Control Flow
The Qiskit C API for control flow provides facilities for inspecting control flow instructions used in quantum circuits. You can query the type of control flow instruction, access nested circuit blocks, inspect conditions and loop parameters, and retrieve qubit and classical bit mappings between nested blocks and the top-level circuit.
typedef struct QkControlFlowInstruction QkControlFlowInstruction
The QkControlFlowInstruction opaque struct is the primary handle used by the C API to represent and reason about control-flow instructions within a circuit. It is obtained by a call to qk_circuit_get_control_flow_instruction() and must be freed with a call to qk_control_flow_instruction_free(). Most C API functions that operate on control-flow constructs expect a pointer to this opaque struct, making it the central vehicle for inspecting control-flow instructions from C. Note that most of the functions in this API which use QkControlFlowInstruction as input, return borrowed pointers that remain valid as long as the control flow instruction exists, so these pointers do not need to be freed separately.
Data Types
QkControlFlowKind
enum QkControlFlowKind
This enum represents the different kinds of control flow instructions that can appear in a quantum circuit.
Values:
enumerator QkControlFlowKind_Box
A Box instruction
enumerator QkControlFlowKind_BreakLoop
Break loop instruction
enumerator QkControlFlowKind_ContinueLoop
Continue loop instruction
enumerator QkControlFlowKind_ForLoop
For loop instruction
enumerator QkControlFlowKind_IfElse
If-else instruction
enumerator QkControlFlowKind_Switch
Switch case instruction
enumerator QkControlFlowKind_While
While loop instruction
QkConditionType
enum QkConditionType
Represents the type of condition or Switch target in a control flow instruction.
This enum is used to identify whether a condition (in IfElse or While instructions) or a Switch target (in Switch instructions) operates on a classical bit, a classical register, or a classical expression.
Values:
enumerator QkConditionType_ClBit
Condition based on a classical bit
enumerator QkConditionType_ClReg
Condition based on a classical register
enumerator QkConditionType_Expr
Condition based on a classical expression
QkConditionBitInfo
struct QkConditionBitInfo
Information about a classical bit condition.
This struct contains the details of a condition that operates on a single classical bit
uint32_t clbit
The index of the classical bit in the circuit
bool condition
The expected value of the classical bit (true or false)
QkBoxDurationKind
enum QkBoxDurationKind
Represents the kind of duration specification for a Box instruction.
Box instructions can have no duration, a concrete duration value, or a duration specified as a classical expression.
Values:
enumerator QkBoxDurationKind_NoDuration
No duration specified
enumerator QkBoxDurationKind_Duration
Concrete duration value (represented as QkDurationInfo)
enumerator QkBoxDurationKind_Expr
Duration specified as a classical expression
QkSwitchCaseLabels
struct QkSwitchCaseLabels
Contains the labels for a Switch case.
This struct holds an array of label values that a Switch case matches against. For example, a case like case(1, 2, 3) would have three labels: 1, 2, and 3. The memory for the labels array is allocated by qk_control_flow_switch_case_labels_uint and must be freed using qk_control_flow_switch_case_labels_clear.
const uint64_t *labels
Pointer to an array of label values
size_t num_labels
Number of labels in the array
QkLoopParamKind
enum QkLoopParamKind
The kind of loop parameter in a ForLoop control flow instruction.
This enum indicates whether a for-loop has no loop parameter, uses a Parameter symbol, or uses a Variable (QkVar) to track the iteration value.
Values:
enumerator QkLoopParamKind_NoLoopParam
No loop parameter is specified for the ForLoop instruction
enumerator QkLoopParamKind_Parameter
Loop parameter is a Parameter
enumerator QkLoopParamKind_Variable
Loop parameter is a Variable
QkSymbolType
enum QkSymbolType
The type of symbol in a ForLoop context.
This enum indicates whether a symbol is a standalone variable or an element inside a parameter vector accessed by an index.
