Shor's algorithm
Usage estimate: Three seconds on an Eagle r3 processor (NOTE: This is an estimate only. Your runtime might vary.)
Shor's algorithm, developed by Peter Shor in 1994, is a groundbreaking quantum algorithm for factoring integers in polynomial time. Its significance lies in its ability to factor large integers exponentially faster than any known classical algorithm, threatening the security of widely used cryptographic systems like RSA, which rely on the difficulty of factoring large numbers. By efficiently solving this problem on a sufficiently powerful quantum computer, Shor's algorithm could revolutionize fields such as cryptography, cybersecurity, and computational mathematics, underscoring the transformative power of quantum computation.
This tutorial focuses on demonstrating Shor's algorithm by factoring 15 on a quantum computer.
First, we define the order finding problem and construct corresponding circuits from the quantum phase estimation protocol. Next, we run the order finding circuits on real hardware using shortest-depth circuits we can transpile. The last section completes Shor's algorithm by connecting the order finding problem to integer factorization.
We end the tutorial with a discussion on other demonstrations of Shor's algorithm on real hardware, focusing on both generic implementations and those tailored to factoring specific integers such as 15 and 21.
Note: This tutorial focuses more on the implementation and demonstration of the circuits concerning Shor's algorithm. For an in-depth educational resource on the material, please refer to the Fundamentals of quantum algorithms course by Dr. John Watrous, and papers in the References section.
Requirements
Setup
import pandas as pd
from fractions import Fraction
from math import floor, gcd, log
from qiskit.circuit.library import QFT, UnitaryGate
from qiskit.transpiler import CouplingMap, generate_preset_pass_manager
Background
Shor's algorithm for integer factorization utilizes an intermediary problem known as the order finding problem. In this section, we demonstrate how to solve the order finding problem using quantum phase estimation.
Phase estimation problem
In the phase estimation problem, we're given a quantum state ψ\ket{\psi} of nn qubits, along with a unitary quantum circuit that acts on nn qubits. We're promised that ψ\ket{\psi} is an eigenvector of the unitary matrix UU that describes the action of the circuit, and our goal is to compute or approximate the eigenvalue λ=e2πiθ\lambda = e^{2 \pi i \theta} to which ψ\ket{\psi} corresponds. In other words, the circuit should output an approximation to the number θ[0,1)\theta \in [0, 1) satisfying Uψ=e2πiθψ.U \ket{\psi}= e^{2 \pi i \theta} \ket{\psi}. The goal of the phase estimation circuit is to approximate θ\theta in mm bits. Mathematically speaking, we would like to find yy such that θy/2m\theta \approx y / 2^m, where y0,1,2,,2m1y \in {0, 1, 2, \dots, 2^{m-1}}. The following image shows the quantum circuit that estimates yy in mm bits by making a measurement on mm qubits.
Quantum phase estimation circuit
In the above circuit, top mm qubits are initiated in the 0m\ket{0^m} state, and the bottom nn qubits are initiated in ψ\ket{\psi}, which is promised to be an eigenvector of UU. The first ingredient in the phase estimation circuit are the controlled-unitary operations that are responsible for performing a phase kickback to their corresponding control qubit. These controlled unitaries are exponentiated in accordance to the position of the control qubit, ranging from the least significant bit to the most significant bit. Since ψ\ket{\psi} is an eigenvector of UU, the state of the bottom nn qubits is not affected by this operation, but the phase information of the eigenvalue propagates to the top mm qubits.
It turns out that after the phase kickback operation via controlled-unitaries, all possible states of the top mm qubits are orthonormal to each other for each eigenvector ψ\ket{\psi} of the unitary UU. Therefore, these states are perfectly distinguishable, and we can rotate the basis they form back to the computational basis to make a measurement. A mathematical analysis shows that this rotation matrix corresponds to the inverse quantum Fourier transform (QFT) in 2m2^m-dimensional Hilbert space. The intuition behind this is that the periodic structure of the modular exponentiation operators is encoded in the quantum state, and the QFT converts this periodicity into measurable peaks in the frequency domain.
