Nishimori phase transition
Usage estimate: 3 minutes on a Heron r2 processor (NOTE: This is an estimate only. Your runtime might vary.)
Background
This tutorial demonstrates how to realize a Nishimori phase transition on an IBM® quantum processor. This experiment was originally described in Realizing the Nishimori transition across the error threshold for constant-depth quantum circuits.
The Nishimori phase transition refers to the transition between short- and long-range ordered phases in the random-bond Ising model. On a quantum computer, the long-range ordered phase manifests as a state in which qubits are entangled across the entire device. This highly entangled state is prepared using the generation of entanglement by measurement (GEM) protocol. By utilizing mid-circuit measurements, the GEM protocol is able to entangle qubits across the entire device using circuits of only constant depth. This tutorial uses the implementation of the GEM protocol from the GEM Suite software package.
Requirements
  • Qiskit SDK v1.0 or later, with visualization support
  • Qiskit Runtime v0.22 or later ( pip install qiskit-ibm-runtime )
  • GEM Suite ( pip install gem-suite )
Setup
from gem_suite import PlaquetteLattice
from gem_suite.experiments import GemExperiment
The GEM protocol works on a quantum processor with qubit connectivity described by a lattice. Today's IBM quantum processors use the heavy hex lattice. The qubits of the processor are grouped into plaquettes based on which unit cell of the lattice they occupy. Because a qubit might occur in more than one unit cell, the plaquettes are not disjoint. On the heavy hex lattice, a plaquette contains 12 qubits. The plaquettes themselves also form lattice, where two plaquettes are connected if they share any qubits. On the heavy hex lattice, neighboring plaquettes share 3 qubits.
In the GEM Suite software package, the fundamental class for implementing the GEM protocol is PlaquetteLattice, which represents the lattice of plaquettes (which is distinct from the heavy hex lattice). A PlaquetteLattice can be initialized from a qubit coupling map. Currently, only heavy hex coupling maps are supported.
The following code cell initializes a plaquette lattice from the coupling map of a IBM quantum processor. The plaquette lattice does not always encompass the entire hardware. For example, ibm_torino has 133 total qubits, but the largest plaquette lattice that fits on the device uses only 125 of them, and comprises a total of 18 plaquettes. Similar can be observed for IBM Quantum® devices with different qubit counts as well.
# QiskitRuntimeService.save_account(channel="ibm_quantum", token="<YOUR_API_KEYN>", overwrite=True, set_as_default=True)
backend = service.least_busy(
plaquette_lattice = PlaquetteLattice.from_coupling_map(backend.coupling_map)
print(f"Number of qubits in backend: {backend.num_qubits}")
    f"Number of qubits in plaquette lattice: {len(list(plaquette_lattice.qubits()))}"
print(f"Number of plaquettes: {len(list(plaquette_lattice.plaquettes()))}")
Number of qubits in backend: 133
Number of qubits in plaquette lattice: 125
Number of plaquettes: 18
You can visualize the plaquette lattice by generating a diagram of its graph representation. In the diagram, the plaquettes are represented by labeled hexagons, and two plaquettes are connected by an edge if they share qubits.
plaquette_lattice.draw_plaquettes()
You can retrieve information about individual plaquettes, such as the qubits they contain, using the plaquettes method.
# Get a list of the plaquettes
plaquettes = list(plaquette_lattice.plaquettes())
# Display information about plaquette 0
plaquettes[0]
PyPlaquette(index=0, qubits=[0, 1, 2, 3, 4, 15, 16, 19, 20, 21, 22, 23], neighbors=[3, 1])
You can also produce a diagram of the underlying qubits that form the plaquette lattice.
plaquette_lattice.draw_qubits()
In addition to the qubit labels and the edges indicating which qubits are connected, the diagram contains three additional pieces of information that are relevant to the GEM protocol:
  • Each qubit is either shaded (gray) or unshaded. The shaded qubits are "site" qubits that represent the sites of the Ising model, and the unshaded qubits are "bond" qubits used to mediate interactions between the site qubits.
  • Each site qubit is labeled either (A) or (B), indicating one of two roles a site qubit can play in the GEM protocol (the roles are explained later).
