Pooled sample-based quantum diagonalization of a nuclear Hamiltonian
Download the Python notebook to run this tutorial yourself.
Usage estimate: 32 seconds on a Nighthawk r2 processor (NOTE: This is an estimate only. Your runtime might vary.)
Learning outcomes
- Learn how a nuclear shell-model Hamiltonian, tabulated in a -coupled basis of orbitals, becomes a qubit Hamiltonian in the -scheme, where one qubit is one single-particle state.
- Build a fixed, non-variational excitation ansatz whose angles come from second-order perturbation theory, so there is no classical optimization loop.
- Compare qubit and fermionic excitations and measure how the choice affects the ensemble's two-qubit depth.
- Run self-consistent configuration recovery with
qiskit-addon-sqdwhen the conserved quantities are nucleon numbers, , and parity rather than electron numbers and spin. - Apply one workflow from a 24-qubit problem you can check exactly to a 40-qubit problem with nearly two million basis states, beyond this tutorial's exact-diagonalization capacity.
Before starting, review the following topics:
- Sample-based quantum diagonalization and the SQD addon API reference.
- Sample-based quantum diagonalization of a chemistry Hamiltonian, the electronic-structure counterpart of this tutorial.
- Transpile against a backend target and Introduction to primitives.
- Second quantization and the Jordan-Wigner mapping.
Background
The nuclear shell model treats a nucleus as a few valence nucleons moving in a small set of single-particle orbitals above an inert core, interacting through an empirical two-body force fitted to measured spectra. It is widely used in low-energy nuclear structure. Its computational cost is combinatorial: the basis is every way of distributing the valence protons and neutrons over the available states, and this growth limits the model spaces accessible to exact diagonalization.
Pooled sample-based quantum diagonalization (pooled SQD) [1] splits that problem in two. A quantum circuit is used only to propose which basis states matter. It is measured in the computational basis, and each measured bitstring names one Slater determinant. The Hamiltonian is then built and diagonalized classically in the span of those determinants. Because the classical step is an exact diagonalization inside a subspace, it returns a variational upper bound on the true ground-state energy, and the bound can only fall as determinants are added.
This division of work makes the method noise-tolerant, with an important limitation. Noise changes which determinants the circuit proposes. It does not enter the classical Hamiltonian, so it cannot move the eigenvalue of a given subspace: a shot that violates a conserved quantity is discarded or repaired, and a shot that survives is a legitimate basis vector however it was produced. Noise therefore costs you subspace quality, not correctness, and the number you report is an upper bound either way.
Nuclear structure provides several exact quantum numbers for filtering samples. A physical determinant must carry the right number of valence protons and the right number of valence neutrons, the right total angular-momentum projection , and the right parity. Each can be checked with an integer test on a bitstring. The fraction of samples rejected depends on the constraint and model space.
Every qubit is one -scheme single-particle state , and means occupied. The register uses a fixed order: protons first, then neutrons; within a species, orbitals in file order; within an orbital, descending. The two halves of a bitstring are therefore the proton configuration and the neutron configuration. This is the bipartition expected by the pooled SQD post-processing tools.
The workflow
Two stages in the diagram handle the nuclear symmetries.
Repair and post-selection handle samples affected by hardware noise. The two half-register nucleon numbers
are Hamming weights, so qiskit-addon-sqd handles them directly: recover_configurations repairs a
broken bitstring by flipping the bits least consistent with the current estimate of the average
orbital occupancies, rather than throwing the shot away.
The product subspace introduces . Because couples the two halves, it is not a property of either one, so it must not be used to filter whole shots: a bitstring whose proton half and neutron half are each valid still contributes two good half-configurations even when its total is wrong. The subspace is therefore spanned by every product of a sampled proton configuration with a sampled neutron configuration, keeping the products that land in the target and parity sector. This is the pooled SQD subspace construction, and it means a few thousand bitstrings can span a subspace far larger than the sample count.
Two governing equations
The shell-model Hamiltonian is a one-body term plus a two-body interaction,
where label -scheme states and for a proton, for a neutron. Empirical interactions such as USDA [2] and GXPF1 [3] are tabulated not in the -scheme but in the -coupled basis, as matrix elements between normalized antisymmetrized two-body states of orbitals . Recovering the -scheme element is a Clebsch-Gordan recoupling,
with the factors undoing the normalization convention of the tabulated states. Everything else in this tutorial is built on these two equations.
The three runs
Column 1 | Nucleus | Shell | Qubits | Symmetry-allowed basis | Exactly checkable? |
| Small-scale | (2p + 2n) | 24 | 640 | Yes | |
| Large-scale | (2p + 2n) | 40 | 4,000 | Yes | |
| Large-scale | (4p + 4n) | 40 | 1,963,461 | No |
The small-scale run is the walkthrough. Both large-scale runs use a 40-qubit register: the first is still small enough to diagonalize exactly on a laptop, so you can compare the hardware result with an exact reference. The second exceeds the exact-diagonalization capacity of this tutorial.
Every run here executes on a QPU. That is a choice made for this tutorial rather than a requirement of the method: all three runs share a backend and a gate budget so you can compare their performance at different problem sizes.
Requirements
Install the following packages before starting:
- Qiskit SDK v2.0 or later (
pip install qiskit) qiskit-ibm-runtimev0.40 or later (pip install qiskit-ibm-runtime)- SQD addon v0.12 or later (
pip install qiskit-addon-sqd) - NumPy, SciPy, and Matplotlib (
pip install numpy scipy matplotlib)
You also need an IBM Quantum® account with credentials saved locally, and access to a QPU with at least 40 qubits.
No simulator package is needed, and no data files have to be downloaded. The two interaction files this tutorial uses are embedded in the following setup cell and written to a temporary directory when you run it.
Setup
This section imports the tools and defines the shell-model helpers the workflow needs, in the order the workflow uses them. The physics behind each one is derived in the Appendix; the comments describe each function's role in the workflow.
Two interaction files are unpacked first. Both are published parameter sets, embedded here so the
notebook is self-contained: usda.snt is the USDA -shell Hamiltonian [2] and
gxpf1.snt is the GXPF1 -shell Hamiltonian [3].
import base64
import gzip
import itertools
import tempfile
from functools import lru_cache
from math import factorial, sqrt
from pathlib import Path
from qiskit.circuit.library import PauliEvolutionGate
from qiskit.quantum_info import Operator, SparsePauliOp
from qiskit_addon_sqd.configuration_recovery import recover_configurations
from qiskit_addon_sqd.counts import bit_array_to_arrays
from qiskit_addon_sqd.subsampling import postselect_by_hamming_right_and_left
from scipy.linalg import eigh
_USDA_SNT_GZ = (
"H4sIAI5wqWoC/4WY224bRwyG7/UU9F0CONsZco5AUyBuC/QmQNG06KWhWGql1LYMy+kJefiOTrucGXJrQAgsf5nl8ecOr+CX"
"D9+9g/0K9pv1/T389rx7gPLrsH+Cz/vVctg+vgAsrgB+HeDdAD9t7zYv6+dr+DDA+z8223/X17B8XMFN+ev9+m+4ed799XjA"
"f9z8sy/4+s8BvoWYrsEERwbhFRqTXi+uCvOwW63vYf+0vFvDAgDo/AFIh8/hK7DH30354Omvb8o3V8c/vIUnMKtboK/wiGKF"
"+gnFEfVn9PQUe8bthNIRtftbsGfUtQbAGXUFfawM8K0BF9SP6MWA0BpwQcMRvRhwBSX86+fl3ct2d4jq4+eHa3hYv2x2q7fX"
"AJuPy+fb3cP69+Uh4luAT8djv95++eGV/fj6y6dvFudnmcX4lGOoBmttNOVncTL2FLs3NGT0l++ndJTv0cR8/t6NUanP8WMI"
"6nPC6C8/5wp+vnn//QLOP9ank3k2wRszkDn/Zwv15xiv41l2SDmjhuEFM4PJ0QkYcgzM4A1Jp1GDkcvtaWMAR9tosAa9huHk"
"AtoUBYwaF8hGarAxOywgxnoeN+Se2smF4H3QMPZQ653XMJpOi6GyrcLcZJtzLgoYcdsOyXKibV1Aom0fikJO0VLUMDeW3kAl"
"qQLWpd66qGE02eZ9lXqSPD3UWyl5DeOeGnINJnmaUggCVrtgh2DJNm3fVy8WF3LSMFa9hYga5iYX0IQsYK2nmTpJkoq81Acy"
"jLTTnPEaxqo3JGcbvZMeGnJVbw6mf2cUqcIsO80nFdOFq8JoSlY+Zb7FfNNZlnw2PqOE8SL3PtlSJhJGXGqsDRjbh4bmocWy"
"oiIxSxjv09JYgaxlGLZxA9EFFOImuIBt3EB04TK3Z5S8wizrrFCJQ4Xpgl9hzDYbu0LCNm6HzkJHweUkYazITalyF7NjGAnh"
"FZJFQniFZFHnqWgbdZ6qtoX50VZhvEJ81TJe7AUcQozH8yQMJ8ymUS07jLin6LXT3FRIhmwSTmtbJpEjr2AsvM7E1ra+ZaiM"
"NoxewZinBlPQTmPJyikn7TQ2630SbWuz4CLlwzuGhCHPqbUmRZQwpkiBDn1vsoQ55oKjbEvNNVgbXls0WvA0NKnPpku91Fkx"
"pahhXPDJtxVCQkBcMtJD27I8VJGAhWYYlVuZzc5e+jSIZWnLa57nOQ1iWZY+jSE3GP5/QIKi5E1Agqi9BbMZiUjEWNwChqKq"
"KTZY11ku5ca2Pqc4YKk1o2DstBjJC1htW2nAgEZ4aDdPvQmmmLeY4tWFt9Y3VAdlpW+oDcpa3zpM1jdUB2XV9agOyqrrcWZQ"
"sq7vMMffBseux5l5yjoLZ+Yp6yzU5mmt5DgzT5mSozZPoVIknJmnTJFQHZRV12OrlvpFQFbycoGKOWiYfl9QlXySGtSUvL9W"
"VJi/YG4grC4CmuCX6CZrKUsY64UyJolCQoZJqWeKhDOCzxQJNcGXbZMEX7EtzF+gvCI1npxjmKaW5Q06ewVjOY0u2+Y0kt5D"
"JhlETS2P+5CqyIMYkCI1NK50SO3TarSR2qfVaKOZPmXjg2beVJmS01zqp/CSmvoqvNSOD/kaS+qUoSGaTM2yz83fdjtMvsZy"
"xOv7N44Fff/GT5q5tXWYfB3jWND3b9yumUvK5SQnvK6w/VuHyfu3DpP3bx0m7984FvT9W4fJ+zceWq/v3zpM3r9xLOj7tw6T"
"928X053QgGz/1mHy/u3yZ8lTtn/jWND3b74NiDx2vRbeep56Lbz1oPRaeOv9G0dmxofXPK33bx0m798C1B9RuP4DPJ0WcLAa"
"AAA="
_GXPF1_SNT_GZ = (
"H4sIAI5wqWoC/4WcQY8dtw3H7/kU41sCeF8lUqKkQw9NgbaXoEHQQ26BkdiIEWdt2E6L9tNXb9+ORIn8PwdZILB/S3I4IsW/"
"ZiYvjr//+P3f4nG8ef/x+PDm4dOvr9+9++rF8d3l+Mf7x99fvTz+dTn++fnTH7/1//z28pfL8e3H9/95fHm8evzl+lffvf3f"
"H59e/fb26L9zHN//+t9Pl+OH1/++HH89JL88gkQO8esfvjm+phDomyvW//39/S+v3x2fPrz6+fVX/dfS889B4fpz/aN43P7p"
"f3Bw/ynH8fD0Zy+uf/fn48MR3vxU/kRXlp7Z+PzDiqUnNn74iW8sb3azYvm0m29s2uxGxabTbryx2cZ7nGzu7KOKV2y8g5Un"
"dsZbbLyDLafd53irjXew9bR7jffF8fbx8+uPr37+/Pb941dPv3P93ZH4W/If6kUohXCm+Jbmh3yR0jicybwl9CFeuFILy908"
"HtIlcrlZyCNJ2q6MdGi7ZVy4tlvHJS52Y71FnHp8D+HCIYTlQuYFhdsv0yVxzZB6vsxwaZwJUumkIjWB1POdDhcqlR2KVo85"
"SoDU8NgdNodiZevqMUqB1LCVWsO2ZMQlyYs+bXEFk4m5bMJJlVgSpGjaouhQvFKxUIbUjIvI85hWW4FNvubyDnMxMkFKRc8V"
"Uml65OhQW1x9fe3XOAtsZPXJ36TIX18SaoQUnysnZsHUXPfcKqTyaSu36FHbWg0tN0jxWIXEAVLzbqcqkMpj3T8lwlBp9RhD"
"qpAaHpnzni9nRXPh6lDbysmJBVLzDtU71KztnDxqW1+JhDaKnTtUa4DUzH00Hp0VXQMHSM3c16irlpf7GEcN1dogpfpEDpAa"
"WRUOBKl0UqkIQ2qs+5IYU6OvthbFodIaF6/9i51VeF0TLZSN2lfh9T729utQOqtXKi/dl/21mihhW+M+BpIKqblypDWHSntc"
"mSA1O3nMe+6dHp0DEaRmXCU0h9p7dOYCqVm1MehOnvy7nWphSKnuu+Q++X2Ca4uQGrYkxp3yMkFLL0ygavPovmR64dhFY5QM"
"KVK1XRxqX4UydlHCXU44hY1ydndKuUBK11BzqH1NNOKNMvt27PMXVUWBemSqCVIjrr4nYFtzTSQJkJp3O7se09p9YygCKVL7"
"UN4opx5DNnE5q5AlerZ2jyExpEYmggTtMYFrzC1Bak58jetGeSvHenSip9ROik0m5lqdsxzjrCYhTM1uImOHYZzVPvnWjXIm"
"0RoaKyqhjjlqiEE3uWoYHqopbT/KY0pDD+Xtx9d8lvI0n6U8zWcpT/NpQqDms5Sn+TRVoOazlKf5LOVpPk1VqPl05AI1n6U8"
"zaepAjWfpTzNp6kKNZ/OQoGaz1Ke5rOUp/k0VaHm03mvUPOd1+esL6X5LOVpPkt5ms9SnubTVIGaz1Ke5rOUp/ks5Wk+TVWo"
"+SzlaT69mgVqPk0VqPks5Wk+S3maT1MVaj5dPwVqPkt5mk9TFWo+S3ma77x/8z56ms9SnuazlKf5LOVpPkt5ms9SnubTVIWa"