For a more in-depth understanding of why the QFT circuit is employed in Shor's algorithm, we refer the reader to the Fundamentals of quantum algorithms course.
We are now ready to use the phase estimation circuit for order finding.
Order finding problem
To define the order finding problem, we begin with some number theory concepts. First, for any given positive integer NN, define the set ZN\mathbb{Z}_N as ZN={0,1,2,,N1}.\mathbb{Z}_N = \{0, 1, 2, \dots, N-1\}. All arithmetic operations in ZN\mathbb{Z}_N are performed modulo NN. In particular, all elements aZna \in \mathbb{Z}_n that are coprime with NN are special and constitute ZN\mathbb{Z}^*_N as ZN={aZN:gcd(a,N)=1}.\mathbb{Z}^*_N = \{ a \in \mathbb{Z}_N : \mathrm{gcd}(a, N)=1 \}. For an element aZNa \in \mathbb{Z}^*_N, the smallest positive integer rr such that ar1  (mod  N)a^r \equiv 1 \; (\mathrm{mod} \; N) is defined as the order of aa modulo NN. As we will see later, finding the order of an aZNa \in \mathbb{Z}^*_N will allow us factor NN.
To construct the order finding circuit from the phase estimation circuit, we need two considerations. First, we need to define the unitary UU that will allow us to find the order rr, and second, we need to define an eigenvector ψ\ket{\psi} of UU to prepare the initial state of the phase estimation circuit.
To connect the order finding problem to phase estimation, we consider the operation defined on a system whose classical states correspond to ZN\mathbb{Z}_N, where we multiply by a fixed element aZNa \in \mathbb{Z}^*_N. In particular, we define this multiplication operator MaM_a such that Max=ax  (mod  N)M_a \ket{x} = \ket{ax \; (\mathrm{mod} \; N)} for each xZNx \in \mathbb{Z}_N. Note that it's implicit that we're taking the product modulo NN inside of the ket on the right-hand side of the equation. A mathematical analysis shows that MaM_a is an unitary operator. Furthermore, it turns out that MaM_a has eigenvector and eigenvalue pairs that allow us to connect the order rr of aa to the phase estimation problem. Specifically, for any choice of j{0,,r1}j \in \{0, \dots, r-1\}, we have that ψj=1rk=0r1ωrjkak\ket{\psi_j} = \frac{1}{\sqrt{r}} \sum^{r-1}_{k=0} \omega^{-jk}_{r} \ket{a^k} is an eigenvector of MaM_a whose corresponding eigenvalue is ωrj\omega^{j}_{r}, where ωrj=e2πijr.\omega^{j}_{r} = e^{2 \pi i \frac{j}{r}}.
By observation, we see that a convenient eigenvector/eigenvalue pair is the state ψ1\ket{\psi_1} with ωr1=e2πi1r\omega^{1}_{r} = e^{2 \pi i \frac{1}{r}}. Therefore, if we could find the eigenvector ψ1\ket{\psi_1}, we could estimate the phase θ=1/r\theta=1/r with our quantum circuit and therefore get an estimate of the order rr. However, it's not easy to do so, and we need to consider an alternative.
Let's consider what the circuit would result in if we prepare the computational state 1\ket{1} as the initial state. This is not an eigenstate of MaM_a, but it is the uniform superposition of the eigenstates we just described above. In other words, the following relation holds. 1=1rk=0r1ψk\ket{1} = \frac{1}{\sqrt{r}} \sum^{r-1}_{k=0} \ket{\psi_k} The implication of the above equation is that if we set the initial state to 1\ket{1}, we will obtain precisely the same measurement result as if we had chosen k{0,,r1}k \in \{ 0, \dots, r-1\} uniformly at random and used ψk\ket{\psi_k} as an eigenvector in the phase estimation circuit. In other words, a measurement of the top mm qubits yields an approximation y/2my / 2^m to the value k/rk / r where k{0,,r1}k \in \{ 0, \dots, r-1\} is chosen uniformly at random. This allows us to learn rr with a high degree of confidence after several independent runs, which was our goal.