Values:
enumerator QkSymbolType_Standalone
A standalone symbol with a simple name
enumerator QkSymbolType_Element
An element symbol with a base name and index
QkSymbolInfo
struct QkSymbolInfo
Symbol information including type and data.
This struct represents a symbol in a ForLoop context, which can be either a standalone variable or an indexed element.
QkSymbolType ty
The type of symbol (standalone or element)
char *name
A null-terminated C string containing the symbol name. For standalone symbols, this is the variable name. For element symbols, this is the base name of the parameter vector. The caller is responsible for freeing this string using qk_str_free.
size_t index
For element symbols, this is the index into the parameter vector. For standalone symbols, this field is unused and should be ignored.
QkLoopCollectionType
enum QkLoopCollectionType
The type of collection used in a ForLoop control flow instruction.
Values:
enumerator QkLoopCollectionType_List
The loop iterates over an explicit list of elements
enumerator QkLoopCollectionType_Range
The loop iterates over a Python-style range (start, stop, step)
QkLoopElements
struct QkLoopElements
A struct containing loop elements from a ForLoop control flow instruction.
This struct is returned by qk_control_flow_loop_elements and contains both a pointer to the array of loop elements and the number of elements in the array. The pointer is borrowed and must not be freed by the caller.
const ptrdiff_t *elements
Pointer to the array of loop elements.
size_t len
Number of elements in the array.
Functions
qk_control_flow_kind
QkControlFlowKind qk_control_flow_kind(const QkControlFlowInstruction *cf_inst)
Get the kind of a control flow instruction.
Example
// Assuming cf_inst is obtained from a circuit with control flow
QkControlFlowKind kind = qk_control_flow_kind(cf_inst);
switch (kind) {
case QkControlFlowKind_Box:
// do something with the box instruction
break;
case QkControlFlowKind_BreakLoop:
// do something with the break loop instruction
break;
case QkControlFlowKind_ContinueLoop:
// do something with the continue loop instruction
break;
case QkControlFlowKind_ForLoop:
// do something with the for loop instruction
break;
case QkControlFlowKind_IfElse:
// do something with the if-else instruction
break;
case QkControlFlowKind_Switch:
// do something with the switch instruction
break;
case QkControlFlowKind_While:
// do something with the while loop instruction
break;
Safety
Behavior is undefined if cf_inst is not a valid pointer to a QkControlFlowInstruction.
Parameters
  • cf_inst – A pointer to the control flow instruction.
Returns
The kind of control flow instruction.
qk_control_flow_num_blocks
size_t qk_control_flow_num_blocks(const QkControlFlowInstruction *cf_inst)
Get the number of circuit blocks in a control flow instruction.
Example
size_t num_blocks = qk_control_flow_num_blocks(cf_inst);
for (size_t i = 0; i < num_blocks; i++) {
const QkCircuit *block_circuit = qk_control_flow_block_circuit(cf_inst, i);
// Process each block...
Safety
Parameters
Returns
The number of circuit blocks contained in this control flow instruction.
const QkCircuit *qk_control_flow_block_circuit(const QkControlFlowInstruction *cf_inst, size_t block_idx)
Get a pointer to a circuit block within a control flow instruction.
Control flow instructions contain one or more circuit blocks (e.g., IfElse has two blocks, Switch may have multiple blocks). This function retrieves a specific block by index.
Example
// Assuming cf_inst is an IfElse control flow instruction
const QkCircuit *true_block = qk_control_flow_block_circuit(cf_inst, 0);
const QkCircuit *false_block = qk_control_flow_block_circuit(cf_inst, 1);
// Process the true and false blocks...
Safety
Parameters
  • block_idx – The index of the block to retrieve. block_idx must be within bounds (< qk_control_flow_num_blocks).