"z1Ke5jupfRWumk9TBWo+S3maz1Ke5rOUp/k0VaHms5Sn+XTnLVDzWcrTfJqqUPNZytN85/1z7rbSfJbyNN/5t06fUJrPUp7m"
"OykvE7T0wgqqdmo+Mb3Q03yCO6bSfII7ptJ8gruc0nxi+pen+eROL5yaT3CXU5pPx1Sh5hNcj0rzCajHVfMJqMdV88mdesyu"
"xwo1n+B6VJpPcD0qzSe4HpXmE1yPSvMJrkelwERVR4Waz1Ke5hNTQ3THoxO90nzFZMLTfAVnVWm+grOqNF/BWVWaTxMVar6C"
"r1FpvgK6yar56vbja76onormu8/5ViqOrNblZH6l0NPAlRq9sKaIbaFnhis15tUuH/E1oieLK1XOTIgsz3ROap9XpQ/SJWqK"
"bCYcKm6K4tp9iUqqzbd1j4qO+g2tpTV6sll1qLipk6fnw32/isDWPSruPborwz7x9eakKbbry6Gi7RN9nrhuHr4tPXXsVLT9"
"vvTdKlUQ18i9Q0Wn+2ZOlYpva0yiDhXthNz69p4S+7ZG7h0q2jma+/BIIfm2RnU4VLQ9R6hG4iWryVurhorOlNbzEJr4tubk"
"bim6e25iqbFbJY4MKfREfaXGNXKK2aF2BSapD6Oy5162yd1S5Og0iq3k5tua1WEpsus+ZO4ZS76tqU4sRc7+mAtJyL6teR8t"
"RVbDUO9yXM2a2O6jQ5GjdCi3HKpva04dluK7J1uWGtFLjhFS6J2HlZpKhzOm0JsRK5XnmjD7Izv5av0eBd7zVb5IsVU6ffTN"
"oQXf1peoeveNjZWaNURFZ0L8fTsX1s9hwO4eeHkOA3Z3Zct6ZOccgPAM0O91hR4ZPEcWMAPkdBWQvsdZj72xZuTRs2U95qFY"
"a8FZHVQpy/Mhd55YbGmPew2VGB2PRvOVsNlib0orYbO1U8fi0cbF6uQhw7jUycMybYs/dSiKwGxyLB5tXEmdM5WM4lKnGLFm"
"FFeaPTruK8ehlEcbV55n2yIwrnlOXorAuPKsxyIwrjz7l3greptzSgve+tqo2lLbcu9MQ4oiPDMpjzaueR8rUUZxqaql/T46"
"k5WiCM9fyuNpy5uZpM9WkvfaxpS1Ndd96JKV2LflUdrW1idaKOT0HNMnTCdnT/OZvcOZv5RHG5fqAJFhXLO2WykwrtlzJkV4"
"llMebVxp7kOUMopr7h1dSmcUl9LuxesT2z6kPOq4ttkkk7sj1/1JWWWnHvfdfVKE50LlUV+jObPqs2hO+zViytpSJ+CFSyu+"
"LY+yttRM3gf3HH1bHmVtzR5NXZQXcI0epW1tdyh2d86a2O52F9vR6V8FUgTm1dWjjWuepZUgMK45k2cKMC6PIjD7rh6j+gpi"
"0Y904b675/n2h3u6QteTedkoc7qy2LIeaUxpkXNAHgeV53khozOYxZb1qDpTrvAa+TxBClECvEbPlvWY5o4cA7zGNDSfFIbX"
"6NmyHmd1SEnwGgfVJ6YKr9GzZT3KebdDZIYe5bzGQLFAj54t7XHXfDkmJ6v789r17e7iTEMrxXhmUh5tXHNmainCuObMVBOO"
"y6MYzEyrx9MW2VMf4cC9NWlbzpmVoqytucPkIO12SsZ4/lKUtTX7V6LGsfi2phadlLa1nX89naUHc437uYnQni/nlEzWN/S8"
"s7TVo41LvUsW9+pwqFBl79HsPYkVr/sK9GjjYnVWSzBfqjoowXx5FN+ZC6dHG5d6WybjfM15ouYE8+VRDObC1aOOa3v+WEJq"
"Tlzb2VCRELOtbYEU47NH5dHGpd5nagzj0s+HAozLoxjMq6tHnfutHmNjblz23G/1qChra3rMOT6f3jGefRVlbamZKfR1COKa"
"PWdS1tZcXy3mnMm3pd4IGpS1Nd9Uai0Wir6t+fxxUtrWPvu27M1MG8XJ1KMz+yqK8Vmt8mjjmn1CKmcUF88zhVIzimtOtZNi"
"fO6rPGpbW9XGLrg50G5rfwNhUueu7swmEtI55yQ0m/RpqI3JPd15ujVtWY9TSbcxpSU8dSShAj16tk4b3r6dmUlI2/L27Ulp"
"W7vKLFK3uByK4nI2VP19SFEJ7EOrRxvXyESr413YhPchLsssV/0dRlEJ70PKo7a1n/vWa1rLbsu8mTooa0up8tpyEd+Wep42"
"KG1rf6su5ebkvpqztLzl3qltRSVc28ojmTM+9F2TwNm3Qgp9/eSeKnaNXFtwqH3nk1KaJE05M6ZDOdNjv9NJIvm2Zr+3lFeP"
"EvqGnH1bM/eWMtNQvFCRHnzUlJlzXMqZYFKqHHLxbdFUFIbiu+8XWmo+50vL6R06l1u/PBO/asN8B5zAmdXTDtP7r8h+jeWL"
"lFOPocYumti39SWq3v0iTvxdtDw9hhmUq9N6PbaqvzJyqyNeMi0nIm51LLbojgIrOUKP+l2yBj16tghrqxib1gqg0pLknfIq"
"bdoirJqkMMNrnDNATPgaPVuE9VBv0J7HbU107V42W44eUhSjPrF4JKyHUokZxqXeTV+exAI9pCjGp/zKIwE9dO2+XSTX1vbc"
"b6pJUYT1UOCWWw2+rdmZJkVYD1Ef0Uoi39acySdFWA9RztLVjm9LPQ0cFAENc3unJjrVsWuY0mK297EYxbrbcs7vlUfCGib3"
"bQ/GNWffMijCGkZRDHr0w+KRsIbpnem6dnZbe9VOitTsW7e3I+e7Pgnv7tfHQxvl7O7KlvU4zu95fouUUNV21RSGFk2oHhdb"
"ZGbf+b4cXf8nRlnb8maASVlbc+UkSnSb0hKox4eFIjNHz7c/aHydkvC6T9Lydo3Je+u8ZSdf+xsu06O2ta2vPr70W1l2W9v6"
"UhSbPoG+kwYnSDVnTKGvqYvfv3JuDVLom2vvpOZpvh9fizHuX71jVp79vqDcG8rrJolLnecTxe8TgMLfBTDoJteOGUVntYJr"
"5PHOVsKnUaEuJw8oE9MWA5V5e2tA9wmQrw5xQB6RrernS33VkEB1PCmKW5f7P6zudeW7TwAA"
DATA = Path(tempfile.mkdtemp(prefix="nuclear_sqd_"))
for name, blob in (("usda.snt", _USDA_SNT_GZ), ("gxpf1.snt", _GXPF1_SNT_GZ)):
(DATA / name).write_bytes(gzip.decompress(base64.b64decode(blob)))
if not (DATA / name).is_file():
raise RuntimeError(f"{name} did not unpack to {DATA}")The model space and the qubit register
An .snt file holds the model space, the single-particle energies, and the -coupled two-body
matrix elements. For the mass-dependent interactions used here, the third and fourth fields of the two-body
header specify the reference mass
at which the interaction was fitted and the exponent of its mass dependence. Both
files carry the exponent , with for USDA and for GXPF1, so the
tabulated matrix elements must be rescaled by for the nucleus being
computed [2], [3]. Single-particle energies are not rescaled. Skipping
this step changes the correlation energy by a few percent.
The energies that follow are valence energies, measured from the inert core; they are not experimental separation energies.
@dataclass(frozen=True)
class Orbital:
idx: int
n: int
ell: int
j2: int
tz: int # j2 = 2j; tz = -1 proton, +1 neutron
class SPState:
"""One m-scheme single-particle state, i.e. one qubit."""
orb: int
j2: int
mj2: int
tz: int
ell: int
spe: float # mj2 = 2 * m_j
@dataclass
class ModelSpace:
orbitals: list
spes: dict
tbmes: dict
core_z: int
core_n: int
mass_number: int
a_ref: int
mass_exponent: float
mass_factor: float
def read_snt(path, n_protons, n_neutrons):
"""Parse a .snt interaction file, applying its mass dependence for this nucleus.
The two-body header line is ``n_tbme method A_ref exponent``. When ``method`` is 1 the
tabulated matrix elements are rescaled by ``(A / A_ref) ** exponent``, where A is the mass
number of the whole nucleus -- the core plus the valence nucleons. A is derived from the
file's own core numbers rather than passed in, so it cannot silently disagree with the
valence counts the rest of the workflow uses. Single-particle energies are not rescaled.
rows = [
ln.split("!")[0].split() for ln in Path(path).read_text().splitlines()
rows = iter([r for r in rows if r])
n_p_orb, n_n_orb, core_z, core_n = (int(x) for x in next(rows)[:4])
orbitals = [
Orbital(*(int(x) for x in next(rows)[:5]))
for _ in range(n_p_orb + n_n_orb)
spes = {}
for _ in range(int(next(rows)[0])): # "i i <i|H(1b)|i>"
field = next(rows)
spes[int(field[0])] = float(field[2])
n_tbme, method, a_ref, exponent = next(rows)[:4]
n_tbme, method, a_ref, exponent = (
int(n_tbme),
int(method),
int(a_ref),
float(exponent),
mass_number = core_z + core_n + n_protons + n_neutrons
factor = (mass_number / a_ref) ** exponent if method == 1 else 1.0
tbmes = {}
for _ in range(n_tbme): # "a b c d J value"
field = next(rows)
tbmes[tuple(int(x) for x in field[:5])] = float(field[5]) * factor
return ModelSpace(
orbitals,
spes,
tbmes,
core_z,
core_n,
mass_number,
a_ref,
exponent,
factor,
def m_scheme_states(ms):
"""The qubit register: protons then neutrons, orbitals in file order, m_j descending."""
return [
SPState(o.idx, o.j2, m2, o.tz, o.ell, ms.spes[o.idx])
for tz in (-1, +1)
for o in ms.orbitals
if o.tz == tz
for m2 in range(o.j2, -o.j2 - 1, -2)
]Clebsch-Gordan recoupling
Equation (2) requires Clebsch-Gordan coefficients for half-integer angular momenta. Every argument is
passed as twice its physical value, so enters as 5 and the arithmetic stays exact.
Interaction.v_ms handles lookups of the interaction matrix elements. An .snt file stores each
matrix element once, so a lookup might need the antisymmetrized pair-exchange phase on either
side, and the bra and ket might be stored in either order.
@lru_cache(maxsize=None)
def clebsch_gordan(j1_2, j2_2, J_2, m1_2, m2_2, M_2):
"""<j1 m1 j2 m2 | J M>. Every argument is twice its physical value."""
if m1_2 + m2_2 != M_2 or not abs(j1_2 - j2_2) <= J_2 <= j1_2 + j2_2:
return 0.0
if abs(m1_2) > j1_2 or abs(m2_2) > j2_2 or abs(M_2) > J_2:
return 0.0
if (j1_2 + j2_2 - J_2) % 2 or (j1_2 - m1_2) % 2 or (j2_2 - m2_2) % 2:
return 0.0
f, half = factorial, lambda x: x // 2
prefactor = sqrt(
(J_2 + 1)
* f(half(j1_2 + j2_2 - J_2))
* f(half(j1_2 - j2_2 + J_2))
* f(half(-j1_2 + j2_2 + J_2))
/ f(half(j1_2 + j2_2 + J_2) + 1)
* f(half(J_2 + M_2))
* f(half(J_2 - M_2))
* f(half(j1_2 - m1_2))
* f(half(j1_2 + m1_2))
* f(half(j2_2 - m2_2))
* f(half(j2_2 + m2_2))
total = 0.0
for k in range(half(j1_2 + j2_2 - J_2) + 1):
d = [
half(j1_2 + j2_2 - J_2) - k,
half(j1_2 - m1_2) - k,
half(j2_2 + m2_2) - k,
half(J_2 - j2_2 + m1_2) + k,
half(J_2 - j1_2 - m2_2) + k,
if all(x >= 0 for x in d):
total += (-1) ** k / (
f(k) * f(d[0]) * f(d[1]) * f(d[2]) * f(d[3]) * f(d[4])
return prefactor * total
class Interaction:
"""Antisymmetrized m-scheme two-body matrix elements <pq||rs>, per Eq. (2)."""
def __init__(self, model_space, sp):
self.ms, self.sp, self._cache = model_space, sp, {}
def _tbme(self, oa, ob, oc, od, J, j_ab_2, j_cd_2):
"""<oa ob; J|V|oc od; J>, allowing for how the file happens to order each pair."""
table = self.ms.tbmes
# |ba; J> = -(-1)^(j_a + j_b - J) |ab; J> for a normalized antisymmetrized pair;
# dropping the leading minus makes v_ms symmetric instead of antisymmetric, and
# the Hamiltonian then fails the rotational-invariance check in Step 1.
phase_ab = -1.0 if (j_ab_2 // 2 - J) % 2 == 0 else 1.0
phase_cd = -1.0 if (j_cd_2 // 2 - J) % 2 == 0 else 1.0
for keys, phase in (
(((oa, ob, oc, od), (oc, od, oa, ob)), 1.0),
(((ob, oa, oc, od), (oc, od, ob, oa)), phase_ab),
(((oa, ob, od, oc), (od, oc, oa, ob)), phase_cd),
(((ob, oa, od, oc), (od, oc, ob, oa)), phase_ab * phase_cd),
for key in keys:
value = table.get(key + (J,))
if value is not None:
return value * phase
return 0.0
def v_ms(self, p, q, r, s):
"""<pq||rs>, zero unless M_J and charge are conserved."""
cached = self._cache.get((p, q, r, s))
if cached is not None:
return cached
P, Q, R, S = (self.sp[i] for i in (p, q, r, s))
value = 0.0
if P.mj2 + Q.mj2 == R.mj2 + S.mj2 and P.tz + Q.tz == R.tz + S.tz:
M = P.mj2 + Q.mj2
# sqrt(1 + delta): undo the normalization of the tabulated pair states
c12 = sqrt(2.0) if (P.tz == Q.tz and P.orb == Q.orb) else 1.0
c34 = sqrt(2.0) if (R.tz == S.tz and R.orb == S.orb) else 1.0
for J2 in range(
max(abs(P.j2 - Q.j2), abs(R.j2 - S.j2)),
min(P.j2 + Q.j2, R.j2 + S.j2) + 1,
2,
cg_bra = clebsch_gordan(P.j2, Q.j2, J2, P.mj2, Q.mj2, M)
cg_ket = clebsch_gordan(R.j2, S.j2, J2, R.mj2, S.mj2, M)
if abs(cg_bra) < 1e-12 or abs(cg_ket) < 1e-12:
continue
value += (
c12
* c34
* cg_bra
* cg_ket
* self._tbme(
P.orb,
Q.orb,
R.orb,
S.orb,
J2 // 2,
P.j2 + Q.j2,
R.j2 + S.j2,
self._cache[(p, q, r, s)] = value
return valueMatrix elements and the symmetry test
A determinant is a sorted tuple of occupied qubit indices. Two determinants differing in more than two occupied states have a vanishing matrix element; otherwise, the Slater-Condon rules give a short sum over the interaction, multiplied by a fermionic sign counting how many occupied states lie between the operators in the fixed register ordering.
symmetry_allowed is the integer test that all four exact quantum numbers reduce to. It is used both
to filter samples and to enumerate the exact basis for the runs small enough to check.
def matrix_element(inter, det_a, det_b):
"""<A|H|B> for two determinants, each a sorted tuple of occupied qubit indices."""
set_a, set_b = set(det_a), set(det_b)
out_a, out_b = sorted(set_a - set_b), sorted(set_b - set_a)
if len(out_a) != len(out_b) or len(out_a) > 2:
return 0.0
if not out_a: # diagonal: one-body plus two-body
return sum(inter.sp[i].spe for i in det_a) + sum(
inter.v_ms(i, j, i, j)
for i, j in itertools.combinations(det_a, 2)
if len(out_a) == 1: # one state moves, p -> q
p, q = out_a[0], out_b[0]
crossings = sum(1 for k in set_a if min(p, q) < k < max(p, q))
return (-1.0) ** crossings * sum(
inter.v_ms(p, j, q, j) for j in det_a if j not in (p, q)
(p, r), (q, s) = out_a, out_b # two states move
crossings = sum(1 for k in set_a if p < k < r) + sum(
1 for k in set_b if q < k < s
return (-1.0) ** crossings * inter.v_ms(p, r, q, s)
def subspace_hamiltonian(inter, dets):
"""Dense real-symmetric H projected onto the span of `dets`."""