Modular exponentiation operators
So far, we linked the phase estimation problem to the order finding problem by defining U=MaU = M_a and ψ=1\ket{\psi} = \ket{1} in our quantum circuit. Therefore, the last remaining ingredient is to find an efficient way to define modular exponentials of MaM_a as MakM_a^k for k=1,2,4,,2m1k = 1, 2, 4, \dots, 2^{m-1}. To perform this computation, we find that for any power kk we choose, we can create a circuit for MakM_a^k not by iterating kk times the circuit for MaM_a, but instead by computing b=ak  mod  Nb = a^k \; \mathrm{mod} \; N and then using the circuit for MbM_b. Since we only need the powers that are powers of 2 themselves, we can do this classically efficiently by using iterative squaring.
Specific example with N=15N = 15 and a=2a=2
We can pause here to discuss a specific example and construct the order finding circuit for N=15N=15. Note that possible nontrivial aZNa \in \mathbb{Z}_N^* for N=15N=15 are a{2,4,7,8,11,13,14}a \in \{2, 4, 7, 8, 11, 13, 14 \}. For this example, we choose a=2a=2. We will construct the M2M_2 operator and the modular exponentiation operators M2kM_2^k.
The action of M2M_2 on the computational basis states is as follows. M20=0M25=10M210=5M_2 \ket{0} = \ket{0} \quad M_2 \ket{5} = \ket{10} \quad M_2 \ket{10} = \ket{5} M21=2M26=12M211=7M_2 \ket{1} = \ket{2} \quad M_2 \ket{6} = \ket{12} \quad M_2 \ket{11} = \ket{7} M22=4M27=14M212=9M_2 \ket{2} = \ket{4} \quad M_2 \ket{7} = \ket{14} \quad M_2 \ket{12} = \ket{9} M23=6M28=1M213=11M_2 \ket{3} = \ket{6} \quad M_2 \ket{8} = \ket{1} \quad M_2 \ket{13} = \ket{11} M24=8M29=3M214=13M_2 \ket{4} = \ket{8} \quad M_2 \ket{9} = \ket{3} \quad M_2 \ket{14} = \ket{13} By observation, we can see that the basis states are shuffled, so we have a permutation matrix. We can construct this operation on four qubits with swap gates. Below, we construct the M2M_2 and the controlled-M2M_2 operations.
def M2mod15():
    M2 (mod 15)
    b = 2
    U = QuantumCircuit(4)
    U.swap(2, 3)
    U.swap(1, 2)
    U.swap(0, 1)
    U = U.to_gate()
    U.name = f"M_{b}"
    return U
# Get the M2 operator
M2 = M2mod15()
# Add it to a circuit and plot
circ = QuantumCircuit(4)
circ.compose(M2, inplace=True)
circ.decompose(reps=2).draw(output="mpl", fold=-1)
def controlled_M2mod15():
    Controlled M2 (mod 15)
    b = 2
    U.swap(2, 3)
    U.swap(1, 2)
    U.swap(0, 1)
    U = U.to_gate()
    U.name = f"M_{b}"
    c_U = U.control()
    return c_U
# Get the controlled-M2 operator
controlled_M2 = controlled_M2mod15()
circ = QuantumCircuit(5)
circ.compose(controlled_M2, inplace=True)
circ.decompose(reps=1).draw(output="mpl", fold=-1)
Gates acting on more than two qubits will be further decomposed into two-qubit gates.