Returns
A pointer to the QkCircuit representing the requested block. The circuit is valid as long as the control flow instruction exists. The circuit is owned by the control flow instruction and must not be freed by the caller.
qk_control_flow_qubit_map
const uint32_t *qk_control_flow_qubit_map(const QkControlFlowInstruction *cf_inst)
Get the qubit mapping for a control flow instruction.
Returns a pointer to an array that maps the qubits used in the control flow instruction’s blocks to their indices in the top-level circuit. The array length equals the number of qubits used by the control flow instruction. For each qubit index i in the nested block, the mapping at index i in the array gives the corresponding qubit index in the top-level circuit.
Example
const uint32_t *qubit_map = qk_control_flow_qubit_map(cf_inst);
uint32_t num_qubits = qk_circuit_num_qubits(qk_control_flow_block_circuit(cf_inst, 0));
for (uint32_t i = 0; i < num_qubits; i++) {
    printf("Block qubit %u maps to circuit qubit %u\n", i, qubit_map[i]);
Safety
Parameters
Returns
A pointer to an array of uint32_t values representing the qubit mapping. The array is valid as long as the control flow instruction exists. The array is owned by the control flow instruction and must not be freed by the caller.
qk_control_flow_clbit_map
const uint32_t *qk_control_flow_clbit_map(const QkControlFlowInstruction *cf_inst)
Get the classical bit mapping for a control flow instruction.
Returns a pointer to an array that maps the classical bits used in the control flow instruction’s blocks to their indices in the top-level circuit. The array length equals the number of classical bits used by the control flow instruction. For each classical bit index i in the nested block, the mapping at index i in the array gives the corresponding classical bit index in the top-level circuit.
Example
const uint32_t *clbit_map = qk_control_flow_clbit_map(cf_inst);
uint32_t num_clbits = qk_circuit_num_clbits(qk_control_flow_block_circuit(cf_inst, 0));
for (uint32_t i = 0; i < num_clbits; i++) {
    printf("Block clbit %u maps to circuit clbit %u\n", i, clbit_map[i]);
Safety
Parameters
Returns
A pointer to an array of uint32_t values representing the classical bit mapping. The array is valid as long as the control flow instruction exists. The array is owned by the control flow instruction and must not be freed by the caller.
qk_control_flow_condition_type
QkConditionType qk_control_flow_condition_type(const QkControlFlowInstruction *cf_inst)
Get the condition type for a control flow instruction.
Returns the type of condition used in an IfElse or While instruction. The condition type indicates whether the condition is based on a classical bit, classical register or a classical expression.
Panics if cf_inst is not an IfElse or While control flow instruction.
Example
// Assuming cf_inst is an IfElse or While control flow instruction
QkConditionType cond_type = qk_control_flow_condition_type(cf_inst);
switch (cond_type) {
case QkConditionType_ClBit:
// do something with classical bit...
break;
case QkConditionType_ClReg:
// do something with classical register...
break;
case QkConditionType_Expr:
// Process expression...
break;
Safety
Parameters
  • cf_inst – A valid pointer to a QkControlFlowInstruction that must represent an IfElse or While instruction.
Returns
A QkConditionType enum value indicating the condition type.
qk_control_flow_condition_bit_info
QkConditionBitInfo qk_control_flow_condition_bit_info(const QkControlFlowInstruction *cf_inst)
Get the classical bit condition information for a control flow instruction.
Extracts the classical bit index and expected value from an IfElse or While instruction that has a classical bit condition.
Panics if cf_inst is not an IfElse or While control flow instruction, or if the condition is not a bit type.
Example
// Assuming cf_inst is an IfElse or While instruction with a bit condition
QkConditionBitInfo bit_info = qk_control_flow_condition_bit_info(cf_inst);
printf("Condition: clbit[%u] == %s\n", bit_info.clbit, bit_info.condition ? "true" : "false");
Safety
Parameters
  • cf_inst – A valid pointer to a QkControlFlowInstruction that must represent an IfElse or While instruction with a classical bit condition.