H = np.zeros((len(dets), len(dets)))
for a, det_a in enumerate(dets):
H[a, a] = matrix_element(inter, det_a, det_a)
for b in range(a + 1, len(dets)):
H[a, b] = H[b, a] = matrix_element(inter, det_a, dets[b])
return H
def ground_state(inter, dets):
"""Lowest eigenvalue and eigenvector of H over `dets`."""
values, vectors = np.linalg.eigh(subspace_hamiltonian(inter, dets))
return values[0], vectors[:, 0]
def symmetry_allowed(
sp, det, n_protons, n_neutrons, mj2_target=0, parity_target=0
"""The four exact shell-model quantum numbers, as integer tests on one determinant."""
n_p = sum(1 for i in det if sp[i].tz == -1)
return (
n_p == n_protons
and len(det) - n_p == n_neutrons
and sum(sp[i].mj2 for i in det) == mj2_target
and sum(sp[i].ell for i in det) % 2 == parity_target
def full_basis(sp, n_protons, n_neutrons, **targets):
"""Every symmetry-allowed determinant. Only tractable for small model spaces."""
protons = [i for i, s in enumerate(sp) if s.tz == -1]
neutrons = [i for i, s in enumerate(sp) if s.tz == +1]
return [
p + n
for p in itertools.combinations(protons, n_protons)
for n in itertools.combinations(neutrons, n_neutrons)
if symmetry_allowed(sp, p + n, n_protons, n_neutrons, **targets)
def count_basis(sp, n_protons, n_neutrons, mj2_target=0, parity_target=0):
"""How many determinants `full_basis` would return, without enumerating them.
A dynamic program over (occupied count, sum of 2*m_j, parity) per species. This stays
cheap when the basis itself is far too large to build, which is how the largest run below
can report the size of the space it is sampling from.
def species(states, k):
table = {(0, 0, 0): 1}
for s in states:
for key, value in list(table.items()):
count, m_sum, parity = key
if count < k:
nxt = (count + 1, m_sum + s.mj2, (parity + s.ell) % 2)
table[nxt] = table.get(nxt, 0) + value
totals = {}
for (count, m_sum, parity), value in table.items():
if count == k:
totals[(m_sum, parity)] = (
totals.get((m_sum, parity), 0) + value
return totals
left = species([s for s in sp if s.tz == -1], n_protons)
right = species([s for s in sp if s.tz == +1], n_neutrons)
return sum(
a * b
for (mp, pp), a in left.items()
for (mn, pn), b in right.items()
if mp + mn == mj2_target and (pp + pn) % 2 == parity_target
)The reference determinant
The ansatz is built on top of a single determinant, so that determinant should be the best one available. Filling the lowest single-particle energies ignores the two-body interaction. In these model spaces, that choice gives an energy 1–2 MeV above the lowest-energy determinant.
Restricting to fillings made of time-reversed pairs forces exactly and leaves only candidates per species (a few thousand at most), so the best one can be found by searching them all on the full diagonal . Ties go to the most strongly aligned pairs, where the pairing force is strongest. In every case in this tutorial that can be checked against a full enumeration, the search returns the global lowest-diagonal determinant, which is also the largest single component of the exact ground state.
def reference_determinant(sp, inter, n_protons, n_neutrons):
"""Lowest-diagonal determinant built from time-reversed (+m_j, -m_j) orbital pairs."""
if n_protons % 2 or n_neutrons % 2:
raise ValueError(
"an odd valence count has no time-reversed paired reference at M_J = 0"
def species_pairs(tz):
return [
q,
next(
p
for p, t in enumerate(sp)
if t.tz == tz and t.orb == s.orb and t.mj2 == -s.mj2
for q, s in enumerate(sp)
if s.tz == tz and s.mj2 > 0
best = None
for chosen_p in itertools.combinations(species_pairs(-1), n_protons // 2):
protons = tuple(q for pair in chosen_p for q in pair)
for chosen_n in itertools.combinations(
species_pairs(+1), n_neutrons // 2
det = tuple(
sorted(protons + tuple(q for pair in chosen_n for q in pair))
# break ties toward the most aligned pairs, where J = 0 pairing is strongest
score = (
matrix_element(inter, det, det),
-sum(abs(sp[q].mj2) for q in det),
if best is None or score < best[0]:
best = (score, det)
return best[1]The excitation pool and its perturbative ranking
Correlation is carried by two-particle–two-hole () excitations from the reference. Two selection rules reduce the pool before any circuit is built: an excitation must conserve , and the hole pair and particle pair must be able to couple to a common total , which is a triangle inequality.
The remaining excitations are ranked by the Epstein-Nesbet second-order score of selected configuration interaction [4],
which estimates how much correlation energy each excitation carries. The same two numbers fix the circuit angle: with , the first-order amplitude is . The Appendix explains why the first-order amplitude is the choice used in this tutorial rather than the exact two-level angle.
def excitation_pool(sp, occ):
"""2p2h quadruples (h1, h2, v1, v2): same-species pairs, then proton-neutron pairs."""
holes = {tz: [i for i in occ if sp[i].tz == tz] for tz in (-1, +1)}
virtuals = {
tz: [i for i, s in enumerate(sp) if s.tz == tz and i not in occ]
for tz in (-1, +1)
pool = [
(h1, h2, v1, v2)
for tz in (-1, +1)
for h1, h2 in itertools.combinations(holes[tz], 2)
for v1, v2 in itertools.combinations(virtuals[tz], 2)
pool += [
(h1, h2, v1, v2)
for h1 in holes[-1]
for h2 in holes[+1]
for v1 in virtuals[-1]
for v2 in virtuals[+1]
return pool
def conserves_symmetry(sp, op):
"""Keeps M_J, and the hole and particle pairs share a reachable total J."""
h1, h2, v1, v2 = op
if sp[v1].mj2 + sp[v2].mj2 != sp[h1].mj2 + sp[h2].mj2:
return False
return max(abs(sp[v1].j2 - sp[v2].j2), abs(sp[h1].j2 - sp[h2].j2)) <= min(
sp[v1].j2 + sp[v2].j2, sp[h1].j2 + sp[h2].j2
def en_denominator(inter, occ, holes, virtuals, floor=0.1):
"""Epstein-Nesbet gap: bare gap, spectator rearrangement, and the pair's own term."""
gap = sum(inter.sp[h].spe for h in holes) - sum(
inter.sp[v].spe for v in virtuals
for k in occ:
if k in holes:
continue
gap += sum(inter.v_ms(h, k, h, k) for h in holes)
gap -= sum(inter.v_ms(v, k, v, k) for v in virtuals)
gap += inter.v_ms(holes[0], holes[1], holes[0], holes[1])
gap -= inter.v_ms(virtuals[0], virtuals[1], virtuals[0], virtuals[1])
return gap if abs(gap) >= floor else (floor if gap >= 0 else -floor)
def rank_pool(inter, occ, pool):
"""Sort by descending PT2 score; return (operator, coupling, first-order amplitude)."""
ranked = []
for op in pool:
h1, h2, v1, v2 = op
coupling = inter.v_ms(v1, v2, h1, h2)
gap = en_denominator(inter, occ, (h1, h2), (v1, v2))
ranked.append((coupling**2 / abs(gap), op, coupling, coupling / gap))
ranked.sort(key=lambda row: (-row[0], row[1])) # deterministic on ties
return [
(op, coupling, amplitude) for _, op, coupling, amplitude in ranked
]Qubit-excitation blocks
Under the Jordan-Wigner mapping a particle-conserving excitation operator becomes a sum of eight Pauli strings, each carrying a string of operators between the outermost indices. The strings enforce fermionic antisymmetry, and they are expensive: a proton-neutron excitation spans the boundary between the two halves of the register and includes a parity string across that boundary.
Dropping the strings gives the qubit-excitation operator of Yordanov et al. [5]. The state prepared by this operator has different amplitudes, but it connects exactly the same pairs of determinants, so the set of determinants the circuit can reach is unchanged. Pooled SQD uses these determinants for the classical diagonalization. Step 2 compares the support of the two constructions and measures their hardware costs.
Building the Pauli form from , with the
string optional, keeps the two constructions a single flag apart. All eight terms of one generator
commute, so a single PauliEvolutionGate step is the exact exponential rather than a Trotter
approximation to it.
def _ladder(num_qubits, q, dagger, parity):
"""Pauli form of a_q or a_q^dagger. `parity` toggles the Jordan-Wigner Z string."""
prefix = (
["Z"] * q + ["I"] * (num_qubits - q) if parity else ["I"] * num_qubits
x_part, y_part = list(prefix), list(prefix)
x_part[q], y_part[q] = "X", "Y"
return SparsePauliOp(
["".join(reversed(x_part)), "".join(reversed(y_part))],
coeffs=[0.5, 0.5 * (-1j if dagger else 1j)],
def excitation_generator(num_qubits, op, parity=False):
"""Hermitian H with exp(-i theta H) = exp(theta (T - T^dagger)) for T = a+ a+ a a."""
h1, h2, v1, v2 = op
T = SparsePauliOp("I" * num_qubits)
for q, dagger in ((v1, True), (v2, True), (h2, False), (h1, False)):
T = (T @ _ladder(num_qubits, q, dagger, parity)).simplify()
return (1j * (T - T.adjoint())).simplify()
def excitation_block(op, theta, parity=False):
"""(window, circuit) for one excitation.
A qubit excitation touches only its four qubits. A fermionic excitation also carries Z
operators on every qubit between the outermost indices, so its window is the whole span --
which is exactly where its extra cost comes from.
window = list(range(min(op), max(op) + 1)) if parity else sorted(op)
local = tuple(window.index(i) for i in op)
generator = excitation_generator(len(window), local, parity=parity)
return window, PauliEvolutionGate(generator, time=theta).definition
def excitation_ansatz(
num_qubits, occ, operators, amplitudes, measure=True, parity=False
"""X gates for the reference determinant, then one evolution block per excitation."""
for q in occ:
qc.x(q)
for op, theta in zip(operators, amplitudes):
if abs(theta) < 1e-12:
continue
window, block = excitation_block(op, theta, parity=parity)
qc.compose(block, qubits=window, inplace=True)
if measure:
qc.measure_all()
return qcThe depth budget and the circuit ensemble
A single deep circuit containing every ranked excitation can exceed the hardware's coherence time. Spreading the pool over an ensemble of shallow circuits and pooling their shots into one determinant set turns Step 2 into a packing problem: each excitation has a measured cost, each circuit has a budget, and the question is how much of the ranked pool fits.
The budget is measured in two-qubit depth (layers of two-qubit gates on the critical path) rather than in a raw gate count, because depth sets the circuit's duration and therefore how much of the device's coherence it spends. The total count is reported alongside it, since that is the better proxy for accumulated gate error; the two answer different questions and neither substitutes for the other.
Both quantities are extracted by arity: an instruction acting on exactly two qubits, whatever the backend happens to call its entangling gate. Matching on gate names instead could return zero for an unfamiliar basis set, incorrectly placing the whole pool in one circuit without exceeding the computed budget.
Filling whichever circuit is currently emptiest, in rank order, keeps every circuit near the budget. Costs are measured on the real backend target, one excitation at a time, because a cost read off an abstract circuit is not the cost the transpiler produces.
DIRECTIVES = ("barrier", "delay")
def is_two_qubit(instruction):
"""True for an operation on exactly two qubits, excluding directives.
Selecting by arity rather than by gate name keeps this correct on any backend, whatever its
two-qubit basis gate happens to be called -- cz on today's Heron devices, ecr on Eagle, or
something newer tomorrow. A gate-name allow-list silently returns zero on anything it has
not heard of, which would collapse the whole pool into one circuit and pass every budget
check. Barriers are excluded because a barrier spanning two qubits is not a gate.
return (
len(instruction.qubits) == 2
and instruction.operation.name not in DIRECTIVES
def two_qubit_count(qc):
"""How many two-qubit gates the circuit contains: the accumulated-gate-error proxy."""
return sum(1 for instruction in qc.data if is_two_qubit(instruction))
def two_qubit_depth(qc):
"""Layers of two-qubit gates on the critical path: the duration and decoherence proxy.
This is what the budget is measured in. Two gates on disjoint qubit pairs run in the same
layer, so depth tracks how long the circuit takes -- and therefore how much coherence it
spends -- while the count above tracks how much gate error it accumulates. Both are
reported; only depth is budgeted.
return qc.depth(filter_function=is_two_qubit)
def excitation_costs(num_qubits, ranked, pm, parity=False):
"""Transpiled two-qubit depth of each excitation on its own."""
return [
two_qubit_depth(
pm.run(
excitation_ansatz(
num_qubits, (), [op], [amp], measure=False, parity=parity
for op, _, amp in ranked
def pack_ensemble(
num_qubits, occ, ranked, costs, budget, n_circuits, parity=False
"""Fill n_circuits in rank order, always adding to whichever is currently emptiest."""
bins, loads = [[] for _ in range(n_circuits)], [0] * n_circuits
for (op, _, amplitude), cost in zip(ranked, costs):
emptiest = min(range(n_circuits), key=lambda b: loads[b])
if loads[emptiest] + cost > budget:
break # every circuit is full
bins[emptiest].append((op, amplitude))
loads[emptiest] += cost
circuits = [
excitation_ansatz(
num_qubits,
occ,
[o for o, _ in b],
[a for _, a in b],
parity=parity,
for b in bins
return circuits, bins
def pack_to_budget(
num_qubits, occ, ranked, costs, budget, n_circuits, pm, attempts=6
"""Pack, transpile, and shrink the target until the assembled circuits really fit.
Costs are measured one excitation at a time, but excitations that share qubits neither add
nor parallelize cleanly once the transpiler routes them together, so the assembled depth is
not the sum of its measured parts. This loop closes that gap against the real transpiler,
and it runs entirely before any job is submitted -- a budget failure must never cost shots.
target = budget
for attempt in range(attempts):
circuits, bins = pack_ensemble(
num_qubits, occ, ranked, costs, target, n_circuits, parity=False
isa = pm.run(circuits)
worst = max(two_qubit_depth(c) for c in isa)
if worst <= budget:
return circuits, bins, isa
target = max(min(costs), int(target * budget / worst * 0.95))
raise RuntimeError(
f"could not fit {n_circuits} circuits inside a two-qubit depth of {budget} in "
f"{attempts} attempts; raise N_CIRCUITS or DEPTH_BUDGET and re-run this cell. "
"No QPU time was spent."
)Post-processing: repair, recombine, diagonalize
Three helpers do the work of Step 4.
half_configurations splits each sampled row into a proton half and a neutron half, and keeps each
half that has the correct nucleon number. A row with a valid proton half contributes that half even if its
neutron half has the wrong nucleon number. Each half carries the total sampled weight of the rows it appeared in, which
is what ranks it if the subspace needs to be truncated.
grow_subspace recombines the halves into every product that lands in the target and parity
sector, adding to the subspace it is given rather than rebuilding it. That keeps successive
subspaces nested, which is what makes the energy sequence monotone non-increasing instead of merely
fluctuating around a bound.
recovery_loop is the self-consistent configuration recovery of the pooled SQD paper
[1]: repair the two half-register nucleon numbers against the current occupancy
estimate, recombine, diagonalize, and take the next occupancy estimate from the eigenvector.
Check the bit-ordering conventions carefully to avoid incorrect results. qiskit-addon-sqd writes column 0 of its
bitstring matrix as the highest qubit index, so reversing a row gives occupation indexed by qubit;
its "right" half is the low qubit indices, which is the proton block. Correspondingly,
recover_configurations takes num_elec_a as the proton number and average occupancies ordered
(protons, neutrons) by qubit index. The addon assumes bit pairs with bit ; in this
register, proton qubit and neutron qubit are the same state, so the
assumption is physically meaningful here rather than incidental.
def half_configurations(
bitstring_matrix, probabilities, sp, n_protons, n_neutrons
"""Split each row into proton and neutron halves, keeping each half on its own weight.