Now we need to construct the modular exponentiation operators. To obtain enough precision in the phase estimation, we will use eight qubits for the estimation measurement. Therefore, we need to construct MbM_b with b=a2k  (mod  N)b = a^{2^k} \; (\mathrm{mod} \; N) for each k=0,1,,7k = 0, 1, \dots, 7.
def a2kmodN(a, k, N):
    """Compute a^{2^k} (mod N) by repeated squaring"""
    for _ in range(k):
        a = int(np.mod(a**2, N))
    return a
k_list = range(8)
b_list = [a2kmodN(2, k, 15) for k in k_list]
print(b_list)
[2, 4, 1, 1, 1, 1, 1, 1]
As we can see from the list of bb values, in addition to M2M_2 that we previously constructed, we also need to build M4M_4 and M1M_1. Note that M1M_1 acts trivially on the computational basis states, so it is simply the identity operator.
M4M_4 acts on the computational basis states as follows. M40=0M45=5M410=10M_4 \ket{0} = \ket{0} \quad M_4 \ket{5} = \ket{5} \quad M_4 \ket{10} = \ket{10} M41=4M46=9M411=14M_4 \ket{1} = \ket{4} \quad M_4 \ket{6} = \ket{9} \quad M_4 \ket{11} = \ket{14} M42=8M47=13M412=3M_4 \ket{2} = \ket{8} \quad M_4 \ket{7} = \ket{13} \quad M_4 \ket{12} = \ket{3} M43=12M48=2M413=7M_4 \ket{3} = \ket{12} \quad M_4 \ket{8} = \ket{2} \quad M_4 \ket{13} = \ket{7} M44=1M49=6M414=11M_4 \ket{4} = \ket{1} \quad M_4 \ket{9} = \ket{6} \quad M_4 \ket{14} = \ket{11}
Therefore, this permutation can be constructed with the following swap operation.
def M4mod15():
    M4 (mod 15)
    b = 4
    U.swap(1, 3)
    U.swap(0, 2)
    U = U.to_gate()
    U.name = f"M_{b}"
    return U
# Get the M4 operator
M4 = M4mod15()
circ.compose(M4, inplace=True)
def controlled_M4mod15():
    Controlled M4 (mod 15)
    b = 4
    U.swap(1, 3)
    U.swap(0, 2)
    U = U.to_gate()
    U.name = f"M_{b}"
    c_U = U.control()
    return c_U
# Get the controlled-M4 operator
controlled_M4 = controlled_M4mod15()
circ.compose(controlled_M4, inplace=True)
We saw that MbM_b operators for a given bZNb \in \mathbb{Z}^*_N are permutation operations. Due to the relatively small size of the permutation problem that we have here, since N=15N=15 requires only four qubits, we were able to synthesize these operations directly with SWAP gates by inspection. In general, this might not be a scalable approach. Instead, we might need to construct the permutation matrix explicitly, and use Qiskit's UnitaryGate class and transpilation methods to synthesize this permutation matrix. However, this can result in significantly deeper circuits. An example follows.
def mod_mult_gate(b, N):
    Modular multiplication gate from permutation matrix.
    if gcd(b, N) > 1:
        print(f"Error: gcd({b},{N}) > 1")
        n = floor(log(N - 1, 2)) + 1
        U = np.full((2**n, 2**n), 0)
        for x in range(N):
            U[b * x % N][x] = 1
        for x in range(N, 2**n):
            U[x][x] = 1
        G = UnitaryGate(U)
        G.name = f"M_{b}"
        return G
# Let's build M2 using the permutation matrix definition
M2_other = mod_mult_gate(2, 15)
circ.compose(M2_other, inplace=True)
circ = circ.decompose()
# Transpile the circuit and get the depth
coupling_map = CouplingMap.from_line(4)
pm = generate_preset_pass_manager(coupling_map=coupling_map)
transpiled_circ = pm.run(circ)
print(f"qubits: {circ.num_qubits}")
    f"2q-depth: {transpiled_circ.depth(lambda x: x.operation.num_qubits==2)}"
print(f"2q-size: {transpiled_circ.size(lambda x: x.operation.num_qubits==2)}")
print(f"Operator counts: {transpiled_circ.count_ops()}")
transpiled_circ.decompose().draw(
    output="mpl", fold=-1, style="clifford", idle_wires=False
qubits: 4
2q-depth: 94
2q-size: 96
Operator counts: OrderedDict({'cx': 45, 'swap': 32, 'u': 24, 'u1': 7, 'u3': 4, 'unitary': 3, 'circuit-335': 1, 'circuit-338': 1, 'circuit-341': 1, 'circuit-344': 1, 'circuit-347': 1, 'circuit-350': 1, 'circuit-353': 1, 'circuit-356': 1, 'circuit-359': 1, 'circuit-362': 1, 'circuit-365': 1, 'circuit-368': 1, 'circuit-371': 1, 'circuit-374': 1, 'circuit-377': 1, 'circuit-380': 1})
Let's compare these counts with the compiled circuit depth of our manual implementation of the M2M_2 gate.