Returns
A QkConditionBitInfo struct containing the classical bit index and expected value.
qk_control_flow_condition_reg_cond_bit_width
uint64_t qk_control_flow_condition_reg_cond_bit_width(const QkControlFlowInstruction *cf_inst)
Get the bit width of the classical register condition for a control flow instruction.
Extracts the bit width of the classical register from an IfElse or While instruction that has a classical register condition.
Panics if cf_inst is not an IfElse or While control flow instruction, or if the condition is not a register type.
Example
// Assuming cf_inst is an IfElse or While instruction with a register condition
uint64_t bit_width = qk_control_flow_condition_reg_cond_bit_width(cf_inst);
printf("Register bit width: %lu\n", bit_width);
Safety
Parameters
  • cf_inst – A valid pointer to a QkControlFlowInstruction that must represent an IfElse or While instruction with a classical register condition.
Returns
The bit width of the condition over the classical register.
const QkClassicalRegister *qk_control_flow_condition_reg(const QkControlFlowInstruction *cf_inst)
Get the classical register for a control flow instruction condition.
Extracts the classical register from an IfElse or While instruction that has a classical register condition.
Example
const QkClassicalRegister* creg = qk_control_flow_condition_reg(cf_inst);
// Use the classical register pointer
Safety
Parameters
Returns
A borrowed pointer to the QkClassicalRegister. The pointer remains valid as long as the parent circuit remains valid.
qk_control_flow_condition_reg_cond_uint
uint64_t qk_control_flow_condition_reg_cond_uint(const QkControlFlowInstruction *cf_inst)
Get the condition value of the classical register condition for a control flow instruction.
Extracts the condition as an unsigned integer value from an IfElse or While instruction that has a classical register condition.
Panics if cf_inst is not an IfElse or While control flow instruction, if the condition is not a register type, or if the condition value does not fit in a uint64_t.
Example
uint64_t expected_value = qk_control_flow_condition_reg_cond_uint(cf_inst);
printf("Expected register value: %lu\n", expected_value);
Safety
Parameters
Returns
The condition value.
qk_control_flow_condition_expr
const QkExprNode *qk_control_flow_condition_expr(const QkControlFlowInstruction *cf_inst)
Get the classical expression for a control flow instruction.
Extracts the classical expression from an IfElse or While instruction that has an expression-based condition.
Panics if cf_inst is not an IfElse or While control flow instruction, or if the condition is not an expression type.
Example Usage
// Assuming while_inst is a While control flow instruction with an expression condition
QkConditionType cond_type = qk_control_flow_condition_type(while_inst);
if (cond_type == QkConditionType_Expr) {
const QkExprNode *expr = qk_control_flow_condition_expr(while_inst);
// Use the expression...
Safety
Parameters
  • cf_inst – A valid pointer to a QkControlFlowInstruction that must represent an IfElse or While instruction with an expression condition.
Returns
A borrowed pointer to the QkExprNode representing the classical expression. The pointer remains valid as long as the parent circuit remains valid.
qk_control_flow_box_duration_kind
QkBoxDurationKind qk_control_flow_box_duration_kind(const QkControlFlowInstruction *cf_inst)
Get the duration kind of a Box control flow instruction.
Box instructions can have no duration, a concrete duration value as QkDurationInfo, or a duration specified as an expression. This function returns which kind of duration is present.
Panics if cf_inst is not a Box control flow instruction.
Example
// Assuming cf_inst is a Box control flow instruction
QkBoxDurationKind duration_kind = qk_control_flow_box_duration_kind(cf_inst);
switch (duration_kind) {
case QkBoxDurationKind_NoDuration:
// do something...
break;
case QkBoxDurationKind_Duration:
// do something...
break;
case QkBoxDurationKind_Expr:
// do something...
break;
Safety
Parameters
  • cf_inst – A pointer to the control flow instruction. The control flow instruction must be of a Box kind.