Column 0 of the addon's matrix is the highest qubit index, so reversing a row gives
occupation indexed by qubit.
protons, neutrons = {}, {}
for row, weight in zip(
bitstring_matrix, np.asarray(probabilities, dtype=float)
occupied = np.flatnonzero(row[::-1])
p = tuple(int(i) for i in occupied if sp[i].tz == -1)
n = tuple(int(i) for i in occupied if sp[i].tz == +1)
if len(p) == n_protons:
protons[p] = protons.get(p, 0.0) + weight
if len(n) == n_neutrons:
neutrons[n] = neutrons.get(n, 0.0) + weight
return protons, neutrons
def product_subspace(sp, protons, neutrons, n_protons, n_neutrons, **targets):
"""Every (proton half) x (neutron half) product that lands in the target sector."""
return sorted(
d
for d in (
tuple(sorted(tuple(p) + tuple(n)))
for p in protons
for n in neutrons
if symmetry_allowed(sp, d, n_protons, n_neutrons, **targets)
def grow_subspace(
sp,
kept_protons,
kept_neutrons,
offered_protons,
offered_neutrons,
n_protons,
n_neutrons,
max_dimension=None,
**targets,
"""Add as many offered halves as the dimension cap allows, never dropping a kept one."""
kept_p, kept_n = list(kept_protons), list(kept_neutrons)
new_p = [c for c in offered_protons if c not in set(kept_p)]
new_n = [c for c in offered_neutrons if c not in set(kept_n)]
if max_dimension is None:
kept_p, kept_n = kept_p + new_p, kept_n + new_n
return (
product_subspace(
sp, kept_p, kept_n, n_protons, n_neutrons, **targets
kept_p,
kept_n,
basis = product_subspace(
step = max(1, (len(new_p) + len(new_n)) // 24)
taken_p = taken_n = 0
while taken_p < len(new_p) or taken_n < len(new_n):
try_p, try_n = (
min(taken_p + step, len(new_p)),
min(taken_n + step, len(new_n)),
candidate = product_subspace(
sp,
kept_p + new_p[:try_p],
kept_n + new_n[:try_n],
n_protons,
n_neutrons,
**targets,
if len(candidate) > max_dimension:
if step == 1:
break
step = max(1, step // 2)
continue
basis, taken_p, taken_n = candidate, try_p, try_n
return basis, kept_p + new_p[:taken_p], kept_n + new_n[:taken_n]
def occupancies(sp, dets, vector):
"""Average occupancy of each qubit in a subspace eigenvector, as (protons, neutrons)."""
half = len(sp) // 2
occ = np.zeros(len(sp))
for weight, det in zip(np.abs(vector) ** 2, dets):
for q in det:
occ[q] += weight
return occ[:half], occ[half:]
def sample_occupancies(sp, bitstring_matrix, probabilities):
"""The same quantity estimated directly from sampled bitstrings."""
half = len(sp) // 2
weights = np.asarray(probabilities, dtype=float)
occ = (weights[:, None] * bitstring_matrix[:, ::-1]).sum(
axis=0
) / weights.sum()
return occ[:half], occ[half:]def recovery_loop(
inter,
sp,
bitstring_matrix,
probabilities,
reference,
n_protons,
n_neutrons,
max_iterations=4,
energy_tol=1e-4,
max_dimension=None,
seed=None,
**targets,
"""Self-consistent configuration recovery, diagonalizing in the product subspace.
`num_elec_a` is the proton number and `num_elec_b` the neutron number, matching the
addon's right/left bipartition of the bitstring matrix.
half = len(sp) // 2
p_ref = tuple(i for i in reference if sp[i].tz == -1)
n_ref = tuple(i for i in reference if sp[i].tz == +1)
survivors, survivor_probs = postselect_by_hamming_right_and_left(
bitstring_matrix,
np.asarray(probabilities, dtype=float).copy(),
hamming_right=n_protons,
hamming_left=n_neutrons,
if len(survivors):
guess = sample_occupancies(sp, survivors, survivor_probs)
else: # nothing survived: start from the reference itself
guess = (
np.array([1.0 if q in p_ref else 0.0 for q in range(half)]),
np.array(
[1.0 if q + half in n_ref else 0.0 for q in range(half)]
weights_p, weights_n = {p_ref: np.inf}, {n_ref: np.inf}
kept_p, kept_n = [p_ref], [n_ref]
history, best = [], None
for iteration in range(max_iterations):
# keep the occupancy estimate strictly inside (0, 1): the heuristic divides by it
clipped = tuple(np.clip(a, 1e-4, 1.0 - 1e-4) for a in guess)
recovered, recovered_probs = recover_configurations(
bitstring_matrix,
probabilities,
clipped,
n_protons,
n_neutrons,
rand_seed=None if seed is None else seed + iteration,
new_p, new_n = half_configurations(
recovered, recovered_probs, sp, n_protons, n_neutrons
for config, weight in new_p.items():
weights_p[config] = weights_p.get(config, 0.0) + weight
for config, weight in new_n.items():
weights_n[config] = weights_n.get(config, 0.0) + weight
def order(w):
return sorted(w, key=lambda c: (-w[c], c))
basis, kept_p, kept_n = grow_subspace(
sp,
kept_p,
kept_n,
order(weights_p),
order(weights_n),
n_protons,
n_neutrons,
max_dimension=max_dimension,
**targets,
energy, vector = ground_state(inter, basis)
history.append(
dict(
iteration=iteration + 1,
energy=energy,
dimension=len(basis),
protons=len(kept_p),
neutrons=len(kept_n),
recovered=len(recovered),
survivors=len(survivors),
f" iteration {iteration + 1}: {len(kept_p)} proton x {len(kept_n)} neutron "
f"halves -> dimension {len(basis)}, E = {energy:.6f} MeV"
if best is None or energy < best[0]:
best = (energy, basis, vector)
guess = occupancies(
sp, basis, vector
) # the self-consistent update
if (
len(history) > 1
and abs(history[-2]["energy"] - energy) < energy_tol
break
return dict(
energy=best[0], basis=best[1], vector=best[2], history=history
)Backend, budget, and run parameters
Every run that follows uses the same backend, the same pass managers, and the same depth budget, so the three are directly comparable. The budget ties them together: every circuit in every ensemble has to fit inside it, and it decides how much of a pool can be sampled at all.
The values here were chosen by measuring transpiled cost against a Heron target. At a two-qubit depth of 300 and 16 circuits, both 24-qubit and 40-qubit ensembles come out well under 100 microseconds per circuit, against coherence times of a few hundred microseconds. Increasing the budget includes more of the pool but increases circuit duration. Measure this tradeoff for your backend.
# This example assumes you have saved your IBM Quantum Platform account locally.
backend = service.least_busy(
operational=True, simulator=False, min_num_qubits=40
optimization_level=3, backend=backend, seed_transpiler=42
costing_manager = generate_preset_pass_manager(
optimization_level=1, backend=backend, seed_transpiler=42
DEPTH_BUDGET = 300 # two-qubit depth per circuit
N_CIRCUITS = 16 # circuits per ensemble
SHOTS = 10_000 # shots per circuit
MAX_DIMENSION = 4_000 # largest subspace the dense solver here will build
JOB_TAGS = ["TUT_SBQDNH"] # initials of the title's content words
# derive the two-qubit basis gate from the target by arity, not from a hard-coded name
two_qubit_basis = sorted(
name
for name in backend.target.operation_names
if backend.target.operation_from_name(name).num_qubits == 2
if not two_qubit_basis:
raise RuntimeError(
f"{backend.name} exposes no two-qubit gate; pick another backend"
f"{backend.name}: {backend.num_qubits} qubits, two-qubit basis gate {two_qubit_basis[0]}"
f"two-qubit depth budget {DEPTH_BUDGET}, {N_CIRCUITS} circuits x {SHOTS:,} shots per run"
f"three runs: {3 * N_CIRCUITS} circuits, {3 * N_CIRCUITS * SHOTS:,} shots in total"
)ibm_phoenix: 120 qubits, two-qubit basis gate cz
two-qubit depth budget 300, 16 circuits x 10,000 shots per run
three runs: 48 circuits, 480,000 shots in totalSmall-scale hardware example
This section follows the four-step workflow on a QPU, using the same backend and the same gate budget as the large-scale runs. The smaller problem provides an exact reference for checking the result.
The small-scale problem is : two valence protons and two valence neutrons in the shell above an core, with the USDA interaction [2]. Three orbitals per species give 24 qubits, and the complete symmetry-allowed basis is 640 determinants, small enough to compare the energy estimates with the exact answer.
Read the interaction, build the register, and construct the reference determinant. The following table shows the register information from the Background, read directly from the interaction file.
N_PROTONS, N_NEUTRONS = 2, 2
ms_sd = read_snt(DATA / "usda.snt", N_PROTONS, N_NEUTRONS)
sp_sd = m_scheme_states(ms_sd)
inter_sd = Interaction(ms_sd, sp_sd)
occ_sd = reference_determinant(sp_sd, inter_sd, N_PROTONS, N_NEUTRONS)
# post-selection splits the register in half, so the two species must contribute equally
n_proton_states = sum(1 for s in sp_sd if s.tz == -1)
if n_proton_states != len(sp_sd) - n_proton_states:
raise ValueError(
"this workflow needs equal proton and neutron state counts"
SHELL_LABEL = {0: "s", 1: "p", 2: "d", 3: "f", 4: "g"}
f"core Z={ms_sd.core_z} N={ms_sd.core_n} plus {N_PROTONS}p + {N_NEUTRONS}n valence "
f"-> A={ms_sd.mass_number} on {len(sp_sd)} qubits"
f"interaction: {len(ms_sd.tbmes)} J-coupled matrix elements, fitted at "
f"A_ref={ms_sd.a_ref}, rescaled by (A/A_ref)^{ms_sd.mass_exponent:g} = "
f"{ms_sd.mass_factor:.6f}\n"
f"{'orbital':>9} {'SPE (MeV)':>10} {'proton qubits':>14} {'neutron qubits':>15}"
for o in (o for o in ms_sd.orbitals if o.tz == -1):
twin = next(
t
for t in ms_sd.orbitals
if t.tz == +1 and (t.n, t.ell, t.j2) == (o.n, o.ell, o.j2)
qp = [q for q, s in enumerate(sp_sd) if s.orb == o.idx]
qn = [q for q, s in enumerate(sp_sd) if s.orb == twin.idx]
f"{f'{o.n}{SHELL_LABEL[o.ell]}{o.j2}/2':>9} {ms_sd.spes[o.idx]:>10.4f} "
f"{f'{qp[0]}-{qp[-1]}':>14} {f'{qn[0]}-{qn[-1]}':>15}"
print(f"\nreference determinant occupies qubits {occ_sd}")
f" M_J = {sum(sp_sd[i].mj2 for i in occ_sd) / 2:g}, "
f"parity = {(-1) ** (sum(sp_sd[i].ell for i in occ_sd) % 2):+d}, "
f"energy = {matrix_element(inter_sd, occ_sd, occ_sd):.6f} MeV"
)core Z=8 N=8 plus 2p + 2n valence -> A=20 on 24 qubits
interaction: 158 J-coupled matrix elements, fitted at A_ref=18, rescaled by (A/A_ref)^-0.3 = 0.968886
orbital SPE (MeV) proton qubits neutron qubits
0d3/2 2.1117 0-3 12-15
0d5/2 -3.9257 4-9 16-21
1s1/2 -3.2079 10-11 22-23
reference determinant occupies qubits (4, 9, 16, 21)
M_J = 0, parity = +1, energy = -29.765549 MeVRun two checks on the Hamiltonian before continuing. Both are inexpensive and can reveal recoupling errors that a single energy calculation might not detect.
A rotationally invariant Hamiltonian organizes its eigenstates into multiplets, so every eigenvalue of the sector must also appear in the spectrum at the same energy. The gap between the ground state and the lowest state carrying is the excitation energy, which is measured: MeV for [6]. An empirical -shell interaction is expected to agree within a few hundred keV.
basis_exact_sd = full_basis(sp_sd, N_PROTONS, N_NEUTRONS)
if len(basis_exact_sd) != count_basis(sp_sd, N_PROTONS, N_NEUTRONS):
raise AssertionError("the basis counter disagrees with the enumeration")
E_REF_SD = matrix_element(inter_sd, occ_sd, occ_sd)
E_EXACT_SD, _ = ground_state(inter_sd, basis_exact_sd)
# the M_J = 2 sector: its spectrum must be contained in the M_J = 0 spectrum
basis_mj2 = full_basis(sp_sd, N_PROTONS, N_NEUTRONS, mj2_target=4)
spectrum_0 = np.linalg.eigvalsh(
subspace_hamiltonian(inter_sd, basis_exact_sd)
spectrum_2 = np.linalg.eigvalsh(subspace_hamiltonian(inter_sd, basis_mj2))
contained = sum(
1 for e in spectrum_2 if np.min(np.abs(spectrum_0 - e)) < 1e-7
if contained != len(spectrum_2):
f"rotational invariance broken: only {contained}/{len(spectrum_2)} "
"M_J=2 eigenvalues appear in the M_J=0 spectrum"
f"rotational invariance: all {contained} M_J=2 eigenvalues found in the M_J=0 spectrum"
f"E(2+) - E(0+) = {spectrum_2[0] - E_EXACT_SD:.3f} MeV (experiment: 1.634 MeV)\n"
print(f"reference determinant {E_REF_SD:11.6f} MeV")
f"exact diagonalization {E_EXACT_SD:11.6f} MeV (dimension {len(basis_exact_sd)})"
print(f"correlation energy to find {E_EXACT_SD - E_REF_SD:11.6f} MeV")rotational invariance: all 497 M_J=2 eigenvalues found in the M_J=0 spectrum
E(2+) - E(0+) = 1.747 MeV (experiment: 1.634 MeV)
reference determinant -29.765549 MeV
exact diagonalization -40.472331 MeV (dimension 640)
correlation energy to find -10.706782 MeVNext, construct the operator pool. Applying the two selection rules gives an important result: for this reference, in this model space, there are no allowed single excitations at all.