  • Each edge is colored using one of six colors, thus partitioning the edges into six groups. This partitioning determines how two-qubit gates can be parallelized, as well as different scheduling patterns that are likely to incur different amounts of error on a noisy quantum processor. Because edges in a group are disjoint, a layer of two-qubit gates can be applied on those edges simultaneously. In fact, it is possible to partition the six colors into three groups of two colors such that the union of each group of two colors is still disjoint. Therefore, only three layers of two-qubit gates are needed to activate every edge. There are 12 ways to so partition the six colors, and each such partition yields a different 3-layer gate schedule.
Now that you have created a plaquette lattice, the next step is to initialize a GemExperiment object, passing both the plaquette lattice and the backend that you intend to run the experiment on. The GemExperiment class manages the actual implementation of the GEM protocol, including generating circuits, submitting jobs, and analyzing the data. The following code cell initializes the experiment class while restricting the plaquette lattice to only two of the plaquettes (21 qubits), reducing the size of the experiment to ensure that the noise in the hardware doesn't overwhelm the signal.
gem_exp = GemExperiment(plaquette_lattice.filter([9, 12]), backend=backend)
# visualize the plaquette lattice after filtering
plaquette_lattice.filter([9, 12]).draw_qubits()
A GEM protocol circuit is built using the following steps:
  1. Prepare the all-+|+\rangle state by applying a Hadamard gate to every qubit.
  2. Apply an RZZR_{ZZ} gate between every pair of connected qubits. This can be achieved using 3 layers of gates. Each RZZR_{ZZ} gate acts on a site qubit and a bond qubit. If the site qubit is labeled (B), then the angle is fixed to π2\frac{\pi}{2}. If the site qubit is labeled (A), then the angle is allowed to vary, producing different circuits. By default, the range of angles is set to 21 equally spaced points between 00 and π2\frac{\pi}{2}, inclusive.
  3. Measure each bond qubit in the Pauli XX basis. Since qubits are measured in the Pauli ZZ basis, this can be accomplished by applying a Hadamard gate before measuring the qubit.
Note that the paper cited in the introduction to this tutorial uses a different convention for the RZZR_{ZZ} angle, which differs from the convention used in this tutorial by a factor of 2.
In step 3, only the bond qubits are measured. To understand what state the site qubits remain in, it is instructive to consider the case that the RZZR_{ZZ} angle applied to site qubits (A) in step 2 is equal to π2\frac{\pi}{2}. In this case, the site qubits are left in a highly entangled state similar to the GHZ state,
GHZ=0000+1111.\lvert \text{GHZ} \rangle = \lvert 00 \cdots 00 \rangle + \lvert 11 \cdots 11 \rangle.
Due to the randomness in the measurement outcomes, the actual state of the site qubits might be a different state with long-range order, for example, 00110+11001\lvert 00110 \rangle + \lvert 11001 \rangle. However, the GHZ state can be recovered by applying a decoding operation based on the measurement outcomes. When the RZZR_{ZZ} angle is tuned down from π2\frac{\pi}{2}, the long-range order can still be recovered up until a critical angle, which in the absence of noise, is approximately 0.3π0.3 \pi. Below this angle, the resulting state no longer exhibits long-range entanglement. This transition between the presence and absence of long-range order is the Nishimori phase transition.
In the description above, the site qubits were left unmeasured, and the decoding operation can be performed by applying quantum gates. In the experiment as implemented in the GEM suite, which this tutorial follows, the site qubits are in fact measured, and the decoding operation is applied in a classical post-processing step.
In the description above, the decoding operation can be performed by applying quantum gates to the site qubits to recover the quantum state. However, if the goal is to immediately measure the state, for example, for characterization purposes, then the site qubits are measured together with the bond qubits, and the decoding operation can be applied in a classical post-processing step. This is how the experiment is implemented in the GEM suite, which this tutorial follows.
In addition to depending on the RZZR_{ZZ} angle in step 2, which by default sweeps across 21 values, the GEM protocol circuit also depends on the scheduling pattern used to implement the 3 layers of RZZR_{ZZ} gates. As discussed previously, there are 12 such scheduling patterns. Therefore, the total number of circuits in the experiment is 21×12=25221 \times 12 = 252.