Returns
The kind of duration as QkBoxDurationKind.
qk_control_flow_box_duration_val_info
QkDurationInfo qk_control_flow_box_duration_val_info(const QkControlFlowInstruction *cf_inst)
Get the duration value information of a Box control flow instruction.
This function retrieves the duration value and type for a Box instruction that has a concrete duration.
Panics if cf_inst is not a Box control flow instruction with a concrete duration.
Example
// Assuming cf_inst is a Box instruction with a concrete duration
QkDurationInfo duration_info = qk_control_flow_box_duration_val_info(cf_inst);
if (duration_info.ty == QkDurationType_Dt) {
    int64_t dt = duration_info.value.dt;
} else {
double time = duration_info.value.time;
Safety
Parameters
  • cf_inst – A pointer to the control flow instruction. The control flow instruction must be of a Box kind with a concrete duration.
Returns
A QkDurationInfo struct containing the duration value and unit.
qk_control_flow_box_duration_expr
const QkExprNode *qk_control_flow_box_duration_expr(const QkControlFlowInstruction *cf_inst)
Get the duration expression of a Box control flow instruction.
This function retrieves a pointer to the expression that defines the duration for a Box instruction when the duration is specified as an expression.
Panics if cf_inst is not a Box control flow instruction with an expression duration.
Example
// Assuming cf_inst is a Box instruction with an expression duration
const QkExpr *duration_expr = qk_control_flow_box_duration_expr(cf_inst);
// Use the expression to evaluate or analyze the duration...
Safety
Parameters
  • cf_inst – A pointer to the control flow instruction. The control flow instruction must be of a Box kind with an expression duration.
Returns
A pointer to the QkExpr representing the duration expression. The expression is valid as long as the control flow instruction exists. The expression is owned by the control flow instruction and must not be freed by the caller.
qk_control_flow_loop_collection_type
QkLoopCollectionType qk_control_flow_loop_collection_type(const QkControlFlowInstruction *cf_inst)
Get the type of collection used in a ForLoop control flow instruction.
This function determines whether a ForLoop iterates over an explicit list of elements or a Python-style range.
Panics if cf_inst is not a ForLoop control flow instruction.
Example
// Assuming cf_inst is a ForLoop instruction
QkLoopCollectionType collection_type = qk_control_flow_loop_collection_type(cf_inst);
if (collection_type == QkLoopCollectionType_List) {
// Handle list-based loop
} else if (collection_type == QkLoopCollectionType_Range) {
// Handle range-based loop
Safety
Parameters
  • cf_inst – A pointer to a control flow instruction that must be a ForLoop.
Returns
A CLoopCollectionType enum value indicating the collection type.
QkLoopElements qk_control_flow_loop_elements(const QkControlFlowInstruction *cf_inst)
Get the list of elements that a ForLoop iterates over.
This function retrieves the list of elements from a ForLoop control flow instruction that uses an explicit list collection. Use qk_control_flow_loop_collection_type to determine the collection type before calling this function.
Panics if cf_inst is not a ForLoop control flow instruction with a list collection.
Example
// Assuming cf_inst is a ForLoop instruction with a List collection type
QkLoopElements loop_elements = qk_control_flow_loop_elements(cf_inst);
for (size_t i = 0; i < loop_elements.len; i++) {
    printf("Element %zu: %zu\n", i, loop_elements.elements[i]);
Safety
Parameters
  • cf_inst – A pointer to a control flow instruction that must be a ForLoop with a List collection.
Returns
A QkLoopElements struct containing a pointer to the array of loop elements and the number of elements. The pointer is borrowed for the duration of the control flow instruction and must not be freed by the caller.
qk_control_flow_loop_range
void qk_control_flow_loop_range(const QkControlFlowInstruction *cf_inst, int64_t *out_start, int64_t *out_stop, int64_t *out_step)
Get the range parameters of a ForLoop that iterates over a Python-style range.