A excitation conserves only if the particle state has the same as the hole. The reference occupies the two states of largest in the lowest orbital ( of ), and no other orbital in the shell reaches , since stops at and at . Therefore, no single excitation survives, and correlation is carried entirely by excitations. This is a property of the reference and the shell, not a general law; the following cell counts it rather than assuming it.
raw_pool_sd = excitation_pool(sp_sd, occ_sd)
pool_sd = [op for op in raw_pool_sd if conserves_symmetry(sp_sd, op)]
ranked_sd = rank_pool(inter_sd, occ_sd, pool_sd)
singles_sd = [
(h, v)
for h in occ_sd
for v in range(len(sp_sd))
if v not in occ_sd and sp_sd[h].tz == sp_sd[v].tz
singles_mj_sd = [
(h, v) for h, v in singles_sd if sp_sd[h].mj2 == sp_sd[v].mj2
f"1p1h: {len(singles_sd):4d} raw -> {len(singles_mj_sd):3d} conserve M_J"
f"2p2h: {len(raw_pool_sd):4d} raw -> {len(pool_sd):3d} conserve M_J and couple to a common J\n"
f"{'rank':>4} {'holes':>9} {'particles':>11} {'<ref|H|a> (MeV)':>16} {'amplitude':>10}"
for r, (op, coupling, amplitude) in enumerate(ranked_sd[:8], start=1):
f"{r:>4} {f'{op[0]},{op[1]}':>9} {f'{op[2]},{op[3]}':>11} "
f"{coupling:>16.4f} {amplitude:>10.4f}"
# what is the best this ansatz could possibly do? Apply every excitation once and recombine.
reachable = {occ_sd}
for op, _, _ in ranked_sd:
h1, h2, v1, v2 = op
reachable |= {
tuple(sorted(set(d) - {h1, h2} | {v1, v2}))
for d in reachable
if {h1, h2} <= set(d) and not {v1, v2} & set(d)
ceiling = product_subspace(
sp_sd,
{tuple(i for i in d if sp_sd[i].tz == -1) for d in reachable},
{tuple(i for i in d if sp_sd[i].tz == +1) for d in reachable},
N_PROTONS,
N_NEUTRONS,
f"\nthe pool reaches {len(reachable)} determinants, whose product subspace spans "
f"{len(ceiling)} of {len(basis_exact_sd)}"
)1p1h: 40 raw -> 0 conserve M_J
2p2h: 490 raw -> 78 conserve M_J and couple to a common J
rank holes particles <ref|H|a> (MeV) amplitude
1 4,9 0,3 -1.8714 0.1375
2 16,21 12,15 -1.8714 0.1375
3 4,21 3,12 1.6775 -0.1029
4 9,16 0,15 1.6775 -0.1029
5 4,9 10,11 -0.8728 0.1168
6 16,21 22,23 -0.8728 0.1168
7 4,21 3,17 1.0622 -0.0882
8 4,21 8,12 -1.0622 0.0882
the pool reaches 412 determinants, whose product subspace spans 640 of 640Step 2: Optimize problem for quantum hardware execution
Transpilation reveals the hardware cost of the Jordan-Wigner strings and the savings from using qubit excitations. The first cell measures both constructions against the real backend target and checks the claim, introduced in the Setup, that dropping the strings changes the amplitudes but not the set of determinants the circuit can reach.
Compare two consequences of this substitution. A qubit excitation costs the same regardless of the distance between its indices, so proton-neutron excitations, which span the boundary between the two halves of the register and make up most of the pool, no longer have this additional cost. The whole pool then fits inside the budget, which means the limit on the result is sampling rather than circuit depth.
# 1. do the two constructions reach the same determinants?
# Apply one block to the reference on the window it spans and read off which basis states
# acquire amplitude. Column 0 of the unitary is the image of |0...0>, and the X gates that
# place the reference are part of the circuit, so that column is exactly what is wanted.
# A fermionic block's window is its whole span, and building a unitary on it costs 4^n, so
# probe the narrowest excitations in the pool rather than the highest-ranked ones.
PROBE_SPAN = 12
narrow = sorted(ranked_sd, key=lambda row: max(row[0]) - min(row[0]))
probes = [op for op, _, _ in narrow if max(op) - min(op) + 1 <= PROBE_SPAN][
:3
if len(probes) < 2:
raise RuntimeError(
f"no excitation spans {PROBE_SPAN} qubits or fewer; raise PROBE_SPAN"
f"{'excitation':>16} {'span':>5} {'reachable determinants':>22} {'same as fermionic?':>19}"
for probe_op in probes:
probe_window = list(range(min(probe_op), max(probe_op) + 1))
probe_local = tuple(probe_window.index(i) for i in probe_op)
probe_occ = tuple(
probe_window.index(i) for i in occ_sd if i in probe_window
supports = {}
for parity in (True, False):
unitary = Operator(
excitation_ansatz(
len(probe_window),
probe_occ,
[probe_local],
[0.7],
measure=False,
parity=parity,
).data
supports[parity] = frozenset(
np.flatnonzero(np.abs(unitary[:, 0]) > 1e-10).tolist()
if len(supports[True]) < 2:
f"{probe_op}: the block did not move any amplitude, so this "
"comparison would be vacuous"
if supports[True] != supports[False]:
f"{probe_op}: the two constructions reach different determinants"
f"{str(probe_op):>16} {len(probe_window):>5} {len(supports[True]):>22} {'yes':>19}"
"\n-> identical support; the amplitudes differ, and pooled SQD only consumes the support\n"
# 2. what does each one cost on this backend?
cost_qeb = excitation_costs(
len(sp_sd), ranked_sd, costing_manager, parity=False
cost_jw = excitation_costs(
len(sp_sd), ranked_sd, costing_manager, parity=True
def species(op):
return "same" if len({sp_sd[i].tz for i in op}) == 1 else "pn"
f"{'excitation':>10} {'count':>5} {'QEB 2q depth':>14} {'fermionic 2q depth':>19}"
for group in ("same", "pn"):
q = [
c
for (op, _, _), c in zip(ranked_sd, cost_qeb)
if species(op) == group
j = [
c for (op, _, _), c in zip(ranked_sd, cost_jw) if species(op) == group
f"{group:>10} {len(q):>5} {f'{min(q)}-{max(q)}':>14} {f'{min(j)}-{max(j)}':>19}"
f"{'pool total':>10} {len(ranked_sd):>5} {sum(cost_qeb):>14} {sum(cost_jw):>19}"
f"\nfermionic / qubit-excitation cost ratio: {sum(cost_jw) / sum(cost_qeb):.2f}x"
f"\nensemble capacity: {N_CIRCUITS} circuits at two-qubit depth {DEPTH_BUDGET}"
) excitation span reachable determinants same as fermionic?
(4, 9, 5, 8) 6 2 yes
(16, 21, 17, 20) 6 2 yes
(4, 9, 6, 7) 6 2 yes
excitation count QEB 2q depth fermionic 2q depth
same 26 40-48 48-144
pn 52 48-48 48-256
pool total 78 3728 9112
fermionic / qubit-excitation cost ratio: 2.44x
ensemble capacity: 16 circuits at two-qubit depth 300circuits_sd, bins_sd, isa_sd = pack_to_budget(
len(sp_sd),
occ_sd,
ranked_sd,
cost_qeb,
DEPTH_BUDGET,
N_CIRCUITS,
pass_manager,
PACKED_SD = sum(len(b) for b in bins_sd)
worst_sd = max(two_qubit_depth(c) for c in isa_sd)
worst_count_sd = max(two_qubit_count(c) for c in isa_sd)
f"packed {PACKED_SD} of {len(ranked_sd)} excitations into {N_CIRCUITS} circuits"
print(f" excitations per circuit {[len(b) for b in bins_sd]}")
print(f" two-qubit depth {[two_qubit_depth(c) for c in isa_sd]}")
print(f" two-qubit gates {[two_qubit_count(c) for c in isa_sd]}")
f"\nworst circuit: two-qubit depth {worst_sd} of a {DEPTH_BUDGET} budget, "
f"{worst_count_sd} two-qubit gates"
)packed 78 of 78 excitations into 16 circuits
excitations per circuit [5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 4, 4]
two-qubit depth [228, 182, 177, 220, 214, 220, 226, 224, 222, 222, 181, 179, 136, 179, 171, 181]
two-qubit gates [234, 231, 227, 228, 225, 225, 233, 229, 233, 226, 230, 223, 232, 226, 176, 185]
worst circuit: two-qubit depth 228 of a 300 budget, 234 two-qubit gatesStep 3: Execute using Qiskit primitives
Submit one job per problem, with the whole ensemble as a single list of circuits. Gate and measurement twirling and dynamical decoupling are enabled to reduce the effects of hardware noise. Their benefit depends on the circuit and backend.
Each job's ID is printed. Use service.job("JOB_ID") to retrieve the completed job and its
results without using additional QPU time.
def sample(isa_circuits, shots, tags):
"""Submit one Sampler job; return the per-circuit bit arrays and the measured QPU seconds."""
sampler.options.environment.job_tags = tags
job = sampler.run(isa_circuits, shots=shots)
f"job {job.job_id()}: {len(isa_circuits)} circuits x {shots:,} shots "
f"on {backend.name}"
return [pub.data.meas for pub in job.result()]
def pool_samples(bit_arrays, sp):
"""Merge the ensemble's bit arrays into one bitstring matrix and probability vector."""
matrices, weights, total = [], [], 0
for bit_array in bit_arrays:
matrix, probabilities = bit_array_to_arrays(bit_array)
matrices.append(matrix)
weights.append(probabilities * bit_array.num_shots)
total += bit_array.num_shots
counts = np.concatenate(weights)
matrix = np.vstack(matrices)
# the same bitstring can appear in more than one circuit; merge duplicate rows
unique, inverse = np.unique(matrix, axis=0, return_inverse=True)
merged = np.zeros(len(unique))
np.add.at(merged, inverse.ravel(), counts)
return unique, merged / merged.sum(), totalbit_arrays_sd = sample(isa_sd, SHOTS, JOB_TAGS + ["20Ne"])
matrix_sd, probs_sd, shots_sd = pool_samples(bit_arrays_sd, sp_sd)
survivors_sd, _ = postselect_by_hamming_right_and_left(
matrix_sd,
probs_sd.copy(),
hamming_right=N_PROTONS,
hamming_left=N_NEUTRONS,
shot_survival_sd = float(
probs_sd[
(matrix_sd[:, len(sp_sd) // 2 :].sum(axis=1) == N_PROTONS)
& (matrix_sd[:, : len(sp_sd) // 2].sum(axis=1) == N_NEUTRONS)
].sum()
reference_bits = "".join(
"1" if q in occ_sd else "0" for q in range(len(sp_sd))
)[::-1]
print(f"\n{shots_sd:,} shots -> {len(matrix_sd):,} distinct bitstrings")
f" {shot_survival_sd:6.1%} of shots carry the right proton and neutron numbers"
print(f" {len(survivors_sd):,} distinct bitstrings do")
order = np.argsort(-probs_sd)
half = len(sp_sd) // 2
print(f"\n{'neutrons':>{half}} | {'protons':<{half}} share")
for i in order[:4]:
bits = "".join("1" if b else "0" for b in matrix_sd[i])
tag = " <- reference determinant" if bits == reference_bits else ""
print(f"{bits[:half]} | {bits[half:]} {probs_sd[i]:6.2%}{tag}")
if len(survivors_sd) == 0:
raise RuntimeError(
"no shot carried the right nucleon numbers; check the backend and "
"the transpiled circuits before spending more QPU time"
)job dap30qtr85ps73fg21p0: 16 circuits x 10,000 shots on ibm_phoenix
160,000 shots -> 17,221 distinct bitstrings
31.5% of shots carry the right proton and neutron numbers
973 distinct bitstrings do
neutrons | protons share
001000010000 | 001000010000 20.08% <- reference determinant
000000010000 | 001000010000 2.25%
001000010000 | 001000000000 2.19%
001000010000 | 000000010000 1.93%Step 4: Post-process and return result in desired classical format
Convert the quantum samples into an energy estimate using the nuclear-symmetry constraints described in the Background section.
Configuration recovery repairs the two nucleon numbers. recover_configurations takes each shot that
has the wrong number of protons or neutrons and flips the bits least consistent with the current
estimate of the average orbital occupancies, instead of discarding it. On the first pass the
occupancy estimate comes from the shots that already survived; afterward it comes from the
eigenvector of the previous subspace, which makes the procedure self-consistent.
and parity are imposed on the recombined products, not on whole shots. Every repaired shot contributes a proton half and a neutron half, and the subspace is spanned by every product of a sampled proton configuration with a sampled neutron configuration that lands at with the right parity. Filtering whole shots on total instead would throw away two good halves for the sake of a quantum number that belongs to their combination.
The four quantum-number checks reject different fractions of samples. The two nucleon numbers account for most of the filtering. Parity is automatically satisfied inside a single major shell: every orbital has even and every orbital odd , so once the nucleon numbers are right the parity cannot be wrong. The parity check is retained because a cross-shell model space would make it an independent constraint. The check keeps products in the target angular-momentum sector. The value of having four exact quantum numbers is that they are cheap and exact, not that each one is a large filter.
Diagonalizing gives a variational upper bound. Because each iteration's subspace contains the last, the sequence of energies falls monotonically, and every entry in it is a rigorous upper bound on the true ground-state energy, regardless of the noise in the samples that produced it.
result_sd = recovery_loop(
inter_sd,
sp_sd,
matrix_sd,
probs_sd,
occ_sd,
N_PROTONS,
N_NEUTRONS,
max_iterations=4,
max_dimension=MAX_DIMENSION,
seed=42,
E_SQD_SD = result_sd["energy"]
recovered_sd = 100 * (E_SQD_SD - E_REF_SD) / (E_EXACT_SD - E_REF_SD)
print(f"\nreference determinant {E_REF_SD:11.6f} MeV")
f"pooled SQD upper bound {E_SQD_SD:11.6f} MeV "
f"(subspace dimension {len(result_sd['basis'])} of {len(basis_exact_sd)})"
print(f"exact diagonalization {E_EXACT_SD:11.6f} MeV")
print(f"\ncorrelation energy recovered: {recovered_sd:.1f}%")
energies_sd = [h["energy"] for h in result_sd["history"]]
if any(b > a + 1e-9 for a, b in zip(energies_sd, energies_sd[1:])):
"the subspaces are not nested; the bound should never rise"
if E_SQD_SD < E_EXACT_SD - 1e-7:
f"pooled SQD returned {E_SQD_SD:.6f}, below the exact {E_EXACT_SD:.6f}; "
"a subspace bound cannot beat the full diagonalization"
) iteration 1: 66 proton x 66 neutron halves -> dimension 640, E = -40.472331 MeV
iteration 2: 66 proton x 66 neutron halves -> dimension 640, E = -40.472331 MeV
pooled SQD upper bound -40.472331 MeV (subspace dimension 640 of 640)
correlation energy recovered: 100.0%Evaluate the results
Use the following checks to evaluate your results on a Heron-class backend with these settings:
- Shot survival on the two nucleon numbers measures the fraction of shots with the correct proton and neutron counts. It can fall as the register grows. A survival rate near zero can indicate a problem with circuit execution. Check the ISA depth in Step 2 and the backend's calibration, not the post-processing.
- The recovery loop should print a subspace dimension that stays constant or grows and an energy that stays constant or falls with
each iteration. If iteration 1 already reaches
MAX_DIMENSION, the classical solver rather than the sampling is the binding constraint. - The recovered fraction for should be high, because the ansatz ceiling computed in Step 1 is the full 640-determinant space; this run is where sampling, not expressiveness, is the only obstacle.
- The two assertions in the preceding cell check the variational bounds. A bound that rises means the subspaces stopped being nested, and a bound below the exact energy means something is wrong with the Hamiltonian, not with the hardware.
Counterintuitively, a noisier backend can give a slightly better bound than a clean one, because errors produce valid half-configurations the ideal circuit would never have sampled, and widening a variational subspace cannot raise its lowest eigenvalue. Noisy simulation can demonstrate the same effect; this tutorial shows it with hardware samples.
# IBM Carbon palette: Blue 60 and Blue 80 for data, Gray 100/70/30 for ink and rules
SURFACE, INK, MUTED, RULE = "#ffffff", "#161616", "#6f6f6f", "#c6c6c6"
SERIES, DEEP, PURPLE = "#0f62fe", "#002d9c", "#6929c4"
def convergence_plot(
history, e_ref, e_exact, title, colour=SERIES, full_dim=None
"""Energy against subspace dimension, scaled to the data rather than to the full window.
