    quadratic_terms: dict[tuple[str, str], float] = {}
    variables: set[str] = set()
    for raw_term, coefficient in problem.items():
        try:
            parsed = ast.literal_eval(raw_term)
        except (ValueError, SyntaxError) as exc:
            raise ValueError(
                f"Invalid problem term {raw_term!r}: expected a tuple literal like '(0, 1)'."
            ) from exc
        if not isinstance(parsed, tuple):
            raise ValueError(
        term = tuple(map(str, parsed))
        if len(term) == 0:
            constant = coefficient
        elif len(term) == 1:
            linear_terms[term[0]] = coefficient
        elif len(term) == 2:
            quadratic_terms[term] = coefficient
            raise ValueError(
                "Invalid problem term, only quadratic problems are "
                f"supported, higher-order term: {term}"
        variables.update(term)
    model = OptimizationProblem()
    model.name = problem_type
    for variable in sorted(variables):
        if variable_type == "spin":
            model.spin_var(variable)
            model.binary_var(variable)
    model.minimize(
        constant=constant, linear=linear_terms, quadratic=quadratic_terms
    return model
def _measure(
    """Return the number of variables and the interaction density."""
    model = to_optimization_problem(
        problem,
        problem_type=kwargs.get("problem_type", ""),
        variable_type=kwargs.get("variable_type", "binary"),
    num_vars = model.get_num_vars()
    pairs = set()
    for term in _interactions(model):
        pairs.update(frozenset(pair) for pair in combinations(set(term), 2))
    max_pairs = num_vars * (num_vars - 1) // 2
    return {
        "num_vars": num_vars,
        "density": len(pairs) / max_pairs if max_pairs else 0.0,
def _interactions(problem: OptimizationProblem) -> Iterator[tuple[int, ...]]:
    """Yield the variables of every term that couples two or more of them.
    A constraint contributes every variable in it, because on hardware it becomes
    a penalty whose square couples them all.
    objective = problem.objective
    yield from objective.quadratic.to_dict()
    for expression in objective.higher_order.values():
        yield from expression.to_dict()
    for constraint in problem.linear_constraints:
        yield _constraint_support(constraint)
    for constraint in problem.quadratic_constraints:
    for constraint in problem.higher_order_constraints:
def _constraint_support(constraint: Any) -> tuple[int, ...]:
    """Return every variable appearing in a constraint's left-hand side."""
    variables = set(constraint.linear.to_dict())
    if hasattr(constraint, "quadratic"):
        for term in constraint.quadratic.to_dict():
    if hasattr(constraint, "higher_order"):
        for expression in constraint.higher_order.values():
            for term in expression.to_dict():
    return tuple(variables)
def _is_small(metrics: dict[str, float]) -> bool:
    """Determine if the metrics fit T-size 'S'."""
    return (
        metrics["num_vars"] <= _SMALL_NUMVARS
        and metrics["density"] <= _SMALL_DENSITY
def _is_medium(metrics: dict[str, float]) -> bool:
    """Determine if the metrics fit T-size 'M'."""
    return (
        metrics["num_vars"] <= _MEDIUM_NUMVARS
        and metrics["density"] <= _MEDIUM_DENSITY
Calculate the size of the problem you submit:
size = calculate_function_size(json_ms_problem)
print(size)
Step 4: Solve the problem using the Parity Twine Optimizer
Now that you have obtained the market split problem and converted it into the correct form, you can find a solution by using the Twine Optimizer and a chosen IBM® backend.
To run the function, choose a suitable backend device; for example, ibm_phoenix.
You can use options for (optional) additional control over the submission:
options = {
    "shots": 100000,
    "postprocessing_level": 1,
    "transpile_only": False,
    "job_tags": ["market_split"],
where shots is an integer that specifies the number of circuit executions, postprocessing_level determines if post-processing is applied to the result, transpile_only specifies whether the problem is only transpiled to a circuit (and not solved), and job_tags is the label used to identify job on IBM Quantum® Platform.
Run the optimizer, passing the calculated size:
function_job = function.run(
    problem=json_ms_problem,
    variable_type="spin",
    backend_name="ibm_phoenix",
    options=options,
    function_size=size,
print(f"Job ID: {function_job.job_id}")
Check the job status:
# Monitor the job status
function_job.status()
Retrieve results:
# Retrieve the job result if the status is DONE
result = function_job.result()
result
The result is of form:
    'solution': {'0': 1, '1': -1, '10': 1, ... },
    'objective_value':  1.0,
    'solution_bitstring': '010000011101111011001001110010',
    'metadata': {
        'circuit_metrics': {
            'depth': 309,
            'gate_count': 3880,
            'two_qubit_gate_depth': 116,
            'two_qubit_gate_count': 899,
            'num_qubits': 30,
            'operations': {'sx': 1244, 'rz': 1227, 'cz': 899, 'delay': 473, 'measure': 30, 'x': 7},
        'solver_info': {
            'variable_mapping': {'0': 0, '1': 1, '10': 2, ... },
            'bitstring_distributions': {
                'before_postprocessing': {'011101110010110111001110011000': 1, ...},
                'after_postprocessing': {'011011110000110101001111011000': 1, ...}
            'best_parameters': {
                'beta': [-0.18054534155552715],
                'gamma': [1.4141236348317905]
        'resource_usage': {
            'RUNNING: MAPPING': {'CPU_TIME': 172.936},
            'RUNNING: OPTIMIZING_FOR_HARDWARE': {'CPU_TIME': 0.272},
            'RUNNING: WAITING_FOR_QPU': {'CPU_TIME': 7.798},
            'RUNNING: EXECUTING_QPU': {'QPU_TIME': 30.0},
            'RUNNING: POST_PROCESSING': {'CPU_TIME': 31.613},
where the solution dictionary corresponds to the qubits defined in the problem and gives their optimized spin values. metadata gives information on the transpilation (two-qubit gates counts/depth, gates used, active qubits), and various runtimes.
In the context of the market split problem, the solution bitstring represents a binary assignment vector used to partition markets into two separate regions. A value of 1 assigns that specific market to Region A while a value of 0 assigns it to Region B. For the optimal solution, the combination balances the split, meaning both regions receive exactly half of the total company demand for every product.
Next steps
Recommendations
Was this page helpful?