This function retrieves the start, stop, and step values from a ForLoop control flow instruction that uses a range collection. Use qk_control_flow_loop_collection_type to determine the collection type before calling this function.
Panics if cf_inst is not a ForLoop control flow instruction with a range collection.
Example
// Assuming cf_inst is a ForLoop instruction with a Range collection type
int64_t start, stop, step;
qk_control_flow_loop_range(cf_inst, &start, &stop, &step);
printf("Loop range: start=%ld, stop=%ld, step=%ld\n", start, stop, step);
Safety
Behavior is undefined if cf_inst is not a valid pointer to a QkControlFlowInstruction, or if any of out_start, out_stop, or out_step are not aligned valid pointers to write to.
Parameters
  • cf_inst – A pointer to a control flow instruction that must be a ForLoop with a Range collection.
  • out_start – An output parameter that will be set to the range start value.
  • out_stop – An output parameter that will be set to the range stop value.
  • out_step – An output parameter that will be set to the range step value.
qk_control_flow_loop_param_kind
QkLoopParamKind qk_control_flow_loop_param_kind(const QkControlFlowInstruction *cf_inst)
Get the kind of loop parameter used in a ForLoop control flow instruction.
This function determines whether a ForLoop has no loop parameter, uses a Parameter symbol, or uses a Variable (QkVar) to track the iteration value.
Example
QkLoopParamKind param_kind = qk_control_flow_loop_param_kind(cf_inst);
if (param_kind == QkLoopParamKind_Parameter) {
// Loop uses a Parameter symbol
} else if (param_kind == QkLoopParamKind_Variable) {
// Loop uses a Variable
Safety
Parameters
Returns
A QkLoopParamKind enum value indicating the loop parameter kind.
qk_control_flow_loop_symbol_info
QkSymbolInfo qk_control_flow_loop_symbol_info(const QkControlFlowInstruction *cf_inst)
Get the loop parameter symbol information from a ForLoop control flow instruction.
This function retrieves the loop parameter symbol information from a ForLoop instruction that uses a Parameter as its loop parameter. The returned QkSymbolInfo contains the symbol’s type, name, and index (for parameter vector element symbols).
Panics if cf_inst is not a ForLoop control flow instruction with a Parameter loop parameter.
Example
// Assuming cf_inst is a ForLoop control flow instruction with a Parameter loop parameter
QkSymbolInfo symbol_info = qk_control_flow_loop_symbol_info(cf_inst);
if (symbol_info.ty == QkSymbolType_Standalone) {
    printf("Loop parameter: %s\n", symbol_info.name);
} else if (symbol_info.ty == QkSymbolType_Element) {
    printf("Loop parameter: %s[%zu]\n", symbol_info.name, symbol_info.index);
qk_str_free(symbol_info.name);
Safety
Parameters
  • cf_inst – A valid pointer to a QkControlFlowInstruction that must represent a ForLoop with a Parameter loop parameter.
Returns
A QkSymbolInfo struct containing the symbol information. The caller must free the returned string in the name field using qk_str_free.
qk_control_flow_loop_variable
const QkVar *qk_control_flow_loop_variable(const QkControlFlowInstruction *cf_inst)
Get the loop variable from a ForLoop control flow instruction.
This function retrieves a pointer to the Variable (QkVar) used as the loop parameter in a ForLoop instruction. The returned pointer is borrowed for the lifetime of the control flow instruction and must not be freed by the caller.
Panics if cf_inst is not a ForLoop control flow instruction with a Variable loop parameter.
Example
// Assuming cf_inst is a ForLoop control flow instruction with a Variable loop parameter
const QkVar *loop_var = qk_control_flow_loop_variable(cf_inst);
// Use the loop variable pointer to access variable information
Safety
Parameters
  • cf_inst – A valid pointer to a QkControlFlowInstruction that must represent a ForLoop with a Variable loop parameter.