A good run lands within a fraction of a percent of the exact answer, so an axis spanning
reference-to-exact would squash every point onto one line. The axis is therefore scaled to
the data (plus the exact line, when there is one), and the right-hand axis carries the
fraction of the correlation energy so the absolute and relative readings sit side by side.
dimensions = [h["dimension"] for h in history]
energies = [h["energy"] for h in history]
fig, ax = plt.subplots(figsize=(7.4, 4.3), facecolor=SURFACE)
ax.set_facecolor(SURFACE)
ax.plot(
dimensions,
energies,
"-o",
color=colour,
linewidth=2,
markersize=8,
markeredgecolor=SURFACE,
markeredgewidth=1.5,
zorder=3,
stacked = {}
for h in history:
# a converged loop repeats the same point; stack the labels so they do not overprint
key = (round(h["dimension"]), round(h["energy"], 9))
offset = 12 + 11 * stacked.get(key, 0)
stacked[key] = stacked.get(key, 0) + 1
ax.annotate(
str(h["iteration"]),
xy=(h["dimension"], h["energy"]),
xytext=(0, offset),
textcoords="offset points",
ha="center",
fontsize=8,
color=MUTED,
span = (max(dimensions) - min(dimensions)) or max(1, max(dimensions) // 4)
x_left, x_right = (
min(dimensions) - 0.14 * span,
max(dimensions) + 0.40 * span,
ax.set_xlim(x_left, x_right)
floor = min(energies) if e_exact is None else min(min(energies), e_exact)
height = max(max(energies) - floor, 1e-3)
ax.set_ylim(floor - 0.30 * height, max(energies) + 0.42 * height)
if e_exact is not None:
ax.axhline(
e_exact, color=MUTED, linestyle="--", linewidth=1, zorder=1
label = "exact" + (f", {full_dim:,} determinants" if full_dim else "")
ax.annotate(
f"{label} {e_exact:.3f} MeV".replace("-", "\u2212"),
xy=(x_left, e_exact),
xytext=(3, 5),
ha="left",
va="bottom",
color=MUTED,
fontsize=9,
# the reference determinant is far off this scale; state it rather than plotting it
ax.annotate(
f"reference determinant {e_ref:.3f} MeV".replace("-", "\u2212")
+ f" ({e_ref - max(energies):+.2f} MeV off the top of this axis)".replace(
"-", "\u2212"
xy=(x_right, max(energies) + 0.42 * height),
xytext=(-3, -12),
ha="right",
va="top",
color=MUTED,
fontsize=8.5,
if e_exact is not None and abs(e_exact - e_ref) > 1e-9:
right = ax.twinx()
low, high = ax.get_ylim()
def to_percent(e):
return 100 * (e - e_ref) / (e_exact - e_ref)
right.set_ylim(to_percent(low), to_percent(high))
right.set_ylabel("correlation energy recovered (%)", color=MUTED)
right.tick_params(colors=MUTED)
for side in ("top", "left"):
right.spines[side].set_visible(False)
right.spines["right"].set_color(MUTED)
right.spines["bottom"].set_color(MUTED)
ax.set_xlabel("subspace dimension", color=MUTED)
ax.set_ylabel("ground-state energy (MeV)", color=MUTED)
ax.set_title(title, color=INK, fontsize=11.5, loc="left", pad=12)
ax.grid(axis="y", color=RULE, alpha=0.55)
ax.tick_params(colors=MUTED)
for side in ("top", "right"):
ax.spines[side].set_visible(False)
for side in ("bottom", "left"):
ax.spines[side].set_color(MUTED)
fig.tight_layout()
return fig
convergence_plot(
result_sd["history"],
E_REF_SD,
E_EXACT_SD,
f"$^{{20}}$Ne: the bound falls as configuration recovery widens the subspace\n"
f"({backend.name}, {N_CIRCUITS} circuits x {SHOTS:,} shots)",
full_dim=len(basis_exact_sd),
Large-scale hardware example
Scaling up changes only the inputs, so the next step is to combine the four stages into one function and run it twice, both times on a 40-qubit register in the shell above a core with the GXPF1 interaction [3].
The two runs illustrate different aspects of scaling:
- , two valence protons and two valence neutrons, has a 4,000-determinant basis. The register is 40 qubits, but the problem is still small enough to diagonalize exactly on a laptop, so you can compare the hardware result with an exact reference after increasing the register size.
- , four valence protons and four valence neutrons, has 1,963,461 symmetry-allowed determinants in the same 40 qubits. The tutorial's dense solver cannot diagonalize that full space, so the run returns a rigorous upper bound and the reference determinant it improves on.
Watch two quantities across the two runs. The fraction of the pool that fits inside the fixed gate
budget shrinks as the pool grows, and pack_ensemble reports how much is included. The
subspace stops being limited by sampling and starts being limited by MAX_DIMENSION, the largest
matrix the dense classical solver here builds. At this scale, a production
calculation would use a selected configuration interaction (selected-CI) solver.
Combine steps 1–4
The following function calls the same stages as the walkthrough, in the same order.
def sqd_run(snt_file, n_protons, n_neutrons, name, exact=True):
"""The whole workflow for one nucleus. Returns a record of every stage."""
ms = read_snt(DATA / snt_file, n_protons, n_neutrons)
sp = m_scheme_states(ms)
inter = Interaction(ms, sp)
if sum(1 for s in sp if s.tz == -1) * 2 != len(sp):
raise ValueError(
f"{name}: post-selection needs equal proton and neutron state counts"
reference = reference_determinant(sp, inter, n_protons, n_neutrons)
e_ref = matrix_element(inter, reference, reference)
raw = excitation_pool(sp, reference)
ranked = rank_pool(
inter, reference, [op for op in raw if conserves_symmetry(sp, op)]
f"{name}: {len(sp)} qubits, {n_protons}p + {n_neutrons}n, A = {ms.mass_number}"
f" 2p2h pool {len(raw)} raw -> {len(ranked)} symmetry-allowed; "
f"reference energy {e_ref:.6f} MeV"
costs = excitation_costs(len(sp), ranked, costing_manager)
circuits, bins, isa = pack_to_budget(
len(sp),
reference,
ranked,
costs,
DEPTH_BUDGET,
N_CIRCUITS,
pass_manager,
packed = sum(len(b) for b in bins)
worst_count = max(two_qubit_count(c) for c in isa)
f" packed {packed} of {len(ranked)} excitations; worst circuit two-qubit depth "
f"{worst}, {worst_count} two-qubit gates"
# a unique tag per run, so the jobs are findable later
bit_arrays = sample(isa, SHOTS, JOB_TAGS + [name])
matrix, probabilities, shots = pool_samples(bit_arrays, sp)
survival = float(
probabilities[
(matrix[:, len(sp) // 2 :].sum(axis=1) == n_protons)
& (matrix[:, : len(sp) // 2].sum(axis=1) == n_neutrons)
].sum()
f" {shots:,} shots -> {len(matrix):,} distinct bitstrings, "
f"{survival:.1%} of shots with the right nucleon numbers"
if survival == 0.0:
raise RuntimeError(
f"{name}: no shot carried the right nucleon numbers"
result = recovery_loop(
inter,
sp,
matrix,
probabilities,
reference,
n_protons,
n_neutrons,
max_iterations=4,
seed=42,
energy = result["energy"]
full_dim = count_basis(sp, n_protons, n_neutrons) # cheap, even when huge
e_exact = None
if exact:
full = full_basis(sp, n_protons, n_neutrons)
if len(full) != full_dim:
f"{name}: counted {full_dim} determinants but enumerated "
f"{len(full)}"
e_exact, _ = ground_state(inter, full)
print(f" reference {e_ref:11.6f} MeV pooled SQD {energy:11.6f} MeV")
f" exact {e_exact:11.6f} MeV (dimension {full_dim}) -> "
f"{100 * (energy - e_ref) / (e_exact - e_ref):.1f}% of the correlation energy"
if energy < e_exact - 1e-7:
f"{name}: pooled SQD bound is below the exact energy"
f" no exact reference: the symmetry-allowed basis is {full_dim:,} determinants"
f" the bound captures {energy - e_ref:.6f} MeV of correlation energy"
print()
return dict(
name=name,
qubits=len(sp),
pool=len(ranked),
packed=packed,
two_qubit=worst,
two_qubit_gates=worst_count,
shots=shots,
distinct=len(matrix),
survival=survival,
dimension=len(result["basis"]),
full_dim=full_dim,
e_ref=e_ref,
e_sqd=energy,
e_exact=e_exact,
history=result["history"],
# the subspace and its eigenvector cannot be reconstructed from the summary --
# they depend on the sampled shots -- so keep them for the scaling analysis
interaction=inter,
states=sp,
reference=reference,
ranked=ranked,
basis=result["basis"],
vector=result["vector"],
pretty = {"20Ne": "$^{20}$Ne", "44Ti": "$^{44}$Ti", "48Cr": "$^{48}$Cr"}
small_scale = dict(
name="20Ne",
qubits=len(sp_sd),
pool=len(ranked_sd),
packed=PACKED_SD,
two_qubit=worst_sd,
two_qubit_gates=worst_count_sd,
shots=shots_sd,
distinct=len(matrix_sd),
survival=shot_survival_sd,
dimension=len(result_sd["basis"]),
e_ref=E_REF_SD,
e_sqd=E_SQD_SD,
e_exact=E_EXACT_SD,
history=result_sd["history"],
interaction=inter_sd,
states=sp_sd,
reference=occ_sd,
ranked=ranked_sd,
basis=result_sd["basis"],
vector=result_sd["vector"],
): the same workflow on a 40-qubit register
The shell above has four orbitals per species and 20 magnetic substates each, so the register is 40 qubits. Two valence protons and two valence neutrons make , with 4,000 symmetry-allowed determinants — about six times the basis, using 40 qubits instead of 24.
This is the larger of the two examples that the notebook can solve exactly, so you can compare the hardware result with an exact reference.
large_scale_verified = sqd_run("gxpf1.snt", 2, 2, "44Ti", exact=True)44Ti: 40 qubits, 2p + 2n, A = 44
2p2h pool 1602 raw -> 174 symmetry-allowed; reference energy -44.309387 MeV
packed 96 of 174 excitations; worst circuit two-qubit depth 272, 285 two-qubit gates
job dap31a02fm4c73f67dp0: 16 circuits x 10,000 shots on ibm_phoenix
160,000 shots -> 48,170 distinct bitstrings, 18.6% of shots with the right nucleon numbers
iteration 1: 187 proton x 189 neutron halves -> dimension 3891, E = -47.849086 MeV
iteration 2: 190 proton x 190 neutron halves -> dimension 4000, E = -47.876666 MeV
iteration 3: 190 proton x 190 neutron halves -> dimension 4000, E = -47.876666 MeV
reference -44.309387 MeV pooled SQD -47.876666 MeV
exact -47.876666 MeV (dimension 4000) -> 100.0% of the correlation energy: beyond the tutorial's exact-diagonalization capacity
Adding two protons and two neutrons uses the same 40-qubit register (4, 4 for
) and increases the basis size by a factor of about 491, to 1,963,461 symmetry-allowed determinants. That
matrix is far beyond anything this tutorial will build, so exact=False: there is no exact reference energy,
only the variational bound and the reference determinant it improves on.
Two things change at this scale, and both are visible in the printout. The pool grows to several
hundred allowed excitations, so the fixed gate budget now covers a minority of it rather than all of
it. Also, the product subspace the samples span is larger than MAX_DIMENSION, so the dense solver
truncates it by sampled weight. The bound remains rigorous but can be less accurate than a bound
computed from all the sampled configurations. A production calculation would retain the samples
and use a solver that supports a larger subspace.
large_scale_unverified = sqd_run("gxpf1.snt", 4, 4, "48Cr", exact=False)48Cr: 40 qubits, 4p + 4n, A = 48
2p2h pool 5536 raw -> 582 symmetry-allowed; reference energy -93.041237 MeV
packed 96 of 582 excitations; worst circuit two-qubit depth 224, 279 two-qubit gates
job dap32a02fm4c73f67eog: 16 circuits x 10,000 shots on ibm_phoenix
160,000 shots -> 55,436 distinct bitstrings, 18.6% of shots with the right nucleon numbers
iteration 1: 223 proton x 223 neutron halves -> dimension 3977, E = -96.481598 MeV
iteration 2: 223 proton x 223 neutron halves -> dimension 3977, E = -96.481598 MeV
reference -93.041237 MeV pooled SQD -96.481598 MeV
no exact reference: the symmetry-allowed basis is 1,963,461 determinants
the bound captures -3.440361 MeV of correlation energyEvaluate a result without an exact reference
The run has no exact reference within this tutorial. Use the existing samples to assess convergence and compare with the classical selection baseline, without additional QPU time or full-space diagonalization.
Is it converged? Reorder the retained determinants by their weight in the converged eigenvector
and the subspaces become nested, so diagonalizing the leading block for a ladder of
traces the bound's descent across two decades of subspace size. If it is still falling steeply at the
largest , the classical solver's dimension cap is the binding constraint and MAX_DIMENSION is the
parameter to increase. If it has flattened, adding more of the retained determinants offers little improvement;
further progress may require sampling additional configurations. The
Hamiltonian is built once at full size and every rung is a principal block of it, so the whole
sweep costs one matrix build rather than one per rung.
How does quantum sampling compare with classical selection? Compare with a subspace of the same size chosen by the classical selection procedure: take the pool ranked by perturbation theory in score order, grow the product subspace to the same dimension, and diagonalize that instead. Both curves are rigorous upper bounds on the same Hamiltonian, so whichever sits lower at equal dimension picked the better determinants. This comparison decides whether hardware sampling improves the energy estimate relative to this classical baseline.
This subspace is not selected for excited states. Configuration recovery steers the subspace using ground-state occupancies, so the higher eigenvalues are much further from converged than the lowest one, and the first excitation energy comes out well above the measured . Reaching excited states properly needs a subspace selected for them.
def subspace_scaling(
inter, basis, vector, points=18, smallest=32, largest=None
"""Nested Rayleigh-Ritz sweep: the lowest eigenvalue of the leading d x d block, for a ladder of d.
Reordering the basis by descending weight in the converged eigenvector makes every subspace in
the ladder a subset of the next, so the energies fall monotonically and each one is a valid
variational bound. H is built once at full size; each rung is a principal block.
order = np.argsort(-(np.abs(vector) ** 2))
ordered = [basis[i] for i in order]
weights = (np.abs(vector) ** 2)[order]
if (
largest is not None
): # cap the ladder so two subspaces end at a common dimension
ordered, weights = ordered[:largest], weights[:largest]
H = subspace_hamiltonian(inter, ordered)
dimensions = np.unique(
np.geomspace(smallest, len(ordered), points).astype(int)
rows = [
int(d),
float(
eigh(H[:d, :d], eigvals_only=True, subset_by_index=[0, 0])[0]
for d in dimensions
return rows, np.cumsum(weights)
def classical_selection(
inter, sp, reference, ranked, target, n_protons, n_neutrons
"""The subspace classical perturbative ranking would pick, grown to `target` dimension.
Same product construction as the sampled subspace, and the same truncation discipline -- half
configurations are offered to `grow_subspace` in order of importance and it takes as many as
fit. The only difference from the sampled path is where the ordering comes from: PT2 score
here, measured sampling weight there. So the comparison isolates *which determinants got
chosen* and nothing else.