The circuits of the experiment can be generated using the circuits method of the GemExperiment class.
circuits = gem_exp.circuits()
print(f"Total number of circuits: {len(circuits)}")
Total number of circuits: 252
For the purposes of this tutorial, it is enough to consider just a single scheduling pattern. The following code cell restricts the experiment to the first scheduling pattern. As a result, the experiment only has 21 circuits, one for each RZZR_{ZZ} angle swept over.
# Restrict experiment to the first scheduling pattern
gem_exp.set_experiment_options(schedule_idx=0)
# There are less circuits now
# Print the RZZ angles swept over
print(f"RZZ angles:\n{gem_exp.parameters()}")
Total number of circuits: 21
RZZ angles:
[0.         0.07853982 0.15707963 0.23561945 0.31415927 0.39269908
 0.4712389  0.54977871 0.62831853 0.70685835 0.78539816 0.86393798
 0.9424778  1.02101761 1.09955743 1.17809725 1.25663706 1.33517688
 1.41371669 1.49225651 1.57079633]
The following code cell draws a diagram of the circuit at index 5. To reduce the size of the diagram, the measurement gates at the end of the circuit are removed.
# Get the circuit at index 5
circuit = circuits[5]
# Remove the final measurements to ease visualization
# Draw the circuit
circuit.draw("mpl", fold=-1, scale=0.5)
Transpiling quantum circuits for execution on hardware typically involves a number of stages. Typically, the stages that incur the most computational overhead are choosing the qubit layout, routing the two-qubit gates to conform to the qubit connectivity of the hardware, and optimizing the circuit to minimize its gate count and depth. In the GEM protocol, the layout and routing stages are unnecessary because the hardware connectivity is already incorporated into the design of the protocol. The circuits already have a qubit layout, and the two-qubit gates are already mapped onto native connections. Furthermore, in order to preserve the structure of the circuit as the RZZR_{ZZ} angle is varied, only very basic circuit optimization should be performed.
The GemExperiment class transparently transpiles circuits when executing the experiment. The layout and routing stages are already overridden by default to do nothing, and circuit optimization is performed at a level that only optimizes single-qubit gates. However, you can override or pass additional options using the set_transpile_options method. For the sake of visualization, the following code cell manually transpiles the circuit displayed previously, and draws the transpiled circuit.
# Demonstrate setting transpile options
gem_exp.set_transpile_options(
    optimization_level=1  # This is the default optimization level
    backend=backend,
    initial_layout=list(gem_exp.physical_qubits),
    **dict(gem_exp.transpile_options),
transpiled = pass_manager.run(circuit)
transpiled.draw("mpl", idle_wires=False, fold=-1, scale=0.5)
To execute the GEM protocol circuits on the hardware, call the run method of the GemExperiment object. You can specify the number of shots you want to sample from each circuit. The run method returns an ExperimentData object which you should save to a variable. Note that the run method only submits jobs without waiting for them to finish, so it is a non-blocking call.
exp_data = gem_exp.run(shots=10_000)
To wait for the results, call the block_for_results method of the ExperimentData object. This call will cause the interpreter to hang until the jobs are finished.
exp_data.block_for_results()
ExperimentData(GemExperiment, d0d5880a-34c1-4aab-a7b6-c4f58516bc03, job_ids=['cwg12ptmptp00082khhg'], metadata=<5 items>, figure_names=['two_point_correlation.svg', 'normalized_variance.svg', 'plaquette_ops.svg', 'bond_ops.svg'])
At an RZZR_{ZZ} angle of π2\frac{\pi}{2}, the decoded state would be the GHZ state in the absence of noise. The long-range order of the GHZ state can be visualized by plotting the magnetization of the measured bitstrings. The magnetization MM is defined as the sum of the single-qubit Pauli ZZ operators,
M=j=1NZj,M = \sum_{j=1}^N Z_j,
where NN is the number of site qubits. Its value for a bitstring is equal to the difference between the number of zeros and the number of ones. Measuring the GHZ state yields the all zeros state or the all ones state with equal probability, so the magnetization would be +N+N half of the time and N-N the other half of the time. In the presence of errors due to noise, other values would also appear, but if the noise is not too great, the distribution would still be peaked near +N+N and N-N.