# Get the M2 operator from our manual construction
M2 = M2mod15()
circ = circ.decompose(reps=3)
transpiled_circ.draw(
qubits: 4
2q-depth: 9
2q-size: 9
Operator counts: OrderedDict({'cx': 9})
As we can see, the permutation matrix approach resulted in a significantly deep circuit even for a single M2M_2 gate compared to our manual implementation of it. Therefore, we will continue with our previous implementation of the MbM_b operations.
Now, we are ready to construct the full order finding circuit using our previously defined controlled modular exponentiation operators. In the following code, we also import the QFT circuit from the Qiskit Circuit library, which uses Hadamard gates on each qubit, a series of controlled-U1 (or Z, depending on the phase) gates, and a layer of swap gates.
# Order finding problem for N = 15 with a = 2
N = 15
a = 2
# Number of qubits
num_target = floor(log(N - 1, 2)) + 1  # for modular exponentiation operators
num_control = 2 * num_target  # for enough precision of estimation
# List of M_b operators in order
k_list = range(num_control)
# Initialize the circuit
control = QuantumRegister(num_control, name="C")
target = QuantumRegister(num_target, name="T")
output = ClassicalRegister(num_control, name="out")
circuit = QuantumCircuit(control, target, output)
# Initialize the target register to the state |1>
circuit.x(num_control)
# Add the Hadamard gates and controlled versions of the
# multiplication gates
for k, qubit in enumerate(control):
    circuit.h(k)
    b = b_list[k]
    if b == 2:
        circuit.compose(
            M2mod15().control(), qubits=[qubit] + list(target), inplace=True
    elif b == 4:
        circuit.compose(
            M4mod15().control(), qubits=[qubit] + list(target), inplace=True
        continue  # M1 is the identity operator
# Apply the inverse QFT to the control register
circuit.compose(QFT(num_control, inverse=True), qubits=control, inplace=True)
# Measure the control register
circuit.measure(control, output)
circuit.draw("mpl", fold=-1)
Note that we omitted the controlled modular exponentiation operations from the remaining control qubits because M1M_1 is the identity operator.
Note that later in this tutorial, we will run this circuit on the ibm_marrakesh backend. To do this, we transpile the circuit according to this specific backend and report the circuit depth and gate counts.
backend = service.backend("ibm_marrakesh")
pm = generate_preset_pass_manager(optimization_level=2, backend=backend)
transpiled_circuit = pm.run(circuit)
    f"2q-depth: {transpiled_circuit.depth(lambda x: x.operation.num_qubits==2)}"
    f"2q-size: {transpiled_circuit.size(lambda x: x.operation.num_qubits==2)}"
print(f"Operator counts: {transpiled_circuit.count_ops()}")
transpiled_circuit.draw(
2q-depth: 187
2q-size: 260
Operator counts: OrderedDict({'sx': 521, 'rz': 354, 'cz': 260, 'measure': 8, 'x': 4})
First, we discuss what we would theoretically obtain if we ran this circuit on an ideal simulator. Below, we have a set of simulation results of the above circuit using 1024 shots. As we can see, we get an approximately uniform distribution over four bitstrings over the control qubits.