Truncating by any other rule would not be a fair baseline. Slicing an arbitrarily ordered
list, for instance, keeps determinants by accident rather than by importance and makes the
classical subspace look worse than classical selection really is.
reached = {reference}
proton_order, neutron_order = [p_ref], [n_ref]
seen_p, seen_n = {p_ref}, {n_ref}
product_budget = 4 * target
for op, _, _ in ranked: # ranked is already in descending PT2 score
h1, h2, v1, v2 = op
fresh = {
for d in reached
reached |= fresh
for det in fresh: # first appearance fixes a half's rank
half_p = tuple(i for i in det if sp[i].tz == -1)
half_n = tuple(i for i in det if sp[i].tz == +1)
if half_p not in seen_p:
seen_p.add(half_p)
proton_order.append(half_p)
if half_n not in seen_n:
seen_n.add(half_n)
neutron_order.append(half_n)
if len(proton_order) * len(neutron_order) > product_budget:
# Half-configuration products over-count the subspace, because only the
# symmetry-allowed ones survive `product_subspace`. Stopping on the product
# count alone can therefore leave the basis far short of `target`, so check
# the dimension actually realized and widen the budget if it falls short.
trial, _, _ = grow_subspace(
sp,
[p_ref],
[n_ref],
proton_order,
neutron_order,
n_protons,
n_neutrons,
max_dimension=target,
if len(trial) >= target:
break
product_budget *= 2
basis, _, _ = grow_subspace(
sp,
[p_ref],
[n_ref],
proton_order,
neutron_order,
n_protons,
n_neutrons,
return basis
run = large_scale_unverified
if "basis" not in run:
raise RuntimeError(
"this cell needs the subspace and eigenvector that sqd_run now returns; "
"re-run the sqd_run definition and the 48Cr cell"
f"{run['name']}: sweeping nested subspaces of the sampled basis "
f"(dimension {run['dimension']})"
sampled_rows, cumulative = subspace_scaling(
run["interaction"], run["basis"], run["vector"]
f"{run['name']}: building the classically selected subspace at the same dimension"
classical_basis = classical_selection(
run["interaction"],
run["states"],
run["reference"],
run["ranked"],
run["dimension"],
4,
4,
# Both subspaces must be scored at the same dimension. Symmetry filtering can still leave
# the classical construction short of the target when the ranked pool runs out, so take the
# dimension both actually reach, cap both ladders there, and verify they agree.
common_dim = min(sampled_rows[-1][0], len(classical_basis))
if common_dim < sampled_rows[-1][0]:
sampled_rows, _ = subspace_scaling(
run["interaction"], run["basis"], run["vector"], largest=common_dim
classical_rows, _ = subspace_scaling(
run["interaction"],
classical_basis,
ground_state(run["interaction"], classical_basis)[1],
largest=common_dim,
if sampled_rows[-1][0] != classical_rows[-1][0]:
raise RuntimeError(
f"comparison dimensions differ: sampled {sampled_rows[-1][0]}, "
f"classical {classical_rows[-1][0]}"
advantage = sampled_rows[-1][1] - classical_rows[-1][1]
direction = "lower" if advantage < 0 else "higher"
verdict = "beats" if advantage < 0 else "does not beat"
descent = next(
e for d, e in reversed(sampled_rows) if d <= sampled_rows[-1][0] / 2
for fraction in (0.90, 0.99):
count = int(np.searchsorted(cumulative, fraction) + 1)
f" {fraction:.0%} of the eigenvector norm sits on {count} determinants "
f"({count / run['full_dim']:.1e} of the {run['full_dim']:,}-determinant space)"
f" bound still falling {1000 * (sampled_rows[-1][1] - descent):+.1f} keV "
f"over the last doubling of dimension"
f" sampled {sampled_rows[-1][1]:.6f} MeV vs classically selected "
f"{classical_rows[-1][1]:.6f} MeV at a verified common dimension of "
f"{classical_rows[-1][0]:,}"
f" -> the sampled subspace is {abs(advantage) * 1000:.0f} keV {direction}"
)48Cr: sweeping nested subspaces of the sampled basis (dimension 3977)
48Cr: building the classically selected subspace at the same dimension
90% of the eigenvector norm sits on 107 determinants (5.4e-05 of the 1,963,461-determinant space)
99% of the eigenvector norm sits on 593 determinants (3.0e-04 of the 1,963,461-determinant space)
bound still falling -15.6 keV over the last doubling of dimension
sampled -96.481598 MeV vs classically selected -95.314510 MeV at a verified common dimension of 3,957
-> the sampled subspace is 1167 keV lowerfig, axes = plt.subplots(1, 2, figsize=(11.2, 4.0), facecolor=SURFACE)
# left: two nested convergence curves on the same axes
ax = axes[0]
ax.plot(
[d for d, _ in sampled_rows],
[e for _, e in sampled_rows],
"-o",
color=SERIES,
linewidth=2,
markersize=5,
markeredgewidth=1,
zorder=4,
label="sampled on the QPU",
ax.plot(
[d for d, _ in classical_rows],
[e for _, e in classical_rows],
"--s",
color=MUTED,
linewidth=1.6,
markersize=4,
markeredgewidth=1,
zorder=3,
label="classically selected, same size",
ax.axhline(run["e_ref"], color=RULE, linestyle=":", linewidth=1.2, zorder=1)
ax.annotate(
f"reference determinant {run['e_ref']:.2f} MeV".replace("-", "\u2212"),
xy=(sampled_rows[-1][0], run["e_ref"]),
xytext=(-2, 4),
ha="right",
va="bottom",
color=MUTED,
fontsize=8,
# mark the gap between the two curves at the largest dimension, not either curve alone
edge = sampled_rows[-1][0]
ax.plot(
[edge, edge],
[classical_rows[-1][1], sampled_rows[-1][1]],
color=SERIES,
linewidth=1.0,
alpha=0.7,
zorder=2,
ax.annotate(
f"{abs(advantage) * 1000:.0f} keV {direction}\nat equal dimension",
xy=(edge, 0.5 * (classical_rows[-1][1] + sampled_rows[-1][1])),
xytext=(-8, 0),
ha="right",
va="center",
color=SERIES,
fontsize=8.5,
ax.set_xscale("log")
ax.set_xlim(sampled_rows[0][0] * 0.75, edge * 1.5)
ax.set_ylabel("variational upper bound (MeV)", color=MUTED)
ax.set_title(
f"{pretty[run['name']]}: the bound, and the subspace it {verdict}",
color=INK,
fontsize=11,
loc="left",
pad=10,
legend = ax.legend(frameon=False, fontsize=8.5, loc="lower left")
for text in legend.get_texts():
text.set_color(MUTED)
# right: why a few thousand determinants can bound two million
ax = axes[1]
ranks = np.arange(1, len(cumulative) + 1)
ax.plot(ranks, 100 * cumulative, "-", color=DEEP, linewidth=2, zorder=3)
for fraction, style, label_y in ((0.90, ":", 46), (0.99, "--", 24)):
ax.axvline(count, color=MUTED, linestyle=style, linewidth=1, zorder=1)
ax.annotate(
f"{fraction:.0%} of the norm\non {count} determinants",
xy=(count, label_y),
xytext=(7, 0),
ha="left",
va="center",
color=MUTED,
fontsize=8.5,
ax.set_xlim(0.8, len(cumulative) * 2.6)
ax.set_ylim(0, 104)
ax.set_xlabel("determinants, ordered by weight", color=MUTED)
ax.set_ylabel("cumulative share of the eigenvector (%)", color=MUTED)
ax.set_title(
f"Sparsity: {run['full_dim']:,} determinants in the sector",
color=INK,
fontsize=11,
loc="left",
pad=10,
for ax in axes:
ax.tick_params(colors=MUTED, labelsize=8.5)
fig.tight_layout()
Compare the three runs
Absolute energies are not comparable across different nuclei and different interactions, so focus on the fraction of the correlation energy recovered across runs, where an exact reference is available. Also compare circuit depth and the fraction of discarded shots.
runs = [small_scale, large_scale_verified, large_scale_unverified]
f"{'run':>6} {'qubits':>6} {'pool':>9} {'2q depth':>8} {'2q gates':>8} "
f"{'shots kept':>10} {'dim':>6} {'of':>9} {'% corr':>7}"
for r in runs:
fraction = (
if r["e_exact"] is None
else f"{100 * (r['e_sqd'] - r['e_ref']) / (r['e_exact'] - r['e_ref']):.1f}%"
coverage = "{}/{}".format(r["packed"], r["pool"])
f"{r['name']:>6} {r['qubits']:>6} {coverage:>9} "
f"{r['two_qubit']:>8} {r['two_qubit_gates']:>8} {r['survival']:>9.1%} "
f"{r['dimension']:>6} {(r['full_dim'] or 0):>9,} {fraction:>7}"
print()
for r in runs:
exact = (
f"exact {r['e_exact']:11.6f}"
if r["e_exact"] is not None
else "exact unavailable"
f"{r['name']:>6} reference {r['e_ref']:11.6f} pooled SQD {r['e_sqd']:11.6f} {exact} MeV"
) run qubits pool 2q depth 2q gates shots kept dim of % corr
20Ne 24 78/78 228 234 31.5% 640 640 100.0%
44Ti 40 96/174 272 285 18.6% 4000 4,000 100.0%
48Cr 40 96/582 224 279 18.6% 3977 1,963,461 --
20Ne reference -29.765549 pooled SQD -40.472331 exact -40.472331 MeV
44Ti reference -44.309387 pooled SQD -47.876666 exact -47.876666 MeV
48Cr reference -93.041237 pooled SQD -96.481598 exact unavailable MeV# Left: how much of the correlation energy was recovered, where the exact answer is known.
# Right: the bound itself for the run that has nothing to score against.
scored = [r for r in runs if r["e_exact"] is not None]
fig, ax = plt.subplots(figsize=(6.4, 3.9), facecolor=SURFACE)
labels = [
f"{pretty[r['name']]}\n{r['qubits']} qubits\n{r['full_dim']:,} determinants"
for r in scored
fractions = [
100 * (r["e_sqd"] - r["e_ref"]) / (r["e_exact"] - r["e_ref"])
for r in scored
shades = [SERIES, DEEP, PURPLE]
bars = ax.bar(
labels, fractions, width=0.46, color=shades[: len(scored)], zorder=3
for bar, fraction, r in zip(bars, fractions, scored):
ax.annotate(
f"{fraction:.1f}%",
xy=(bar.get_x() + bar.get_width() / 2, fraction),
xytext=(0, 5),
ha="center",
va="bottom",
color=INK,
fontsize=10,
ax.annotate(
f"dim {r['dimension']:,}",
xy=(bar.get_x() + bar.get_width() / 2, 3),
ha="center",
va="bottom",
color=SURFACE,
fontsize=8.5,
ax.axhline(100, color=MUTED, linestyle="--", linewidth=1, zorder=1)
ax.annotate(
"exact diagonalization",
xy=(-0.45, 100),
xytext=(0, 4),
ha="left",
va="bottom",
color=MUTED,
fontsize=8.5,
ax.set_ylim(0, 118)
ax.set_ylabel("correlation energy recovered (%)", color=MUTED)
ax.set_title(
f"Where the exact answer is known ({backend.name})",
color=INK,
fontsize=11,
loc="left",
pad=10,
fig.tight_layout()
# the same convergence view as the walkthrough, for the run with no exact reference
convergence_plot(
large_scale_unverified["history"],
large_scale_unverified["e_ref"],
None,
f"{pretty[large_scale_unverified['name']]}: "
f"{large_scale_unverified['full_dim']:,} determinants, no exact answer to score against\n"
colour=DEEP,
Summary
One workflow, unchanged apart from its inputs, ran on a QPU at three problem sizes: a 24-qubit problem you can check exactly, a 40-qubit problem you can still check exactly, and a 40-qubit problem with nearly two million basis states beyond this tutorial's exact-diagonalization capacity.
The three runs illustrate the following points:
- The quantum step only has to propose determinants. The circuit is fixed, seeded from second-order perturbation theory, and never optimized. Nothing in the workflow needs its amplitudes to be accurate, only its support to be useful. Classical diagonalization in the selected subspace gives a variational upper bound, although the bound varies with the sampled configurations.
- Qubit excitations reduce circuit depth. Because only the support matters, the fermionic excitation blocks can be replaced by qubit excitations, whose cost does not grow with the distance between the orbitals they connect. Step 2 measured the saving on the actual backend, which is the difference between a circuit that fits comfortably inside coherence and one that does not.
- Configuration recovery reuses noisy samples. Every shot with the wrong proton or neutron number is repaired against the current occupancy estimate rather than discarded, and each repaired half-configuration can add configurations to the subspace. Widening a variational subspace cannot raise its lowest eigenvalue. This tutorial demonstrates configuration recovery using hardware samples.
- The binding constraint moves as you scale. At 24 qubits the ansatz could reach the exact answer, and only sampling stood in the way. At 40 qubits with four valence nucleons per species, the gate budget covers a minority of the pool and the dense classical solver caps the subspace. Knowing which of the three is limiting you is the practical skill this workflow teaches.
Next steps
Explore these related resources:
- Sample-based quantum diagonalization of a chemistry Hamiltonian: the same algorithm applied to electronic structure, using the SQD addon's selected-CI solver.
- SQD addon documentation: post-selection, subsampling, and configuration-recovery utilities.
- Quantum diagonalization algorithms: a full course on subspace diagonalization, including Krylov variants.
- Introduction to transpilation: the pass-manager options that matter when a circuit is dominated by two-qubit gates.
- Execution modes: explore batch mode for scheduling independent jobs.
Extensions to consider
- Replace the dense solver.
MAX_DIMENSIONis the ceiling on everything at the scale, andnp.linalg.eighon a dense matrix is why. Building the same projected Hamiltonian as a sparse matrix and using an iterative eigensolver such asscipy.sparse.linalg.eigsh, or a Davidson or selected-CI solver designed for nuclear two-body interactions, could support larger subspaces. The practical limit depends on matrix sparsity, available memory, and solver convergence, and this tutorial does not benchmark that extension. The SQD addon'sqiskit_addon_sqd.fermion.solve_sciis not a drop-in substitute: it wraps an electronic-structure solver and expects one- and two-body integrals in that form, so the shared proton neutron product structure is not sufficient on its own. Using it would mean mapping the shell-model interaction of Equation (1) into those integrals and validating the result against the exact energies this notebook already computes. - Add batching and subsampling. The published pooled SQD workflow diagonalizes several independent subsamples per iteration and keeps the best. This tutorial uses one batch per iteration, which is harmless for the variational bound but does not provide the variance information that indicates whether more shots would help.
- Excited states and other sectors. The higher eigenvalues of each subspace Hamiltonian are upper bounds on excited states in the same symmetry sector, and running at reaches other sectors. The check in Step 1 is already half of this calculation.
- A cross-shell model space. Parity is automatically satisfied inside a single major shell, which is why it does no work here. An - space mixes parities, making parity a genuine fourth constraint, one that neither SQD's Hamming-weight repair nor the product construction would catch on its own.
- Odd-mass nuclei.
reference_determinantrequires an even valence count in each species, because a time-reversed paired filling is what forces . An odd nucleus needs a half-integer target and an unpaired reference.
The Fortran sources, interaction data, CMake project, and build instructions are in the docs/tutorials/assets/nuclear_sqd_pooled/fortran directory of the Qiskit documentation repository. Clone the repository, or download that directory, to build and run this tutorial yourself.
Usage estimate: 34 seconds on a Heron r3 processor (NOTE: This is an estimate only. Your runtime might vary.)
Learning outcomes (Fortran)
- Build and run a Qiskit workflow from Fortran, using the Qiskit C library and the qiskit-fortran bindings.
- Learn how a nuclear shell-model Hamiltonian, tabulated in a -coupled basis of orbitals, becomes a qubit Hamiltonian in the -scheme, where one qubit is one single-particle state.
- Build a fixed, non-variational excitation ensemble whose excitations are ranked by second-order perturbation theory and whose angles are seeded from two-level mixing, so there is no classical optimization loop.
- Filter sampled bitstrings by exact nuclear quantum numbers and diagonalize the Hamiltonian in the selected subspace to get a variational upper bound.
- Check the build locally against an exact reference before submitting jobs to IBM Quantum® hardware.
Prerequisites (Fortran)
Before starting, review the following topics:
- Modern Fortran (modules and derived types) and building projects with CMake.
- Sample-based quantum diagonalization, and Sample-based quantum diagonalization of a chemistry Hamiltonian, the electronic-structure counterpart of this tutorial.
- Introduction to primitives.
- Second quantization and the Jordan-Wigner mapping.
Background (Fortran)
The nuclear shell model treats a nucleus as a few valence nucleons moving in a small set of single-particle orbitals above an inert core, interacting through an empirical two-body force fitted to measured spectra. Its computational cost is combinatorial: the basis is every way of distributing the valence protons and neutrons over the available states, and this growth limits the model spaces accessible to exact diagonalization.