For the raw bitstrings before decoding, the distribution of the magnetization would be equivalent to that of uniformly random bitstrings, in the absence of noise.
The following code cell plots the magnetization of the raw bitstrings and the decoded bitstrings at the RZZR_{ZZ} angle of π2\frac{\pi}{2}.
def magnetization_distribution(
    counts_dict: dict[str, int],
) -> dict[str, float]:
    """Compute magnetization distribution from counts dictionary."""
    # Construct dictionary from magnetization to count
    mag_dist = defaultdict(float)
    for bitstring, count in counts_dict.items():
        mag = bitstring.count("0") - bitstring.count("1")
        mag_dist[mag] += count
    # Normalize
    shots = sum(counts_dict.values())
    for mag in mag_dist:
        mag_dist[mag] /= shots
    return mag_dist
# Get counts dictionaries with and without decoding
data = exp_data.data()
# Get the last data point, which is at the angle for the GHZ state
raw_counts = data[-1]["counts"]
# Without decoding
site_indices = [
    i for i, q in enumerate(gem_exp.plaquettes.qubits()) if q.role == "Site"
site_raw_counts = defaultdict(int)
for key, val in raw_counts.items():
    site_str = "".join(key[-1 - i] for i in site_indices)
    site_raw_counts[site_str] += val
# With decoding
_, site_decoded_counts = gem_exp.plaquettes.decode_outcomes(
    raw_counts, return_counts=True
# Compute magnetization distribution
raw_magnetization = magnetization_distribution(site_raw_counts)
decoded_magnetization = magnetization_distribution(site_decoded_counts)
# Plot
plt.bar(*zip(*raw_magnetization.items()), label="raw")
plt.bar(*zip(*decoded_magnetization.items()), label="decoded", width=0.3)
plt.legend()
plt.xlabel("Magnetization")
plt.ylabel("Frequency")
plt.title("Magnetization distribution with and without decoding")
Text(0.5, 1.0, 'Magnetization distribution with and without decoding')
To more rigorously characterize the long-range order, you can examine the average two-point correlation ff, defined as
f=1N2(M2M2).f = \frac{1}{N^2} \left(\langle M^2 \rangle - \langle M \rangle ^2\right).
A higher value indicates a greater degree of entanglement. The GemExperiment class automatically computes this value for the decoded bitstrings as part of processing the experimental data. It stores a figure that is accessible via the figure method of the experiment data class. In this case, the name of the figure is two_point_correlation.
exp_data.figure("two_point_correlation")
To determine the critical point of the Nishimori phase transition, you can look at the normalized variance of M2/NM^2 / N, defined as
g=1N3(M4M22),g = \frac{1}{N^3} \left(\langle M^4 \rangle - \langle M^2 \rangle^2\right),
which quantifies the amount of fluctuation in the squared magnetization. This value is maximized at the critical point of the Nishimori phase transition. In the absence of noise, the critical point occurs at approximately 0.3π0.3 \pi. In the presence of noise, the critical point is shifted higher, but the phase transition is still observed as long as the critical point occurs below 0.5π0.5 \pi.
exp_data.figure("normalized_variance")
Scale up the experiment
The following code cells run the experiment for six plaquettes (49 qubits) and the full 12 plaquettes (125 qubits) and plot the normalized variance. As the experiment is scaled to larger sizes, the greater amount of noise shifts the critical point rightwards.
    plaquette_lattice.filter(range(3, 9)), backend=backend
gem_exp = GemExperiment(plaquette_lattice, backend=backend)
Conclusion
In this tutorial, you realized a Nishimori phase transition on a quantum processor using the GEM protocol. The metrics that you examined during post-processing, in particular the two-point correlation and the normalized variance, serve as benchmarks of the device's ability to generate long-range entangled states. These benchmarks extend the utility of the GEM protocol beyond probing interesting physics. As part of the protocol, you entangled qubits across the entire device using circuits of only constant depth. This feat is only possible due to the protocol's use of mid-circuit measurements. In this experiment, the entangled state was immediately measured, but an interesting avenue to explore would be to continue using the state in additional quantum processing!
Tutorial survey
Link to survey
Was this page helpful?