Returns
A pointer to the QkVar representing the loop variable. The pointer is valid for the lifetime of the control flow instruction.
qk_control_flow_switch_target_type
QkConditionType qk_control_flow_switch_target_type(const QkControlFlowInstruction *cf_inst)
Get the type of the Switch target for a Switch control flow instruction.
Switch statements can operate on different types of targets: a classical bit, a classical register, or an expression. This function returns which type of target the Switch statement uses.
Panics if cf_inst is not a Switch control flow instruction.
Example
// Assuming cf_inst is a Switch control flow instruction
QkConditionType target_type = qk_control_flow_switch_target_type(cf_inst);
switch (target_type) {
// do something
break;
// do something
break;
// do something
break;
Safety
Parameters
  • cf_inst – A pointer to the control flow instruction. The control flow instruction must be of a Switch kind.
Returns
The condition type of the Switch target as QkConditionType.
qk_control_flow_switch_target_bit
uint32_t qk_control_flow_switch_target_bit(const QkControlFlowInstruction *cf_inst)
Get the classical bit index for a Switch target.
This function retrieves the index of the classical bit that a Switch statement operates on when the Switch target is a classical bit.
Panics if cf_inst is not a Switch control flow instruction with a classical bit target.
Example
// Assuming cf_inst is a Switch instruction with a classical bit target
uint32_t clbit_idx = qk_control_flow_switch_target_bit(cf_inst);
printf("Switch operates on clbit %u\n", clbit_idx);
Safety
Parameters
  • cf_inst – A pointer to the control flow instruction. The control flow instruction must be of a Switch kind with a classical bit target.
Returns
The index of the classical bit in the circuit.
qk_control_flow_switch_target_register
const QkClassicalRegister *qk_control_flow_switch_target_register(const QkControlFlowInstruction *cf_inst)
Get the classical register that a Switch statement operates on.
This function retrieves the classical register used as the Switch target when the Switch operates on a register.
Panics if cf_inst is not a Switch control flow instruction with a register target.
Example
// Assuming cf_inst is a Switch instruction with a register target
const QkClassicalRegister *reg = qk_control_flow_switch_target_register(cf_inst);
// Use the register to get its name, size, etc...
Safety
Parameters
  • cf_inst – A pointer to the control flow instruction. The control flow instruction must be of a Switch kind with a register target.
Returns
A pointer to the QkClassicalRegister that the Switch operates on. The register is valid as long as the control flow instruction exists. The register is owned by the control flow instruction and must not be freed by the caller.
qk_control_flow_switch_target_expr
const QkExprNode *qk_control_flow_switch_target_expr(const QkControlFlowInstruction *cf_inst)
Get the expression for a Switch target.
This function retrieves a pointer to the classical expression that a Switch statement operates on when the Switch target is an expression.
Panics if cf_inst is not a Switch control flow instruction with an expression target.
Example
// Assuming cf_inst is a Switch instruction with an expression target
const QkExpr *target_expr = qk_control_flow_switch_target_expr(cf_inst);
// Evaluate the expression...
Safety
Parameters
  • cf_inst – A pointer to the control flow instruction. The control flow instruction must be of a Switch kind with an expression target.
Returns
A pointer to the QkExpr representing the Switch target expression. The expression is valid as long as the control flow instruction exists. The expression is owned by the control flow instruction and must not be freed by the caller.
qk_control_flow_switch_num_cases
size_t qk_control_flow_switch_num_cases(const QkControlFlowInstruction *cf_inst)
Get the number of cases in a Switch statement.
Returns the total number of case blocks in the Switch statement, including the default case if present.
Example
size_t num_cases = qk_control_flow_switch_num_cases(cf_inst);
for (size_t i = 0; i < num_cases; i++) {
// Analyze the case...