Pooled sample-based quantum diagonalization (pooled SQD) [1] splits that problem in two. A quantum circuit is used only to propose which basis states matter. It is measured in the computational basis, and each measured bitstring names one Slater determinant. The Hamiltonian is then built and diagonalized classically in the span of those determinants. Because the classical step is an exact diagonalization inside a subspace, it returns a variational upper bound on the true ground-state energy.
Noise changes which determinants the circuit proposes, but it does not enter the classical Hamiltonian. A shot that violates a conserved quantity is discarded, and a shot that survives is a legitimate basis vector however it was produced. Noise therefore costs subspace quality, not correctness. Nuclear structure provides several exact quantum numbers for this check: a physical determinant must carry the right number of valence protons and valence neutrons, the right total angular-momentum projection , and the right parity.
The Fortran application uses the same register as the Python example. Every qubit is one -scheme single-particle state , and means occupied. Protons come first, then neutrons; within a species, orbitals follow the order of the interaction file; within an orbital, descends. The example here uses this 24-qubit -shell register.
The Hamiltonian is a one-body term plus a two-body interaction,
where label -scheme states. The interaction file tabulates two-body matrix elements in the -coupled basis of orbitals, and the application recovers each -scheme element by Clebsch-Gordan recoupling. The regression test in Check the workflow locally confirms that this produces the same Hamiltonian as the Python example.
The Fortran workflow
- Reference determinant. Fill the lowest single-particle-energy pairs of each species, which gives .
- Excitation pool. Generate the single and double excitations of the reference allowed by angular-momentum coupling, rank them by a second-order perturbation-theory score, , and seed each with its two-level mixing angle.
- Circuit ensemble. Each circuit prepares the reference and applies the next slice of the ranked pool: Givens rotations for single excitations and qubit-excitation gates for double excitations. With the default of 16 excitations per circuit, 11 circuits cover the whole double-excitation pool for .
- Sample. Transpile each circuit and sample it on a QPU.
- Filter. Keep only shots with the right proton number, neutron number, , and parity, and discard the rest.
- Diagonalize. Build the Hamiltonian in the span of the unique kept determinants, pooled across all circuits, and diagonalize it with LAPACK to get a variational upper bound. Alternatively, diagonalize each circuit's samples separately.
Each step maps to a source file in the Fortran directory:
Step | Source |
| Read the interaction and recouple to the -scheme | physics/usdb_reader.f90, physics/clebsch_gordan.f90, physics/orbital_registry.f90 |
| Rank and seed the excitation pool | nuclear_pool.f90, nuclear_selection.f90 |
| Build the circuits | circuit/nuclear_ansatz.f90, nuclear_gates.f90 |
| Sample, filter, and diagonalize | circuit/nuclear_shell_driver.f90, physics/symmetry_filter.f90, physics/exact_solver.f90 |
The Fortran workflow differs from the Python example in several choices, such as how it picks the reference determinant and how it handles samples with the wrong symmetry. Differences from the Python example lists them.
Requirements (Fortran)
This implementation is adapted from the nuclear shell-model application in qiskit-fortran, the Fortran bindings for Qiskit. Build and run the version in the Fortran directory linked in the preceding note rather than the upstream application, because it includes corrections to interaction mass scaling and antisymmetrized pair-exchange phases.
Follow the build instructions to build the Qiskit C library, the Fortran bindings, and this application. The build instructions set NUCLEAR_SRC to the Fortran directory and NUCLEAR_DEPS to a separate directory for the dependencies; the commands in this example use those variables. Use the same Fortran compiler for the bindings and the application, because module files are compiler-specific. Building the Qiskit C library (make c) takes several minutes.
The Quantum Compute Client support described in the build instructions is optional. You need it only to submit hardware jobs; the local checks and saved-bitstring processing work without it.
The build produces nuclear_shell_driver in $NUCLEAR_SRC/build and copies data/USDB.snt beside it. Despite its filename, that file contains the USDA interaction, as its header states. The supplied example describes two valence protons and two valence neutrons in the shell, which is , the same nucleus as the Python small-scale hardware example.
First, run the Hamiltonian regression test:
ctest --test-dir "$NUCLEAR_SRC/build" --output-on-failureThe test builds the complete 640-determinant basis for , diagonalizes it, and checks that the ground-state energy is MeV, the exact energy in the Python example. Passing confirms that the Fortran application builds the same Hamiltonian as the Python example. Because SQD diagonalizes in a subspace of this basis, no run of this application can report an energy below MeV for ; the closer a run gets, the better its sampled subspace.
Next, run the driver without hardware from the build directory:
cd "$NUCLEAR_SRC/build"
./nuclear_shell_driver --protons 2 --neutrons 2 --circuits 3 --shots 256Without --runtime, the application generates copies of the reference determinant rather than sampling a simulated quantum circuit. This checks the classical filtering and diagonalization pipeline; it does not test circuit sampling. The selected subspace has dimension one, so its energy is the reference determinant's diagonal matrix element.
The run prints a detailed log. The expected result is in the RESULT lines near the end:
RESULT energy_level01 -28.644723043 MeV
RESULT subspace_dim 1 states
RESULT pooled_kept 768 shotsTo check saved-bitstring processing, run:
./nuclear_shell_driver --protons 2 --neutrons 2 --circuits 2 --shots 256 --save-bitstrings
./nuclear_shell_driver --bitstrings-dir . --max-steps 2 --protons 2 --neutrons 2 --mode per-stepThe second command reads the bitstrings_stepNN.txt files written by the first, without submitting hardware jobs. Its per-step mode diagonalizes each file separately; it does not combine all files into one pooled subspace. per-step is the default with --bitstrings-dir, and --mode pooled is rejected there, because pooled mode runs the full circuit ensemble. Saved samples, including those from a hardware run, can therefore only be reprocessed per step.
Run on hardware
These commands assume you have already saved your IBM Quantum Platform credentials locally. The pinned Quantum Compute client reads ~/.qiskit/qiskit-ibm.json; use an account named default, default-ibm-quantum-platform, or default-ibm-cloud. Do not put API keys in tutorial files.
From $NUCLEAR_SRC/build, run:
./nuclear_shell_driver --runtime --backend ibm_pittsburgh \
--protons 2 --neutrons 2 --circuits 11 --shots 4096Choose a backend available to your account with enough qubits for the model space; without --backend, the driver uses the least-busy backend. The driver transpiles each circuit, submits it as its own Sampler job, and waits for that job to finish before building the next circuit. The command shown therefore runs 11 jobs one after another, each with 4,096 shots on a 24-qubit register, and uses QPU time for each. If a job does not complete, the driver skips it and leaves its samples out of the pool. The driver also writes the returned samples to bitstrings_stepNN.txt files, which you can reprocess per step as shown in the previous section. Counts and energies depend on the samples and device noise.
Use ./nuclear_shell_driver --help for the full option list. To use another interaction, supply --snt /absolute/path/to/interaction.snt and the corresponding valence nucleon counts. Only the -shell interaction is included; --shell pf requires a separately supplied gxpf1.snt file.
Optional: parallel post-processing
nuclear_shell_parallel is an optional coarray post-processor, built when the compiler and runtime support it. The default GNU build uses the single-image coarray runtime. After generating two step files, check it with:
./nuclear_shell_parallel --steps 2 --protons 2 --neutrons 2 --bitstrings-dir .A multi-image run requires an appropriate coarray runtime and build configuration; launching the single-image binary with multiple processes does not enable distributed execution.
Both versions build the same shell-model Hamiltonian from the USDA interaction, which the regression test confirms for . They differ in how they choose the circuits and process the samples, so independently sampled runs are not expected to produce the same energy:
Column 1 | Fortran example | Python example |
| Reference determinant | Fills the lowest single-particle-energy pairs of each species: MeV for | Searches all paired fillings for the lowest diagonal energy: MeV for |
| Circuit angles | Exact two-level mixing angle, | First-order amplitude, |
| Samples with the wrong symmetry | Discarded by the symmetry filter | Repaired by self-consistent configuration recovery |
| Subspace | Unique kept determinants; whole shots are filtered on proton number, neutron number, , and parity | Products of sampled proton and neutron half-configurations in the target and parity sector |
| Diagonalization | Pooled across all circuits, or per step | Pooled, inside the configuration-recovery loop |
| Backend | Named with --backend, otherwise the least-busy backend | least_busy backend with at least 40 qubits |
| Transpilation | Each circuit separately, optimization level 0 | All circuits together, optimization level 3 |
| Job submission | One job per circuit, one after another | One Sampler job per ensemble |
| Example run | 11 circuits × 4,096 shots for | 16 circuits × 10,000 shots each for , , and |
The Appendix explains why the Python example searches for its reference determinant and uses the first-order amplitude. The Fortran application keeps the simpler choices, so its starting point is higher in energy for , and its circuits seed different amplitudes. Because it discards rather than repairs samples with the wrong symmetry, low sample retention can also limit the accuracy of a Fortran result even though the Hamiltonian is correct.
Next steps (Fortran)
- qiskit-fortran: the Fortran bindings for Qiskit that this application is built on.
- Qiskit C API: the C library that the Fortran bindings call, and Install the Qiskit C API for building it.
- Sample-based quantum diagonalization of a chemistry Hamiltonian: the same algorithm applied to electronic structure.
Extensions to consider (Fortran)
Each difference from the Python example is a place to extend the Fortran application:
- Repair samples instead of discarding them. The symmetry filter drops every shot with the wrong proton or neutron number, so on noisy hardware only a small fraction of shots survive. Configuration recovery, as in the Python example, repairs those shots using average orbital occupancies from the previous diagonalization and recycles them into the subspace.
- Build a product subspace. couples the two halves of a bitstring, so filtering whole shots on discards valid proton and neutron half-configurations. Combining every sampled proton configuration with every sampled neutron configuration, and keeping the products in the target and parity sector, can span a much larger subspace from the same shots.
- Search for the reference determinant. Searching all paired fillings for the lowest diagonal energy, as the Appendix describes, gives a lower starting energy for than filling the lowest single-particle energies.
- Submit the ensemble together. The driver submits one job per circuit and waits for each to finish. Submitting all circuits in one Sampler job, or in a batch, reduces queue and per-job overhead.
- Run a larger model space. Supply a -shell interaction file such as
gxpf1.sntwith--snt, or place it in the run directory and use the--shell pfshorthand, together with the valence nucleon counts. This runs on a 40-qubit register, like the Python example's and runs. Larger subspaces then need more memory for the dense LAPACK diagonalization.
Appendix
This section explains the reasoning behind the helpers introduced in the Setup section.
Why the mass-dependence rescaling is not optional
Empirical shell-model interactions are fitted at one mass and applied across a chain of isotopes, with
the two-body matrix elements scaled as . Both interaction files carry
, with for the USD family and for GXPF1. Note that on the two-body header
line of a .snt file, those two numbers sit where an oscillator frequency and a core energy would
plausibly go, which makes them easy to misread; reading the exponent as a constant core energy adds a
spurious offset to every diagonal element and drops the rescaling, changing the correlation energy by
a few percent. The symmetry check in Step 1 does not by itself verify the energy scale. Comparing
the excitation energy, measured in MeV, with experiment provides an additional check on the
mass-dependent rescaling. An excitation energy is a difference between levels, so it does not
detect a constant offset applied to all energies.
Why the reference is found by search rather than by filling
The obvious reference is the determinant that fills the lowest single-particle energies. It is not the lowest-energy determinant, because the diagonal of Equation (1) includes the two-body term , and the pairing interaction strongly prefers occupying time-reversed partners in the largest available . In the shell, that is the difference between the pair and the pair of , and it is worth about 1 MeV; in the shell, it is worth closer to 2. Because the reference energy defines the zero of the "correlation energy recovered" metric, a poor choice inflates that metric and gives a less accurate starting point.
Restricting to paired fillings makes exhaustive search inexpensive, with candidates per species (a few thousand at most), and ensures . In every case in this tutorial that can be checked against a full enumeration, the search returns the global lowest-diagonal determinant, which is also the single largest component of the exact ground state.
Why the first-order amplitude, not the exact two-level angle
Diagonalizing the Hamiltonian in the space gives the mixing angle ; it might be tempting to call that the correct choice for an isolated pair of levels. In this ansatz, several dozen excitation blocks act in sequence on the same reference, so optimizing each block separately does not necessarily optimize the composite circuit.
The circuit's role determines the choice of angle. Since for every real , the exact angle is always smaller in magnitude than the first-order amplitude , and therefore always leaves more amplitude on the reference determinant. A circuit that keeps more amplitude on the reference returns the reference more often and distinct excited determinants less often. For pooled SQD, the useful output of a shot is a determinant the classical step has not seen yet, which motivates using the larger angle in this tutorial. Neither angle needs to be accurate, because the classical diagonalization discards the circuit's amplitudes entirely and re-derives its own.
Why pooled SQD can use qubit excitations
The fermionic excitation maps under Jordan-Wigner to eight Pauli strings, each carrying operators on every qubit between the outermost indices. Those strings encode the fermionic sign, and their cost grows with the span, which for a proton-neutron excitation is the whole register.
Deleting them gives the qubit-excitation operator of Yordanov et al. [5]. It is a different operator: the state it prepares differs from the fermionic one in the signs of its amplitudes, and the two sampling distributions can differ substantially. What it does not change is which determinants have nonzero amplitude, because each block still rotates within the same two-dimensional space for every determinant it acts on, and it still conserves both nucleon numbers, , and parity exactly. The reachable set of determinants is therefore identical, and the reachable set is the only thing pooled SQD uses; the classical diagonalization assigns its own amplitudes regardless. Step 2 verifies the identical-support claim on a real operator from the pool and measures what the substitution saves.
The limitation is that the sampling weights differ, so the two constructions will not discover determinants in the same order at finite shot count. Since the ranking that decides which excitations enter the circuits is classical and unchanged, and the classical step re-weights everything anyway, the difference in sampling weights is a tradeoff for reduced circuit depth.
Why belongs to the product stage
Post-selection and configuration recovery both act on Hamming weights: the number of protons in one
half of the register, and the number of neutrons in the other. is not of that form. It is a property of a proton configuration paired with a neutron configuration. A shot whose proton
half and neutron half each carry the right nucleon number contains two usable half-configurations even
when their values do not cancel, because the proton half at is perfectly good once it
is paired with a neutron half at . Filtering whole shots on total throws both halves
away, and imposing on the recombined products keeps them. The same argument explains why
recover_configurations needs no notion of to be useful in this case.
References
- J. Robledo-Moreno, M. Motta, H. Haas, et al., "Chemistry beyond the scale of exact diagonalization on a quantum-centric supercomputer", Science Advances 11, eadu9991 (2025). arXiv:2405.05068
- B. A. Brown and W. A. Richter, "New USD Hamiltonians for the sd shell", Physical Review C 74,
034315 (2006). The embedded
usda.sntfile carries the USDA parameters as tabulated by W. A. Richter, S. Mkhize and B. A. Brown, "sd-shell observables for the USDA and USDB Hamiltonians", Physical Review C 78, 064302 (2008). - M. Honma, T. Otsuka, B. A. Brown and T. Mizusaki, "Effective interaction for pf-shell nuclei", Physical Review C 65, 061301(R) (2002).
- B. Huron, J. P. Malrieu and P. Rancurel, "Iterative perturbation calculations of ground and excited state energies from multiconfigurational zeroth-order wavefunctions", The Journal of Chemical Physics 58, 5745 (1973).
- Y. S. Yordanov, D. R. M. Arvidsson-Shukur and C. H. W. Barnes, "Efficient quantum circuits for quantum computational chemistry", Physical Review A 102, 062612 (2020).
- National Nuclear Data Center, Evaluated Nuclear Structure Data File, Brookhaven National Laboratory. Source of the measured excitation energies quoted in Step 1.