# Obtained from the simulator
counts = {"00000000": 264, "01000000": 268, "10000000": 249, "11000000": 243}
plot_histogram(counts)
By measuring the control qubits, we obtain an eight-bit phase estimation of the MaM_a operator. We can convert this binary representation to decimal to find the measured phase. As we can see from the above histogram, four different bitstrings were measured, and each of them corresponds to a phase value as follows.
# Rows to be displayed in table
rows = []
# Corresponding phase of each bitstring
measured_phases = []
for output in counts:
    decimal = int(output, 2)  # Convert bitstring to decimal
    phase = decimal / (2**num_control)  # Find corresponding eigenvalue
    measured_phases.append(phase)
    # Add these values to the rows in our table:
    rows.append(
            f"{output}(bin) = {decimal:>3}(dec)",
            f"{decimal}/{2 ** num_control} = {phase:.2f}",
# Print the rows in a table
headers = ["Register Output", "Phase"]
df = pd.DataFrame(rows, columns=headers)
print(df)
            Register Output           Phase
0  00000000(bin) =   0(dec)    0/256 = 0.00
1  01000000(bin) =  64(dec)   64/256 = 0.25
2  10000000(bin) = 128(dec)  128/256 = 0.50
3  11000000(bin) = 192(dec)  192/256 = 0.75
Recall that the any measured phase corresponds to θ=k/r\theta = k / r where kk is sampled uniformly at random from {0,1,,r1}\{0, 1, \dots, r-1 \}. Therefore, we can use the continued fractions algorithm to attempt to find kk and the order rr. Python has this functionality built in. We can use the fractions module to turn a float into a Fraction object, for example:
Fraction(0.666)
Fraction(5998794703657501, 9007199254740992)
Because this gives fractions that return the result exactly (in this case, 0.6660000...), this can give gnarly results like the one above. We can use the .limit_denominator() method to get the fraction that most closely resembles our float, with a denominator below a certain value:
# Get fraction that most closely resembles 0.666
# with denominator < 15
Fraction(0.666).limit_denominator(15)
Fraction(2, 3)
This is much nicer. The order (r) must be less than N, so we will set the maximum denominator to be 15:
# Rows to be displayed in a table
rows = []
for phase in measured_phases:
    frac = Fraction(phase).limit_denominator(15)
    rows.append(
        [phase, f"{frac.numerator}/{frac.denominator}", frac.denominator]
headers = ["Phase", "Fraction", "Guess for r"]
print(df)
   Phase Fraction  Guess for r
0   0.00      0/1            1
1   0.25      1/4            4
2   0.50      1/2            2
3   0.75      3/4            4
We can see that two of the measured eigenvalues provided us with the correct result: r=4r=4, and we can see that Shor’s algorithm for order finding has a chance of failing. These bad results are because k=0k = 0, or because kk and rr are not coprime - and instead of rr, we are given a factor of rr. The easiest solution to this is to simply repeat the experiment until we get a satisfying result for rr.
So far, we implemented the order finding problem for N=15N=15 with a=2a=2 using the phase estimation circuit on a simulator. The last step of Shor's algorithm will be to relate the order finding problem to the integer factorization problem. This last part of the algorithm is purely classical and can be solved on a classical computer after the phase measurements have been obtained from a quantum computer. Therefore, we defer the last part of the algorithm until after we demonstrate how we can run the order finding circuit on real hardware.
Hardware runs
Now we can run the order finding circuit that we previously transpiled for ibm_marrakesh. Here we turn to dynamical decoupling (DD) for error suppression, and gate twirling for error mitigation purposes. DD involves applying sequences of precisely timed control pulses to a quantum device, effectively averaging out unwanted environmental interactions and decoherence. Gate twirling, on the other hand, randomizes specific quantum gates to transform coherent errors into Pauli errors, which accumulate linearly rather than quadratically. Both techniques are often combined to enhance the coherence and fidelity of quantum computations.