Safety
Parameters
Returns
The number of cases in the Switch statement.
qk_control_flow_switch_is_case_default
bool qk_control_flow_switch_is_case_default(const QkControlFlowInstruction *cf_inst, size_t case_idx)
Check if a specific case in a Switch statement is the default case.
Switch statements can have a default case that matches when no other cases match. This function checks whether the case at the given index is the default case. The default case may also include leading labels, which can be retrieved by qk_control_flow_switch_case_labels_uint on the default case.
Example
for (size_t i = 0; i < qk_control_flow_switch_num_cases(cf_inst); i++) {
if (qk_control_flow_switch_is_case_default(cf_inst, i)) {
        printf("Case %zu is the default case\n", i);
Safety
Parameters
  • case_idx – The index of the case to check. Must be less than the value returned by qk_control_flow_switch_num_cases.
Returns
true if the case at case_idx is the default case, false otherwise.
qk_control_flow_switch_case_labels_bit_width
uint64_t qk_control_flow_switch_case_labels_bit_width(const QkControlFlowInstruction *cf_inst, size_t case_idx)
Get the maximum bit width required to represent the labels in a Switch case.
This function returns the maximum number of bits needed to represent any of the unsigned integer labels in the specified case. This is useful for determining the minimum bit width required to store or process the case labels.
Example
uint64_t bit_width = qk_control_flow_switch_case_labels_bit_width(cf_inst, 0);
printf("Maximum bit width for case 0: %lu\n", bit_width);
Safety
Parameters
  • case_idx – The index of the case whose label bit width to retrieve. Must be less than the value returned by qk_control_flow_switch_num_cases.
Returns
The maximum bit width of the labels in the case, or 0 if the case has no unsigned integer labels (e.g., only a DEFAULT specifier).
QkSwitchCaseLabels qk_control_flow_switch_case_labels_uint(const QkControlFlowInstruction *cf_inst, size_t case_idx)
Get the labels for a specific case in a Switch statement.
Each case in a Switch statement can have one or more labels (e.g., case(1, 2, 3)) has three labels: 1, 2, and 3). This function retrieves all labels for a given case. Note that the default case can also include labels, which can be retrieved by this function. When called on a default case without additional labels, the function sets num_labels = 0 and labels = NULL in the returned QkSwitchCaseLabels struct. Before calling this function, you should use qk_control_flow_switch_case_labels_bit_width to ensure the labels will fit in uint64_t.
Panics if cf_inst is not a Switch control flow instruction or if a case label does not fit in uint64_t.
Example
QkSwitchCaseLabels case_labels = qk_control_flow_switch_case_labels_uint(cf_inst, 0);
for (size_t i = 0; i < case_labels.num_labels; i++) {
    printf("Label %zu: %lu\n", i, case_labels.labels[i]);
qk_control_flow_switch_case_labels_clear(&case_labels);
Safety
Behavior is undefined if cf_inst is not a valid pointer to a QkControlFlowInstruction, or if out_labels is not a valid pointer to a QkSwitchCaseLabels struct.
Parameters
  • case_idx – The index of the case whose labels to retrieve. Must be less than the value returned by qk_control_flow_switch_num_cases.
Returns
A QkSwitchCaseLabels struct with the label information for the given case. The struct will contain a pointer to an array of labels and the number of labels. If num_labels > 0, you should call qk_control_flow_switch_case_labels_clear to free the memory allocated by this function.
void qk_control_flow_switch_case_labels_clear(QkSwitchCaseLabels *labels)
Clear a QkSwitchCaseLabels struct.
This function must be called to free the memory allocated by qk_control_flow_switch_case_labels_uint. After calling this function, the labels pointer in the struct will be set to null and the count will be set to zero.
Example
// Use the labels...
Safety
Behavior is undefined if labels is not a valid pointer to a QkSwitchCaseLabels.
Parameters
  • labels – A pointer to the QkSwitchCaseLabels struct to clear. The struct must have been previously populated by qk_control_flow_switch_case_labels_uint.
Was this page helpful?
