Configure noise management with Sampler
    qiskit-ibm-runtime~=0.46.1
There are several ways to manage noise, typically by using various error mitigation and error suppression techniques to avoid errors before they happen. These techniques usually cause pre-processing overhead. Therefore, it is important to achieve a balance between perfecting your results and ensuring that your job completes in a reasonable amount of time.
Sampler supports the following noise management techniques. See Error mitigation and suppression techniques for an explanation of each.
Note
Not all options work together on all types of circuits. See the feature compatibility table guide for full details.
Example
sampler = Sampler(backend)
    f">>> dynamical decoupling sequence to use: {sampler.options.dynamical_decoupling.sequence_type}"
Qiskit Code Assistant
Can't remember the right attributes? Try asking Qiskit Code Assistant.
# Enable dynamic decoupling for Sampler with the 'XpXm' sequence type
New to the code assistant? See Qiskit Code Assistant for installation and usage. Note this is an experimental feature and only available to IBM Quantum Premium Plan users.
Next steps
Recommendations
Was this page helpful?