# Sampler primitive to obtain the probability distribution
sampler = Sampler(backend)
# Turn on dynamical decoupling with sequence XpXm
# Enable gate twirling
pub = transpiled_circuit
job = sampler.run([pub], shots=1024)
result = job.result()[0]
counts = result.data["out"].get_counts()
plot_histogram(counts, figsize=(35, 5))
As we can see, we obtained the same bitstrings with highest counts. Since quantum hardware has noise, there is some leakage to other bitstrings, which we can filter out statistically.
# Dictionary of bitstrings and their counts to keep
counts_keep = {}
# Threshold to filter
threshold = np.max(list(counts.values())) / 2
for key, value in counts.items():
    if value > threshold:
        counts_keep[key] = value
print(counts_keep)
{'00000000': 58, '01000000': 41, '11000000': 42, '10000000': 40}
Integer Factorization
So far, we discussed how we can implement the order finding problem using a phase estimation circuit. Now, we connect the order finding problem to integer factorization, which completes Shor's algorithm. Note that this part of the algorithm is classical.
We now demonstrate this using our example of N=15N = 15 and a=2a = 2. Recall that the phase we measured is k/rk / r, where ar  (mod  N)=1a^r \; (\textrm{mod} \; N) = 1 and kk is a random integer between 00 and r1r - 1. From this equation, we have (ar1)  (mod  N)=0,(a^r - 1) \; (\textrm{mod} \; N) = 0, which means NN must divide ar1a^r-1. If rr is also even, then we can write ar1=(ar/21)(ar/2+1).a^r -1 = (a^{r/2}-1)(a^{r/2}+1). If rr is not even, we cannot go further and must try again with a different value for aa; otherwise, there is a high probability that the greatest common divisor of NN and either ar/21a^{r/2}-1, or ar/2+1a^{r/2}+1 is a proper factor of NN.
Since some runs of the algorithm will statistically fail, we will repeat this algorithm until at least one factor of NN is found.
The cell below repeats the algorithm until at least one factor of N=15N=15 is found. We will use the results of the hardware run above to guess the phase and the corresponding factor in each iteration.
a = 2
N = 15
FACTOR_FOUND = False
num_attempt = 0
while not FACTOR_FOUND:
    print(f"\nATTEMPT {num_attempt}:")
    # Here, we get the bitstring by iterating over outcomes
    # of a previous hardware run with multiple shots.
    # Instead, we can also perform a single-shot measurement
    # here in the loop.
    bitstring = list(counts_keep.keys())[num_attempt]
    num_attempt += 1
    # Find the phase from measurement
    decimal = int(bitstring, 2)
    phase = decimal / (2**num_control)  # phase = k / r
    print(f"Phase: theta = {phase}")
    # Guess the order from phase
    frac = Fraction(phase).limit_denominator(N)
    r = frac.denominator  # order = r
    print(f"Order of {a} modulo {N} estimated as: r = {r}")
    if phase != 0:
        # Guesses for factors are gcd(a^{r / 2} ± 1, 15)
        if r % 2 == 0:
            x = pow(a, r // 2, N) - 1
            d = gcd(x, N)
            if d > 1:
                FACTOR_FOUND = True
                print(f"*** Non-trivial factor found: {x} ***")
ATTEMPT 0:
Phase: theta = 0.0
Order of 2 modulo 15 estimated as: r = 1
ATTEMPT 1:
Phase: theta = 0.25
Order of 2 modulo 15 estimated as: r = 4
*** Non-trivial factor found: 3 ***
Discussion
In this section, we discuss other milestone work that has demonstrated Shor's algorithm on real hardware.
The seminal work [3] from IBM® demonstrated Shor's algorithm for the first time, factoring the number 15 into its prime factors 3 and 5 using a seven-qubit nuclear magnetic resonance (NMR) quantum computer. Another experiment [4] factored 15 using photonic qubits. By employing a single qubit recycled multiple times and encoding the work register in higher-dimensional states, the researchers reduced the required number of qubits to one-third of that in the standard protocol, utilizing a two-photon compiled algorithm. A significant paper in the demonstration of Shor's algorithm is [5], which uses Kitaev's iterative phase estimation [8] technique to reduce the qubit requirement of the algorithm. Authors used seven control qubits and four cache qubits, together with the implementation of modular multipliers. This implementation, however, requires mid-circuit measurements with feed-forward operations and qubit recycling with reset operations. This demonstration was done on an ion-trap quantum computer.
More recent work [6] focused on factoring 15, 21, and 35 on IBM Quantum® hardware. Similar to previous work, researchers used a compiled version of the algorithm that employed a semi-classical quantum Fourier transform as proposed by Kitaev to minimize the number of physical qubits and gates. A most recent work [7] also performed a proof-of-concept demonstration for factoring the integer 21. This demonstration also involved the use of a compiled version of the quantum phase estimation routine, and built upon the previous demonstration by [4]. Authors went beyond this work by using a configuration of approximate Toffoli gates with residual phase shifts. The algorithm was implemented on IBM quantum processors using only five qubits, and the presence of entanglement between the control and register qubits was verified successfully.
Scaling of the algorithm
We note that RSA encryption typically involves key sizes on the order of 2048 to 4096 bits. Attempting to factor a 2048-bit number with Shor's algorithm will result in a quantum circuit with millions of qubits, including the error correction overhead and a circuit depth on the order of a billion, which is beyond the limits of current quantum hardware to execute. Therefore, Shor's algorithm will require either optimized circuit construction methods or robust quantum error correction to be practically viable for breaking modern cryptographic systems. We refer you to [9] for a more detailed discussion on resource estimation for Shor's algorithm.
Challenge
Congratulations for finishing the tutorial! Now is a great time to test your understanding. Could you try to construct the circuit for factoring 21? You can select an aa of your own choice. You will need to decide on the bit accuracy of the algorithm to choose the number of qubits, and you will need to design the modular exponentiation operators MaM_a. We encourage you to try this out yourself, and then read about the methodologies shown in Fig. 9 of [6] and Fig. 2 of [7].
def M_a_mod21():
    M_a (mod 21)
    # Your code here
    pass
References
  1. Shor, Peter W. "Polynomial-time algorithms for prime factorization and discrete logarithms on a quantum computer." SIAM review 41.2 (1999): 303-332.
  2. IBM Quantum Fundamentals of Quantum Algorithms course by Dr. John Watrous.
  3. Vandersypen, Lieven MK, et al. "Experimental realization of Shor's quantum factoring algorithm using nuclear magnetic resonance." Nature 414.6866 (2001): 883-887.
  4. Martin-Lopez, Enrique, et al. "Experimental realization of Shor's quantum factoring algorithm using qubit recycling." Nature photonics 6.11 (2012): 773-776.
  5. Monz, Thomas, et al. "Realization of a scalable Shor algorithm." Science 351.6277 (2016): 1068-1070.
  6. Amico, Mirko, Zain H. Saleem, and Muir Kumph. "Experimental study of Shor's factoring algorithm using the IBM Q Experience." Physical Review A 100.1 (2019): 012305.
  7. Skosana, Unathi, and Mark Tame. "Demonstration of Shor’s factoring algorithm for N=21 on IBM quantum processors." Scientific reports 11.1 (2021): 16599.
  8. Kitaev, A. Yu. "Quantum measurements and the Abelian stabilizer problem." arXiv preprint quant-ph/9511026 (1995).
  9. Gidney, Craig, and Martin Ekerå. "How to factor 2048 bit RSA integers in 8 hours using 20 million noisy qubits." Quantum 5 (2021): 433.
Was this page helpful?
